Hey, I’m trying to install openhab on my nanopi neo plus 2.
I’ve installed the most recent armbian image on it, and got to where I run openhabian-config, and use it to “upgrade system”.
It does it’s thing untill the point where it tries to unpack the zulu java files, which gives the error:
cannot write: No space left on device.
There should be plenty of space left, so I’m not sure what is wrong.
I’ve installed the 32bit version of oracel java 8, but this doesn’t prevent the zulu java installation attempt.
Any idea why it happens?
If I use the regular installation, it fails as mentioned when trying to install the zulu java.
I managed to get it working, by using the manual installation, going through the processes without installing the zulu package - that one keeps failing. Instead I installed the oracle java.
Then finished the installation using the “manual” menu items.
Yes, it’s using the whole sd card.
As mentioned, I managed to get everything installed, using the manual installation.
(except zulu java, used oracle instead).
It’s a 32gb card, and there was plenty of space left.
I also managed to do the installation on the 8gb mmc on the nanopi - no space issues!
Which is why I don’t understand why the zulu java installation would give this error.
As far as I can tell, the error comes up when the installation is trying to extract the downloaded tar.gz file. I could do it manually, but the automated installation fails for some reason.
