Zigbee devices work for sometime and then suddenly stop working
Hi
I am using CC2531EMK dongle
schneider zigbee switches
openhab version 2.5.1
zigbee binding version 2.5.1
CC2531 dongle is online and zigbee devices are also online.
After the configuration the switches seem to work.But after sometime they does not respond from openhab ui.
Following are the debug logs
[WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.353 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.354 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.355 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.356 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.357 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.359 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.360 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.361 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.362 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.363 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.364 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.365 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.366 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.367 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.368 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.369 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.370 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.371 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.372 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.373 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.374 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.375 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.376 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.377 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.378 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.380 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.381 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.382 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.384 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.385 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.407 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.408 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.409 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.410 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.411 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.412 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.413 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.414 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.415 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.416 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.417 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.418 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.419 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.420 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.421 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.422 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.423 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.424 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.425 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.426 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.427 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.428 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.429 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.430 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.431 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.432 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.433 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.434 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.435 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.436 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.437 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.438 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.439 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.440 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.441 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.442 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.443 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.444 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.445 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.446 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:33.447 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:34.175 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - AF_DATA_REQUEST executed and timed out while waiting for response.
2020-02-05 21:20:34.176 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - Failed to send AF_DATA_REQUEST [attempt 1]
2020-02-05 21:20:35.179 [DEBUG] [31.network.impl.CommandInterfaceImpl] - ->  AF_DATA_REQUEST (Packet: subsystem=null, length=15, apiId=24 01, data=FE 0F 24 01 79 E7 00 00 01 00 38 30 1F 05 1E 79 E7 01 00 26, checksum=26, error=false)
2020-02-05 21:20:35.205 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.206 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.208 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.210 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.212 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.214 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.260 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.261 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.263 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.264 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.266 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.268 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.269 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.270 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.272 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.273 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.275 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.276 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.278 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.280 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.281 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.283 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.284 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.286 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.308 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.309 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.311 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.312 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.314 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.315 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.317 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.318 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.320 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.321 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.323 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.324 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.326 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.327 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.329 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.330 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.332 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.333 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.335 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.336 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.338 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.339 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.341 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.342 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.344 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:35.345 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:36.183 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - AF_DATA_REQUEST executed and timed out while waiting for response.
2020-02-05 21:20:36.184 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - Failed to send AF_DATA_REQUEST [attempt 2]
2020-02-05 21:20:37.686 [DEBUG] [31.network.impl.CommandInterfaceImpl] - ->  AF_DATA_REQUEST (Packet: subsystem=null, length=15, apiId=24 01, data=FE 0F 24 01 79 E7 00 00 01 00 38 30 1F 05 1E 79 E7 01 00 26, checksum=26, error=false)
2020-02-05 21:20:37.707 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.708 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.709 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.710 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.712 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.713 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.763 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.764 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.765 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.766 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.767 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.768 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.769 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.770 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.771 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.772 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.773 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.774 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.775 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.776 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.777 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.778 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.799 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.800 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.801 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.802 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.803 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.804 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.805 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.806 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.807 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.808 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.809 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.810 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.811 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.812 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.813 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.814 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.815 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.816 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.817 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.818 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.819 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.820 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.821 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.822 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:37.823 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-05 21:20:38.689 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - AF_DATA_REQUEST executed and timed out while waiting for response.
