All other already exposed items are still in Alexa and work completly without issue but no new devices get found. I tagged them just as I always do via the Web Interface.
What could cause this issue?
Any things that I should check?
What would help to pin point the issue?
If all your Alexa-enabled devices in openHAB aren’t discovered or getting updated:
Check that your server is available ------ Server is available
Look for any relevant errors in your openHAB server logs. -------- No errors in openHAB Log
Check the spelling of your Alexa metadata configuration. It is case sensitive. ----- done through the UI and everything is correct there.
If only new devices aren’t found, make sure your last Alexa-related config changes are valid. ------ Removed the last added item, but even that does not get discovered again.
If necessary, stagger the discovery process by adding a couple devices at a time to isolate the culprit. ------ Also not working.
After I disabled the persistence that was causing the zram filling up, this issue still persists.
What happens if you restart your device? Degraded performance on a Raspberry Pi is not only tied to Zram. Try to disable some of your addons if necessary.
