Become aware of the binding documentation. Hint: How about the section when things do not go as expected?
I did actually post a debug above. The documentation does not even mention the bindings capability of device firmware updates.
I put everything I am aware of now into debug again.
log:set debug org.openhab.binding.zigbee
log:set debug com.zsmartsystems.zigbee
log:set info com.zsmartsystems.zigbee.dongle.xbee.internal.ash
log:set debug com.zsmartsystems.zigbee.app.otaserver.ZclOtaUpgradeServer
this is the full output when I click “Install”:
19:21:17.944 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - null: Update firmware with 0x01020509
19:21:17.946 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'FirmwareUpdateHandler.updateFirmware()' on 'org.openhab.binding.zigbee.handler.ZigBeeThingHandler@58a630be': null
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.updateFirmware(ZigBeeThingHandler.java:906) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_191]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_191]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_191]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_191]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_191]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_191]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_191]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_191]
19:21:17.949 [ERROR] [al.firmware.FirmwareUpdateServiceImpl] - Unexpected exception occurred for firmware update of thing with UID zigbee:device:c890ebfb:7cb03eaa00acf5af and firmware FirmwareImpl [thingTypeUID=zigbee:device, vendor=OSRAM, model=Plug 01, modelRestricted=false, description=null, version=0x01020509, prerequisiteVersion=null, changelog=null, onlineChangelog=null, md5Hash=null, properties={}].
Sorry for missing this - it was only 1 line long and I would have expected a lot more than 1 line.
I think Bruce is talking about the documentation section about debug logs.
I’m very surprised that there is only two lines printed. Unfortunately I can’t really comment further.
its this from the ledvance/osram webpage for the PLUG 01:
zipped with the xml
thats my xml
addtionally. this is the properties from the device I want to update:
Without a larger debug log I really can’t work out what is going on. It looks like some sort of configuration problem, but there’s simply too little information to go on.
Perhaps the documentation should be nodified to say UNFILTERED debug logs are useful for troubleshooting.
I switched now to a Ember Controller (Bitron).
Now the update does work. So it was related to the xbee controller.
I will rebuild now my network and see if also the other issues are gone I had.
Please try with the latest binding as there was a fix made recently that may help with this OTA issue.
@shorty707 It is usually easiest to use the install script.
Zigbee and Z-Wave manual install script - Tutorials & Examples - openHAB Community
Will there be support for OpenHab 3?
Firmwareprovider was added after building it from git. And Log seems to be ok:
2021-12-02 14:43:36.342 [INFO ] [penhab.event.FirmwareStatusInfoEvent] - Firmware status of thing zigbee:device:01382AC2:7cb03eaa00b09e1c changed to UPDATE_EXECUTABLE.The new updatable firmware version is 0x01020509.
But, if i look at the Think i have not the shown line. No Info about currend Version and no update Button.