2020-02-05 21:20:38.692 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - Failed to send AF_DATA_REQUEST [attempt 3]
2020-02-05 21:20:38.694 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=1E state=TX_NAK
2020-02-05 21:20:38.695 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=1E, state=TX_NAK, outstanding=5
2020-02-05 21:20:38.704 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: NetworkAddressResponse [CF7C/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=53116, startIndex=null, nwkAddrAssocDevList=[]]
2020-02-05 21:20:38.704 [DEBUG] [transaction.ZigBeeTransactionManager] - 76EA/11: Sending ZigBeeTransaction [ieeeAddress=00124B0014ADDB93 queueTime=57270, state=WAITING, sendCnt=1, command=ConfigureReportingCommand [On/Off: 0000/0 -> 76EA/11, cluster=0006, TID=1D, records=[AttributeReportingConfigurationRecord [attributeDataType=BOOLEAN, attributeIdentifier=0, direction=0, minimumReportingInterval=1, maximumReportingInterval=900]]]]
2020-02-05 21:20:38.705 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 6 outstanding
2020-02-05 21:20:38.706 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [CF7C/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=53116, startIndex=null, nwkAddrAssocDevList=[]]
2020-02-05 21:20:38.708 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ConfigureReportingCommand [On/Off: 0000/0 -> 76EA/11, cluster=0006, TID=1D, records=[AttributeReportingConfigurationRecord [attributeDataType=BOOLEAN, attributeIdentifier=0, direction=0, minimumReportingInterval=1, maximumReportingInterval=900]]]
2020-02-05 21:20:38.709 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=29, commandId=6]
2020-02-05 21:20:38.710 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [CF7C/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=53116, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=null queueTime=34211, state=TRANSMITTED, sendCnt=1, command=NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=24, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]]
2020-02-05 21:20:38.712 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=76EA/11, profile=0104, cluster=0006, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=39, payload=00 1D 06 00 00 00 10 01 00 84 03]
2020-02-05 21:20:38.713 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [CF7C/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=53116, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B0014ADDB93 queueTime=23060, state=TRANSMITTED, sendCnt=2, command=ManagementBindRequest [0000/0 -> 76EA/0, cluster=0033, TID=20, startIndex=0]]
2020-02-05 21:20:38.714 [DEBUG] [31.network.impl.CommandInterfaceImpl] - ->  AF_DATA_REQUEST (Packet: subsystem=null, length=21, apiId=24 01, data=FE 15 24 01 EA 76 0B 01 06 00 39 30 1F 0B 00 1D 06 00 00 00 10 01 00 84 03 30, checksum=30, error=false)
2020-02-05 21:20:38.717 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [CF7C/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=53116, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B001470001A queueTime=69088, state=DISPATCHED, sendCnt=2, command=IeeeAddressRequest [0000/0 -> E779/0, cluster=0001, TID=1E, nwkAddrOfInterest=E779, requestType=1, startIndex=0]]
2020-02-05 21:20:38.721 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [CF7C/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=53116, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B0014700018 queueTime=28671, state=TRANSMITTED, sendCnt=2, command=IeeeAddressRequest [0000/0 -> CF7C/0, cluster=0001, TID=23, nwkAddrOfInterest=CF7C, requestType=1, startIndex=0]]
2020-02-05 21:20:38.725 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [CF7C/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=53116, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B0014ADDB93 queueTime=57291, state=DISPATCHED, sendCnt=2, command=ConfigureReportingCommand [On/Off: 0000/0 -> 76EA/11, cluster=0006, TID=1D, records=[AttributeReportingConfigurationRecord [attributeDataType=BOOLEAN, attributeIdentifier=0, direction=0, minimumReportingInterval=1, maximumReportingInterval=900]]]]
2020-02-05 21:20:38.729 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [CF7C/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=53116, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B0014700018 queueTime=23050, state=TRANSMITTED, sendCnt=1, command=ManagementBindRequest [0000/0 -> CF7C/0, cluster=0033, TID=25, startIndex=0]]
2020-02-05 21:20:38.733 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received EA
2020-02-05 21:20:38.734 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 76
2020-02-05 21:20:38.736 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received B8
2020-02-05 21:20:38.738 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-  AF_DATA_SRSP (FE 01 64 01 00 64)
2020-02-05 21:20:38.740 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0D 45 80 00 93 DB AD 14 00 4B 12 00 EA 76 00 00 FC)
2020-02-05 21:20:38.740 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=1D state=TX_ACK
2020-02-05 21:20:38.742 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=1D, state=TX_ACK, outstanding=6
2020-02-05 21:20:38.742 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=13, apiId=45 80, data=FE 0D 45 80 00 93 DB AD 14 00 4B 12 00 EA 76 00 00 FC, checksum=FC, error=false
2020-02-05 21:20:38.744 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 1D -> TX_ACK == TRANSMITTED
