A thread dump?? I know very little about linux, so this will require some help
Doesnt sound good if the problem is lack of resources… I´ll try google it to see if I can find anything…
@chris here is a debug log right after a reboot, (at time 22.17 today aprox).
I´m not quite sure if this is normal, but I see some timeouts, and transaction timeouts.
I just upgraded to openhab2_2.4.0~M4-1
When I now click on one of the Offline ZigBee things. It says
“Bridge - Offline”
Not sure if that means anything different than “offline”
Hi @chris - I’m having similar problems and cannot get more than one sengled bulb to pair with my husbzb-1 dongle.
I saw your document for sniffing. I have a few questions that aren’t entirely clear in the document:
I’ve tried the following (Wireshark running on another host):
java -jar ZigBeeSniffer.jar -port /dev/ttyUSB1 -baud 115200 -flow hardware --ipaddr 192.168.100.3 --ipport 17754
but didn’t capture any packets…
Thanks!
Peter
You can use an HUSBZB-1, but note that you will need a separate one for sniffing - you can’t use the same device as you use for the coordinator.
Correct - but as above, you do need a separate device for sniffing.
OpenHAB will need to be running as we want to see the communications between the devices and openHAB.
I don’t know - it really depends where the problem is. If there’s a problem with the device joining the network, then yes, you will need to capture this activity. If the problem is elsewhere, then this shouldn’t be needed.
Hi, I have same problem with " LUMI lumi.sensor_magnet.aq2" (Aqara Door Sensor).
Paired, working… but after reboot my device, lost comunication with LUMI and in logs see only
> 2018-11-02 20:05:27.028 [nt.FirmwareStatusInfoEvent] - Firmware status of thing zigbee:device:b926f303:00158d000251b67f changed to UNKNOWN.
> 2018-11-02 20:05:57.455 [hingStatusInfoChangedEvent] - 'zigbee:device:b926f303:00158d000251b67f' changed from OFFLINE to ONLINE
Thats last info about Zigbee, and nothing else see in log (I have INFO log only).
CC2531EMK Coordinator is ONLINE and working.
I try to remove Thing LUMI from OpenHAB, and after Discovery Zigbee is discovered LUMI. But still not working. I need reset it to work again.
