zram1 is where persistence is stored, seems you have an unusual amount of data put there and update
regularly so it stays in (Z)RAM, did you install some DB there like Influx ?
If you have enough RAM you can increase in /etc/ztab but in general that’s a bad idea to combine hence not recommended as also say the docs.
I had rrd4j persistence installed but uninstalled it yesterday. No other persistence binding is installed.
When rrd4j was still installed I got Read only file system errors after a while. I assume because the zram was full.
Also switched to a completely new SD card before making this thread to rule out the possibility of a faulty/degraded SD card.
Could this zram issue also cause the Alexa integration to not work correctly anymore? No new devices get detected by Alexa even though everything is tagged correctly.
Edit:
I just restarted openhab and till 5 minutes it does not seem to fill up anymore.
So I assume that the rrd4j persistence was filling up the zram (but I don’t know what could cause this immense amount of data).
The issue that still remains is that the Alexa integration seems not to work correctly anymore