2020-02-05 21:20:38.744 [DEBUG] [transaction.ZigBeeTransactionManager] - FFFF/0: Sending ZigBeeTransaction [ieeeAddress=null queueTime=34244, state=WAITING, sendCnt=0, command=NetworkAddressRequest [0000/0 -> FFFF/0, cluster=0000, TID=26, ieeeAddr=00124B0014700018, requestType=0, startIndex=0]]
2020-02-05 21:20:38.746 [DEBUG] [e.dongle.cc2531.ZigBeeDongleTiCc2531] - Unhandled ZToolPacket type 0x4580
2020-02-05 21:20:38.746 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 7 outstanding
2020-02-05 21:20:38.749 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 14 45 FF EA 76 00 00 80 00 24 00 00 00 93 DB AD 14 00 4B 12 00 EA 76 A2)
2020-02-05 21:20:38.750 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: NetworkAddressRequest [0000/0 -> FFFF/0, cluster=0000, TID=26, ieeeAddr=00124B0014700018, requestType=0, startIndex=0]
2020-02-05 21:20:38.751 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=20, apiId=45 FF, data=FE 14 45 FF EA 76 00 00 80 00 24 00 00 00 93 DB AD 14 00 4B 12 00 EA 76 A2, checksum=A2, error=false
2020-02-05 21:20:38.754 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=FFFF/0, profile=0000, cluster=0000, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=3A, payload=26 18 00 70 14 00 4B 12 00 00 00]
2020-02-05 21:20:38.754 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=76EA/0, destinationAddress=0000/0, profile=0000, cluster=8000, addressMode=null, radius=0, apsSecurity=false, apsCounter=--, payload=00 00 93 DB AD 14 00 4B 12 00 EA 76]
2020-02-05 21:20:38.756 [DEBUG] [31.network.impl.CommandInterfaceImpl] - ->  AF_DATA_REQUEST (Packet: subsystem=null, length=21, apiId=24 01, data=FE 15 24 01 FF FF 00 00 00 00 3A 30 1F 0B 26 18 00 70 14 00 4B 12 00 00 00 2D, checksum=2D, error=false)
2020-02-05 21:20:38.757 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: NetworkAddressResponse [76EA/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=30442, startIndex=null, nwkAddrAssocDevList=[]]
2020-02-05 21:20:38.760 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [76EA/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=30442, startIndex=null, nwkAddrAssocDevList=[]]
2020-02-05 21:20:38.764 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [76EA/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=30442, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=null queueTime=34265, state=TRANSMITTED, sendCnt=1, command=NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=24, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]]
2020-02-05 21:20:38.767 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction response received - waiting TX_ACK: ZigBeeTransaction [ieeeAddress=null queueTime=34268, state=RESPONDED, sendCnt=1, command=NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=24, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]]
2020-02-05 21:20:38.768 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [76EA/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=30442, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B0014ADDB93 queueTime=23115, state=TRANSMITTED, sendCnt=2, command=ManagementBindRequest [0000/0 -> 76EA/0, cluster=0033, TID=20, startIndex=0]]
2020-02-05 21:20:38.771 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [76EA/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=30442, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B001470001A queueTime=69142, state=DISPATCHED, sendCnt=2, command=IeeeAddressRequest [0000/0 -> E779/0, cluster=0001, TID=1E, nwkAddrOfInterest=E779, requestType=1, startIndex=0]]
2020-02-05 21:20:38.774 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [76EA/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=30442, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B0014700018 queueTime=28724, state=TRANSMITTED, sendCnt=2, command=IeeeAddressRequest [0000/0 -> CF7C/0, cluster=0001, TID=23, nwkAddrOfInterest=CF7C, requestType=1, startIndex=0]]
2020-02-05 21:20:38.777 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [76EA/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=30442, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B0014ADDB93 queueTime=57344, state=TRANSMITTED, sendCnt=2, command=ConfigureReportingCommand [On/Off: 0000/0 -> 76EA/11, cluster=0006, TID=1D, records=[AttributeReportingConfigurationRecord [attributeDataType=BOOLEAN, attributeIdentifier=0, direction=0, minimumReportingInterval=1, maximumReportingInterval=900]]]]
2020-02-05 21:20:38.780 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [76EA/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=30442, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=00124B0014700018 queueTime=23102, state=TRANSMITTED, sendCnt=1, command=ManagementBindRequest [0000/0 -> CF7C/0, cluster=0033, TID=25, startIndex=0]]
2020-02-05 21:20:38.784 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [76EA/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=30442, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=null queueTime=34283, state=DISPATCHED, sendCnt=1, command=NetworkAddressRequest [0000/0 -> FFFF/0, cluster=0000, TID=26, ieeeAddr=00124B0014700018, requestType=0, startIndex=0]]
2020-02-05 21:20:38.787 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolParseException: Packet checksum failed
	at com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolPacketStream.parsePacket(ZToolPacketStream.java:141) [bundleFile:?]
