no problem , i guess i know how to update
Point noticed.
My main concern for updates is, wether it´s backward compatible, and what I might need to change (how much work to do to things noone thought of). Openhab isn´t just a one simple package. It influence lots of stuff.
I dont expect see a full detailed list of all changes which will influence my specific system. But because of that, I know there is a risc, that when I do update, I may find myself dealing with and trying to fix things noone thought of, tried or discovered yet. It becomes kinda like the quote: “Dont try fix whats already working” dilemma.
Right now this is what keeping me from updating my main system. Only one good solution: Backup´s
I’m not sure if the issue regarding handling of the OnOff command on a dimmer Item has been addressed already. In the latest snapshot the behaviour is at least different. If I now switch on a lamp which was switched off at 50% level. It initially switches on at the previous leve, but after that directly setting the level to 100% again:
This is a separate issue that I’ve created a PR for already.
Hey Chris - I’ve just tried updating my zsmart to the newest libraries (i was on 1.1.4) and it seems any time I do 1.1.5 or above I have issues with the system. I can get my coordinator online but none of the devices come online. Debug just shows coordinator traffic and paperui says ‘node not found on network’ attached is a copy of the 1.1.5 error instance that spit out a very clear error message before dying. I’ve also included a screenshot of the binding/zsmartsystemversions that were running at the time. Let me know if there is something I need to do on my end to resolve this. Thank you!
openhab_1.1.5.log (151.8 KB)Yes, you will have problems if you do this as there are some changes to the API due to some refactoring.
See the following PR which will be merged once the TP is updated.
Since updating to M8 I’ve noticed difficulty with some bulbs and poor performance (very chatty zigbee network visible via debug) / If I add and remove a bulb it seems to revert back to the 0 is cool white 100 is warm. Does that update require me to remove/rejoin bulbs or are there any known performance issues. Everything does seem to ultimately work and I can try to get some logs later this weekend when i have a bit more time (for now i’ve reverted back to the 1.1.4 on m7)
It should be the same as before.
Color temperature was swapped around to be consistent with ESH definition. Also, the color temperature channel was changed as this is now defined as a system channel by ESH.
No. You might want to delete the thing and add it back so that it uses the new color temp channel.
Please don’t - M8 will become 2.4 in a few days time, and using a different version really isn’t going to solve any issues if there are any. Please try and work out what problems you have and report them.
I agree thank you - I just reverted since I didn’t have time to work on it further and needed it stable. I’ll give a try this weekend with deleting things and rejoining them and let you know if I have any issues.
A complete reinstallation of OH resolved my problems for some days - till yesterday: using XBee stick and ubuntu server 18.04.01 I cannot get this coordinator online anymore. Did another fresh install and here are the logs (trying different parameters)
Has anyone similar problems?
openhab> list |grep -i zig
200 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee
201 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee.dongl
202 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee.dongl
203 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee.dongl
204 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee.dongl
211 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee Binding
212 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee CC2531 Binding
213 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee Ember Binding
214 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee Telegesis Binding
215 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee XBee Binding
openhab> log:tail
17:57:32.767 [INFO ] [rthome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
17:57:33.187 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.50.30:8080
17:57:33.188 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.50.30:8443
17:57:44.244 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘package-standard’ has been installed.
17:57:45.348 [INFO ] [mebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
17:57:45.380 [INFO ] [bpanel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
17:57:45.513 [INFO ] [marthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
17:57:45.528 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘ui-homebuilder’ has been installed.
17:57:45.532 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘ui-basic’ has been installed.
17:57:45.533 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘ui-habpanel’ has been installed.
17:57:45.533 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘ui-paper’ has been installed.
17:58:09.255 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘binding-zigbee’ has been installed.
