Logs have been captured.
Seeing a lot of the following in the logs:
2019-12-07 21:46:57.136 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementLqiRequest [0/0 -> 57746/0, cluster=0031, TID=18, startIndex=0]
2019-12-07 21:46:57.140 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=57746/0, profile=0000, cluster=49, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=24, payload=00 00]
2019-12-07 21:46:57.145 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EzspSendUnicastRequest [type=EMBER_OUTGOING_DIRECT, indexOrDestination=57746, apsFrame=EmberApsFrame [profileId=0, clusterId=49, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=24], messageTag=24, messageContents=00 00]
2019-12-07 21:46:57.262 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspSendUnicastResponse [status=EMBER_SUCCESS, sequence=38]
2019-12-07 21:46:57.264 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unhandled EZSP Frame: EzspSendUnicastResponse [status=EMBER_SUCCESS, sequence=38]
2019-12-07 21:46:57.859 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=61732, apsFrame=EmberApsFrame [profileId=0, clusterId=49, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=31], messageTag=17, status=EMBER_DELIVERY_FAILED, messageContents=]
2019-12-07 21:46:57.861 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unhandled EZSP Frame: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=61732, apsFrame=EmberApsFrame [profileId=0, clusterId=49, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=31], messageTag=17, status=EMBER_DELIVERY_FAILED, messageContents=]
2019-12-07 21:46:57.900 [DEBUG] [com.sun.xml.bind.v2.ContextFactory ] - Property com.sun.xml.bind.XmlAccessorFactoryis not active. Using JAXB's implementation
2019-12-07 21:46:57.989 [DEBUG] [com.sun.xml.bind.v2.util.XmlFactory ] - SAXParserFactory instance: com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl@174f714
2019-12-07 21:46:58.147 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspIncomingMessageHandler [type=EMBER_INCOMING_BROADCAST, apsFrame=EmberApsFrame [profileId=0, clusterId=1, sourceEndpoint=0, destinationEndpoint=0, options=[], groupId=0, sequence=213], lastHopLqi=255, lastHopRssi=-51, sender=46274, bindingIndex=255, addressIndex=255, messageContents=F6 FD FF 00 00]
2019-12-07 21:46:58.150 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=46274/0, destinationAddress=0/0, profile=0000, cluster=1, addressMode=null, radius=0, apsSecurity=false, apsCounter=213, payload=F6 FD FF 00 00]
2019-12-07 21:46:58.153 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressRequest [46274/0 -> 0/0, cluster=0001, TID=NULL, nwkAddrOfInterest=65533, requestType=0, startIndex=0]
2019-12-07 21:46:59.288 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspIncomingRouteErrorHandler [status=EMBER_MAC_INDIRECT_TIMEOUT, target=61732]
2019-12-07 21:46:59.290 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unhandled EZSP Frame: EzspIncomingRouteErrorHandler [status=EMBER_MAC_INDIRECT_TIMEOUT, target=61732]
2019-12-07 21:46:59.664 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction timeout: ManagementLqiRequest [0/0 -> 61732/0, cluster=0031, TID=16, startIndex=0]
2019-12-07 21:46:59.670 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000B02B5D8: Node SVC Discovery: ManagementLqiRequest response CommandResult [TIMEOUT]
2019-12-07 21:46:59.675 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000B02B5D8: Node SVC Discovery: request NEIGHBORS failed after 13 attempts.
2019-12-07 21:46:59.678 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000B02B5D8: Node SVC Discovery: running
2019-12-07 21:46:59.681 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000B02B5D8: Node SVC Discovery: complete
2019-12-07 21:46:59.685 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000B02B5D8: Node 61732 update
2019-12-07 21:47:00.137 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspIncomingMessageHandler [type=EMBER_INCOMING_BROADCAST, apsFrame=EmberApsFrame [profileId=0, clusterId=1, sourceEndpoint=0, destinationEndpoint=0, options=[], groupId=0, sequence=214], lastHopLqi=255, lastHopRssi=-51, sender=46274, bindingIndex=255, addressIndex=255, messageContents=F7 FD FF 00 00]
2019-12-07 21:47:00.141 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=46274/0, destinationAddress=0/0, profile=0000, cluster=1, addressMode=null, radius=0, apsSecurity=false, apsCounter=214, payload=F7 FD FF 00 00]
2019-12-07 21:47:00.144 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressRequest [46274/0 -> 0/0, cluster=0001, TID=NULL, nwkAddrOfInterest=65533, requestType=0, startIndex=0]
2019-12-07 21:47:00.557 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=20636, apsFrame=EmberApsFrame [profileId=0, clusterId=49, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=37], messageTag=23, status=EMBER_DELIVERY_FAILED, messageContents=]
2019-12-07 21:47:00.561 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unhandled EZSP Frame: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=20636, apsFrame=EmberApsFrame [profileId=0, clusterId=49, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=37], messageTag=23, status=EMBER_DELIVERY_FAILED, messageContents=]
2019-12-07 21:47:03.005 [DEBUG] [com.sun.xml.bind.v2.ContextFactory ] - Property com.sun.xml.bind.XmlAccessorFactoryis not active. Using JAXB's implementation
2019-12-07 21:47:03.095 [DEBUG] [com.sun.xml.bind.v2.util.XmlFactory ] - SAXParserFactory instance: com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl@9332e0
2019-12-07 21:47:08.110 [DEBUG] [com.sun.xml.bind.v2.ContextFactory ] - Property com.sun.xml.bind.XmlAccessorFactoryis not active. Using JAXB's implementation
2019-12-07 21:47:08.184 [DEBUG] [com.sun.xml.bind.v2.util.XmlFactory ] - SAXParserFactory instance: com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl@8a9c83