	at com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolPacketParser.run(ZToolPacketParser.java:107) [bundleFile:?]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2020-02-05 21:20:38.789 [DEBUG] [531.network.packet.ZToolPacketParser] - Received a BAD PACKET FE 00 00 00 00
2020-02-05 21:20:38.790 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-  AF_DATA_SRSP (FE 01 64 01 00 64)
2020-02-05 21:20:38.791 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0F 45 81 00 18 00 70 14 00 4B 12 00 7C CF 00 01 EA 76 C0)
2020-02-05 21:20:38.791 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=26 state=TX_ACK
2020-02-05 21:20:38.792 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=15, apiId=45 81, data=FE 0F 45 81 00 18 00 70 14 00 4B 12 00 7C CF 00 01 EA 76 C0, checksum=C0, error=false
2020-02-05 21:20:38.793 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=26, state=TX_ACK, outstanding=7
2020-02-05 21:20:38.794 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=CF7C/0, destinationAddress=0000/0, profile=0000, cluster=8001, addressMode=null, radius=0, apsSecurity=false, apsCounter=--, payload=00 00 18 00 70 14 00 4B 12 00 7C CF 01 00 EA 76]
2020-02-05 21:20:38.795 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 1E -> TX_NAK == DISPATCHED
2020-02-05 21:20:38.795 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: Added transaction to queue, len=4, transaction=ZigBeeTransaction [ieeeAddress=null queueTime=0, state=WAITING, sendCnt=0, command=NetworkAddressRequest [0000/0 -> FFFF/0, cluster=0000, TID=--, ieeeAddr=00124B001470001A, requestType=0, startIndex=0]]
2020-02-05 21:20:38.799 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 26 -> TX_ACK == TRANSMITTED
2020-02-05 21:20:38.799 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=00124B001470001A queueTime=69168, state=FAILED, sendCnt=2, command=IeeeAddressRequest [0000/0 -> E779/0, cluster=0001, TID=1E, nwkAddrOfInterest=E779, requestType=1, startIndex=0]]
2020-02-05 21:20:38.800 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 6 outstanding
2020-02-05 21:20:38.796 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 00124B0014700018: transactionComplete FAILED 1
2020-02-06 14:40:01.126 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:01.128 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:01.130 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:01.133 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:01.135 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:01.137 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:01.139 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:01.967 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - AF_DATA_REQUEST executed and timed out while waiting for response.
2020-02-06 14:40:01.969 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - Failed to send AF_DATA_REQUEST [attempt 3]
2020-02-06 14:40:01.972 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=24 state=TX_NAK
2020-02-06 14:40:01.976 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=24, state=TX_NAK, outstanding=2
2020-02-06 14:40:01.979 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=00124B001470001A queueTime=29004, state=FAILED, sendCnt=1, command=IeeeAddressRequest [0000/0 -> 9050/0, cluster=0001, TID=24, nwkAddrOfInterest=9050, requestType=1, startIndex=0]]
2020-02-06 14:40:01.981 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2020-02-06 14:40:01.981 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: NetworkAddressResponse [3713/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=14099, startIndex=null, nwkAddrAssocDevList=[]]
2020-02-06 14:40:01.981 [DEBUG] [transaction.ZigBeeTransactionManager] - FFFD/0: Sending ZigBeeTransaction [ieeeAddress=null queueTime=17753, state=WAITING, sendCnt=0, command=NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=25, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]]
2020-02-06 14:40:01.983 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [3713/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=14099, startIndex=null, nwkAddrAssocDevList=[]]
