Ok, that’s fine. I don’t think this device will work without this (it may not even work with security).
That said, changing the security doesn’t change anything at all - other than when you include this device, so it should have no impact on the rest of your devices. Once the device is included, simply change the security setting back to Security devices only…
I was afraid it might be that and my error somewhere along the line. As it turns out I actually bought 2 (was waiting to see the verdict) , so I’ll try the other one. It might have been since I originally discovered it in SS. My only excuse was that it was not discovering with OH and thought I would have better luck with the PC powering the stick, instead of the pi3 (more oomph). It’s a Zooz stick by the BTW…
My test system has a HUSBZB-1 but I have a Zooz stick on my production system. I believe controller variants do not usually make much of any difference.
Well the good news is the other switch was recognized. The bad news I could not get the first switch excluded via OH and resorted to Simplicity studio. It’s now out of OH, but the switch itself probably retains some memory of that inclusion. I have tried to factory reset, then reinclude to no avail so far.
As a side note, I think the problem I had with inclusion with OH on the first switch was not enough load. On the switch I got working, I temporarily replaced my LEDs with 60W incandescent. I had this problem once before with a V3 version when I only had one bulb. They work okay with LEDs, but need more wattage for inclusion.