17:59:04.902 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zigbee:coordinator_xbee:69e57f59’ changed from UNINITIALIZED to INITIALIZING
17:59:04.909 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:04.913 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:04.929 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:04.942 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zigbee:coordinator_xbee:69e57f59’ changed from INITIALIZING to UNKNOWN
17:59:11.038 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:24.038 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:24.078 [ERROR] [est.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zigbee:coordinator_xbee:69e57f59/config’
at com.zsmartsystems.zigbee.app.discovery.ZigBeeDiscoveryExtension.extensionShutdown(ZigBeeDiscoveryExtension.java:96) ~[?:?]
at com.zsmartsystems.zigbee.ZigBeeNetworkManager.shutdown(ZigBeeNetworkManager.java:529) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.dispose(ZigBeeCoordinatorHandler.java:303) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.handleConfigurationUpdate(ZigBeeCoordinatorHandler.java:554) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:91) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:438) [120:org.eclipse.smarthome.io.rest.core:0.10.0.201812091851]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.Server.handle(Server.java:531) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
17:59:53.361 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:53.389 [ERROR] [est.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zigbee:coordinator_xbee:69e57f59/config’
18:00:24.703 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
18:00:24.717 [ERROR] [est.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zigbee:coordinator_xbee:69e57f59/config’
The error is caused when you are shutting down the system, so it doesn’t really help with your problem.
Please can you also format logs with the </>
button so they are more easily readable.
Just letting you know - I ended up just going ahead with this at lunch today since it was daylight out and lights less important. Anyway … went back to m8 and am deleting / rejoining things that have the color temp channel and it seems everything is going smoother. Prior to deleting / readding I did notice a number of discovery failed messages so perhaps something with the channel change was clunking up one of my bulbs. Thanks for the info!
Hi Chris - are these failures normal? I see numerous discovery failed messages. I have been able to get everything re-added with the exception of one bulb that is being difficult. This final node (841826000007ad26) seems to never finish discovery. I"ve attached my log via this link as it was too big to post up here directly. Let me know if you have issues accessing it (its hosted locally by me).
Thanks!
Just so we’re looking at the same messages, can you tell me what you’re actually looking at?
These messages below caught me. I managed to finally get it to join - I power cycled / force reset the bulb again and it started playing nice. Perhaps the bulb was just the issue.
2018-12-12 13:39:42.797 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=4427, apsFrame=EmberApsFrame [profileId=0, clusterId=49, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0,
These aren’t “failures” - this is just a message that is reflected back from the library when a packet is sent. The DISCOVERY thing here in the options simply means that if the NCP doesn’t know the address, it should discovery it.
sorry guys for asking again. I did a complete reset : installed ubuntu server 18.04.1, then zulu-8, openhab2 testing main, added openhab to dialout and tty, changed EXTRA_JAVA_OPTS, zigbee binding and added xbee thing
XBee coordinator stays to unknown; it reports ERROR: 500 - Internal Server Error
What can I do to get it working again???
logs are added as requested (sorry)
17:19:17.718 [INFO ] [bpanel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
17:19:17.896 [INFO ] [mebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
17:19:22.131 [INFO ] [rthome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
17:19:22.650 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.50.30:8080
17:19:22.651 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.50.30:8443
17:19:22.861 [INFO ] [marthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
17:20:42.988 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-zigbee' has been installed.
17:21:07.678 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zigbee:coordinator_xbee:c16885ee' changed from UNINITIALIZED to INITIALIZING
17:21:07.695 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zigbee:coordinator_xbee:c16885ee' has been updated.
17:21:07.698 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zigbee:coordinator_xbee:c16885ee' has been updated.
17:21:07.701 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zigbee:coordinator_xbee:c16885ee' has been updated.
17:21:07.703 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zigbee:coordinator_xbee:c16885ee' has been updated.
17:21:07.725 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zigbee:coordinator_xbee:c16885ee' changed from INITIALIZING to UNKNOWN
17:21:13.831 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zigbee:coordinator_xbee:c16885ee' has been updated.
17:21:31.095 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zigbee:coordinator_xbee:c16885ee' has been updated.
17:21:31.124 [ERROR] [est.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/zigbee:coordinator_xbee:c16885ee/config'
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:438) [120:org.eclipse.smarthome.io.rest.core:0.10.0.oh240M8]
What are you actually doing to cause this error? As I said previously, the error is caused during the shutdown of the binding, and it’s initiated when you did something via the UI.
Thanks for your quick response!!!
It was just after installation.
I had not documented the preferences of the previous settings. As “Flow control” did not work with “Hardware”, I changed it to “Software”.
I did the same in previous installations till it worked.
Now every time I change this value I get the same error - but in contrast to earlier installations I never get it “online”.
I am a bit confused as I had NOT shut the binding down!
Bildschirmfoto%20von%202018-12-14%2020-56-12|690x388 ?