2020-02-06 14:40:01.984 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2020-02-06 14:40:01.987 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [3713/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=14099, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=null queueTime=17759, state=WAITING, sendCnt=0, command=NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=25, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]]
2020-02-06 14:40:01.990 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=25, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]
2020-02-06 14:40:01.990 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [3713/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014700018, nwkAddrRemoteDev=14099, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=null queueTime=29026, state=TRANSMITTED, sendCnt=1, command=NetworkAddressRequest [0000/0 -> FFFF/0, cluster=0000, TID=23, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]]
2020-02-06 14:40:01.999 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 14
2020-02-06 14:40:02.001 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 00
2020-02-06 14:40:02.000 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=FFFD/0, profile=0000, cluster=0000, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=30, payload=25 93 DB AD 14 00 4B 12 00 00 00]
2020-02-06 14:40:02.002 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 4B
2020-02-06 14:40:02.004 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 12
2020-02-06 14:40:02.006 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 00
2020-02-06 14:40:02.004 [DEBUG] [31.network.impl.CommandInterfaceImpl] - ->  AF_DATA_REQUEST (Packet: subsystem=null, length=21, apiId=24 01, data=FE 15 24 01 FD FF 00 00 00 00 30 30 1F 0B 25 93 DB AD 14 00 4B 12 00 00 00 AB, checksum=AB, error=false)
2020-02-06 14:40:02.008 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received A2
2020-02-06 14:40:02.009 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 36
2020-02-06 14:40:02.011 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 00
2020-02-06 14:40:02.013 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 01
2020-02-06 14:40:02.015 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 50
2020-02-06 14:40:02.017 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 90
2020-02-06 14:40:02.019 [DEBUG] [531.network.packet.ZToolPacketParser] - Discarded stream: expected start byte but received 36
2020-02-06 14:40:02.021 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 18 45 FF A2 36 00 01 80 00 1B 00 00 00 93 DB AD 14 00 4B 12 00 A2 36 01 00 50 90 51)
2020-02-06 14:40:02.023 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=24, apiId=45 FF, data=FE 18 45 FF A2 36 00 01 80 00 1B 00 00 00 93 DB AD 14 00 4B 12 00 A2 36 01 00 50 90 51, checksum=51, error=false
2020-02-06 14:40:02.026 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=36A2/0, destinationAddress=0000/0, profile=0000, cluster=8001, addressMode=null, radius=0, apsSecurity=false, apsCounter=--, payload=00 00 93 DB AD 14 00 4B 12 00 A2 36 01 00 50 90]
2020-02-06 14:40:02.114 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:04.770 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:04.772 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:04.773 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-02-06 14:40:05.532 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - AF_DATA_REQUEST executed and timed out while waiting for response.
2020-02-06 14:40:05.534 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - Failed to send AF_DATA_REQUEST [attempt 2]
2020-02-06 14:40:07.037 [DEBUG] [31.network.impl.CommandInterfaceImpl] - ->  AF_DATA_REQUEST (Packet: subsystem=null, length=21, apiId=24 01, data=FE 15 24 01 FD FF 00 00 00 00 30 30 1F 0B 25 93 DB AD 14 00 4B 12 00 00 00 AB, checksum=AB, error=false)
```csv
your code goes h2020-02-06 14:40:08.049 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - AF_DATA_REQUEST executed and timed out while waiting for response.
2020-02-06 14:40:08.053 [DEBUG] [.cc2531.network.ZigBeeNetworkManager] - Failed to send AF_DATA_REQUEST [attempt 3]
2020-02-06 14:40:08.055 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=25 state=TX_NAK
2020-02-06 14:40:08.058 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=25, state=TX_NAK, outstanding=1
2020-02-06 14:40:08.067 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=null queueTime=23839, state=FAILED, sendCnt=1, command=NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=25, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]]
2020-02-06 14:40:08.068 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-02-06 14:40:08.071 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: transactionComplete FAILED 2
2020-02-06 14:40:08.071 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressResponse [36A2/0 -> 0000/0, cluster=8001, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=13986, startIndex=0, nwkAddrAssocDevList=[36944]]
2020-02-06 14:40:08.069 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 22 -> TX_NAK == FAILED
2020-02-06 14:40:08.073 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: transactionComplete exceeded retries 1
2020-02-06 14:40:08.074 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: IeeeAddressResponse [36A2/0 -> 0000/0, cluster=8001, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=13986, startIndex=0, nwkAddrAssocDevList=[36944]]
2020-02-06 14:40:08.078 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction terminated: ZigBeeTransaction [ieeeAddress=null queueTime=42925, state=FAILED, sendCnt=1, command=NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=21, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]]
2020-02-06 14:40:08.080 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 14 45 FF A2 36 00 00 80 00 21 00 00 00 93 DB AD 14 00 4B 12 00 A2 36 A7)
2020-02-06 14:40:08.082 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: Added transaction to queue, len=3, transaction=ZigBeeTransaction [ieeeAddress=null queueTime=0, state=WAITING, sendCnt=0, command=NetworkAddressRequest [0000/0 -> FFFF/0, cluster=0000, TID=--, ieeeAddr=00124B0014ADDB93, requestType=0, startIndex=0]]
2020-02-06 14:40:08.083 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=20, apiId=45 FF, data=FE 14 45 FF A2 36 00 00 80 00 21 00 00 00 93 DB AD 14 00 4B 12 00 A2 36 A7, checksum=A7, error=false
2020-02-06 14:40:08.085 [DEBUG] [transaction.ZigBeeTransactionManager] - FFFD/0: Sending ZigBeeTransaction [ieeeAddress=null queueTime=23853, state=WAITING, sendCnt=0, command=NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=26, ieeeAddr=00124B001470001A, requestType=0, startIndex=0]]
2020-02-06 14:40:08.086 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=36A2/0, destinationAddress=0000/0, profile=0000, cluster=8000, addressMode=null, radius=0, apsSecurity=false, apsCounter=--, payload=00 00 93 DB AD 14 00 4B 12 00 A2 36]
2020-02-06 14:40:08.087 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-02-06 14:40:08.089 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: NetworkAddressResponse [36A2/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=13986, startIndex=null, nwkAddrAssocDevList=[]]
2020-02-06 14:40:08.090 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=26, ieeeAddr=00124B001470001A, requestType=0, startIndex=0]
2020-02-06 14:40:08.093 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [36A2/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=13986, startIndex=null, nwkAddrAssocDevList=[]]
2020-02-06 14:40:08.095 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=FFFD/0, profile=0000, cluster=0000, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=31, payload=26 1A 00 70 14 00 4B 12 00 00 00]
2020-02-06 14:40:08.099 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [36A2/0 -> 0000/0, cluster=8000, TID=00, status=SUCCESS, ieeeAddrRemoteDev=00124B0014ADDB93, nwkAddrRemoteDev=13986, startIndex=null, nwkAddrAssocDevList=[]] ZigBeeTransaction [ieeeAddress=null queueTime=23867, state=DISPATCHED, sendCnt=1, command=NetworkAddressRequest [0000/0 -> FFFD/0, cluster=0000, TID=26, ieeeAddr=00124B001470001A, requestType=0, startIndex=0]]
2020-02-06 14:40:08.099 [DEBUG] [31.network.impl.CommandInterfaceImpl] - ->  AF_DATA_REQUEST (Packet: subsystem=null, length=21, apiId=24 01, data=FE 15 24 01 FD FF 00 00 00 00 31 30 1F 0B 26 1A 00 70 14 00 4B 12 00 00 00 26, checksum=26, error=false)
2020-02-06 14:40:08.103 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]ere
What binding are you using? I can think of at least 2 available for OH.
It’s the ZigBee binding (stated in the first message :wink: ).
This indicates some sort of issue where you’re loosing data in the serial connection. Maybe it’s a hardware problem? You don’t say what hardware you are using?
Sorry, I missed that.
I see so many using zigbee2mqtt and calling it Zigbee.
I am using raspberry pi 3b+
I dont understand where the problem lies.I raised issue on ti’s forum as well but they replied this👇
Hi Rakesh,
Try increasing the baud rate to the maximum value of 115200. You will need to contact openHAB for questions concerning their interface. There is nothing to investigate from TI’s perspective since this project uses a Z-STACK-ARCHIVE project with the recommended CC2531 image.
:sob:
Yes…thats true many use zigbee2mqtt…:slightly_smiling_face:
Unfortunately this is one of the problems with this device - it is not supported by TI any more.
Anyway, I don’t think that’s the issue - lots of people use this device with the ZigBee binding. One issue I’ve seen people talking about is the need to use a powered hub with the RPi (Bruce might know more about that).
In any case the TI driver hasn’t changed for a long time and it seems to be a serial issue given what you’ve presented here.
Some USB2 sticks (don’t know about this one) appear as USB3 devices when connected to a USB3 port like the Pi 4. The workaround is to use a powered USB2 hub. The hub makes the stick appear as a proper USB2 device.
I have checked the baurate of the ttyACM0
stty -F /dev/ttyACM0
speed 115200 baud; line = 0;
min = 0; time = 1;
-brkint -icrnl -imaxbel
-opost -onlcr
-isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
and i aslo did the baudrate of cc2531 in the binding paperui to 115200
I did a fresh install of openhabian…installed the binding but still same debug logs :sob:
What is the default baudrate of cc2531emk?
i have looked into documentation of rpi 3b+ the usb ports are usb 2.0
But still i will use external usb2 powerhub.
what serial issue it might be?..Please help i am stuck :sob:
I have used the Pi 3B+ for quite a while with no issues but a different stick with Z-Wave. I did not need to mess with baud rates.
Which stick do you use along with Rpi 3b+?
Will this issue go away if i change the stick?
I am in the US and used a combination Z-Wave & Zigbee stick. I do not know if you are in the same Z-Wave region. I had the HUSBZB-1 but just used the Z-Wave portion.
Ok…I have gone through many posts recently where chris has mentioned ember dongles…how abt ember video funstick
Hi I have went through the Documentation Schneider ULTI Zigee Switches.
1.These switches are Zigbee certified and Zigbee complaint product.
2.These switches are certified for Zigbee and Zigbee Pro Stack Profile
3.These switches are Zigbee HAD(Home Automation Devices)
4.Application Profile: ZigBee Home Automation – 053520r26
The following tables are composed of the detailed questions to be answered, which make up the PICS proforma.
8.1	ZigBee Device Types
Table 2 - Functional device types
Item number	Item description	 Reference	Status	Support
FDT1	Is this device capable of acting as a ZigBee coordinator?	[R1]/2.5.5.5.1
O.1	Yes
FDT2	Is this device capable of acting as a ZigBee router?	[R1]/2.5.5.5.2
O.1	Yes
FDT3	Is this a ZigBee end device?	[R1]/2.5.5.5.3
O.1	No
8.2	ZigBee Stack Profile
Table 3 – ZigBee stack profile
ZSP1	Is the device built on a ZigBee Compliant Platform certified for  ZigBee or ZigBee PRO stack profile [R2]/8.3?
[R11]/8
[R2]/8.3
M	Yes
ZSP2	Does the device implement source binding with a binding table whose number of available entries is greater than or equal to the number of mandatory clusters supported by the device descriptions implemented?	[R3]/5.2
O
By device type 	Yes
ZSP3	Does the device adhere to the polling rate specifications given in [R3]/5.1?
[R3]/5.2
FDT3:M	N/A
ZSP4	Does the device support Trust Center Link Keys including the Default TRUST Center Link Key?	[R3]/5.2	M	Yes
8.3	ZigBee Home Automation general requirements support
Table 4 – HA general requirements support
HAG1	Does the device support the ZigBee Cluster Library PICS as defined in [R14]?
[R14]/8
M	Yes
HAG2	Does the device support at least 16 entries in the group table?	[R3]/6
O
By device type	Yes
HAG3	Does the device support the Scenes cluster as a server?		O	Yes
HAG4	Does the device support at least 16 entries in the scenes table?	[R3]/6
HAG3:M	Yes
HAG5	Does the device support a method for the user to put the device in join mode?		By device type	Yes
HAG6	Does the device support a method for the user to use the device to form a network?		By device type	Yes
HAG7	Does the device support a method for allowing others to join the network?		By device type	Yes
HAG8	Does the device support a method for allowing a user to restore factory settings?		By device type	Yes
HAG9	Does the device support a method to pair devices?		By device type	No
HAG10	Does the device support a method for the user to enable identify mode?		By device type	Yes
8.4	ZigBee Home Automation device description support
Table 5 – HA device description support
HAD1	Is the product programmed as an On/Off Switch?	[R3]/7.3.4
O.1	No
HAD2	Is the product programmed as a Level Control Switch?	[R3]/7.3.5
O.1	No
HAD3	Is the product programmed as an On/Off Output?	[R3]/7.3.6
O.1	No
HAD4	Is the product programmed as Level Controllable Output?	[R3]/7.3.7
O.1	No
HAD5	Is the product programmed as a Scene Selector?	[R3]/7.3.8
O.1	No
HAD6	Is the product programmed as a Configuration Tool?	[R3]/7.3.9
O.1	No
HAD7	Is the product programmed as a Remote Control?	[R3]/7.3.10
O.1	No
HAD8	Is the product programmed as a Combined Interface?	[R3]/7.3.11
O.1	No
HAD9	Is the product programmed as a Range Extender?	[R3]/7.3.12
O.1	No
HAD10	Is the product programmed as a Mains Power Outlet?	[R3]/7.3.13
O.1	No
HAD33
Is the product a Door Lock?	R3/7.3.2	O.1	No
HAD34
Is the product a Door Lock Controller?	R3/7.3.3	O.1	No
HAD32
Is the product a Simple Sensor?	R3	O.1	No
HAD11	Is the product programmed as a On/Off Light?	[R3]/7.4.1
O.1	Yes
HAD12	Is the product programmed as a Dimmable Light?	[R3]/7.4.2
O.1	No
HAD13	Is the product programmed as a Color Dimmable Light?	[R3]/7.4.3
O.1	No
HAD14	Is the product programmed as an On/Off Light Switch?	[R3]/7.4.4
O.1	No
HAD15	Is the product programmed as a Dimmer Switch?	[R3]/7.4.5
O.1	No
HAD16	Is the product programmed as a Color Dimmer Switch?	[R3]/7.4.6
O.1	No
HAD17	Is the product programmed as a Light Sensor?	[R3]/7.4.7
O.1	No
HAD18	Is the product programmed as an Occupancy Sensor?	[R3]/7.4.8
O.1	No
HAD19	Is the product programmed as a Shade?	[R3]/7.5.1
O.1	No
HAD20	Is the product programmed as a Shade Controller?	[R3]/7.5.2
O.1	No
HAD35
Is the product a Window Covering Device	R3/7.5.3	O.1	No
HAD36
Is the product a Window Covering Controller	R3/7.5.4	O.1	No
HAD21	Is the product programmed as a Heating/Cooling Unit?	[R3]/7.6.1
O.1	No
HAD22	Is the product programmed as a Thermostat?	[R3]/7.6.2
O.1	No
HAD23	Is the product programmed as a Temperature Sensor?	[R3]/7.6.3
O.1	No
HAD24	Is the product programmed as a Pump?	[R3]/7.6.4
O.1	No
HAD25	Is the product programmed as a Pump Controller?	[R3]/7.6.5
O.1	No
HAD26	Is the product programmed as a Pressure Sensor?	[R3]/7.6.6
O.1	No
HAD27	Is the product programmed as a Flow Sensor?	[R3]/7.6.7
O.1	No
HAD28	Is the product programmed as a Control and Indicating Equipment?	[R3]/7.7.1
O.1	No
HAD29	Is the product programmed as an IAS Ancillary Control Equipment?	[R3]/7.7.2
O.1	No
HAD30	Is the product programmed as an IAS Zone?	[R3]/7.7.3
O.1	No
HAD31	Is the product programmed as an IAS Warning Device?	[R3]/7.7.4
O.1	No
8.5	Home Automation common clusters
Table 6 – Common cluster ZCL PICS restrictions/requirements
ZCL PICS Item number [R14]	Status	Additional Constraints	Support
BCS1	M		Yes
ICS1	M		Yes
PCCS1	O		No
TCCS1	O		No
ACS1	O		No
SMC1	O
SMS1	O
Table 7 – Common cluster support
HACC1	Are any clusters that receive attribute reports supported as either server or client?	[R2] 7.1
O	Yes
HACC2	Are any manufacturer-specific clusters supported?	[R2] 7.1
O	No
I wanted to know whether these switches can support the Openhab Binding?
And If it supports then can changing the usb stick solve the issue?
From the information, it’s actually unclear what this device is. It seems to state NO to every question - eg is this a switch - no, is this a level control switch - no… Maybe I missed it, but I don’t see any “yes” here so it’s unclear what the device does.
If it’s a simple switch as the name infers, then it should work.
