Ah, I forgot to mention that I downloaded the jar and placed it in the addon folder. It didn’t install the bundles as I expected. I tried restarting openHAB and rebooting. That’s when I tried to do it manually.
Current status.
4.1.67.Final jar is loaded in the addon folder, but the new bundles aren’t being loaded.
openhab> bundle:list |grep Netty
240 x Active x 80 x 4.1.63.Final x Netty/Buffer
241 x Active x 80 x 4.1.63.Final x Netty/Codec
242 x Active x 80 x 4.1.63.Final x Netty/Codec/HTTP
243 x Active x 80 x 4.1.63.Final x Netty/Codec/Socks
244 x Active x 80 x 4.1.63.Final x Netty/Common
245 x Active x 80 x 4.1.63.Final x Netty/Handler
246 x Active x 80 x 4.1.63.Final x Netty/Handler/Proxy
247 x Active x 80 x 4.1.63.Final x Netty/Resolver
248 x Active x 80 x 4.1.63.Final x Netty/Transport
249 x Active x 80 x 4.1.63.Final x Netty/Transport/Native/Epoll
250 x Active x 80 x 4.1.63.Final x Netty/Transport/Native/Unix/Common
I started this test with my working production system (with the newer ipcamera jar).
Uninstalled the newer jar and went back to the merged ipcamera binding and it kept working which I expected.
Restarted just openHAB, and it still kept working with all cameras enabled which I did not expect to occur.
Full reboot and also a cache clean, still it keeps working.
I then messed with the Netty libs and broke the mqtt binding in the process as it uses Netty.
Because mqtt did not start, changing the order the bindings start in, the issue now returned to my system.
uninstall and reinstall of MQTT binding, fixed the mqtt not starting, but now the zigbee issue remained on my system.
Uninstalled merged ipcamera binding and reboot fixed the zigbee issue.
Dropped back in the newer ipcamera jar into the addons folder, did a reboot and the issue is fixed again.
Decided I needed to double confirm by breaking and fixing twice.
Uninstalled the MQTT binding.
Now that all bindings that use Netty were uninstalled (addons jars do not count) netty was not getting installed automatically so the ipcamera failed to start.
Installed newer Netty jars in console.
Restarted and I could not reproduce the issue with zigbee, all works.
Installed mqtt binding again and updated the netty libs it used to make sure only 1 version is in use and not a mixture.
Restarted multiple times and zigbee keeps working.
I changed multiple things so the result was different.
Conclusion: Nothing conclusive. Appears to make a difference in which order the bindings get installed in or perhaps the order they show up in when you do a bundle:list I think it is worth upgrading Netty as that will place it last in the bundle:list and perhaps you currently have netty getting loaded before the zwave binding or very close to it? Just a theory.
Commands that worked to upgrade netty AFTER first bundle:uninstall xxx using the number from the first column when you do a bundle:list.
bundle:install https://repo1.maven.org/maven2/io/netty/netty-buffer/4.1.67.Final/netty-buffer-4.1.67.Final.jar
bundle:install https://repo1.maven.org/maven2/io/netty/netty-codec/4.1.67.Final/netty-codec-4.1.67.Final.jar
bundle:install https://repo1.maven.org/maven2/io/netty/netty-codec-http/4.1.67.Final/netty-codec-http-4.1.67.Final.jar
bundle:install https://repo1.maven.org/maven2/io/netty/netty-common/4.1.67.Final/netty-common-4.1.67.Final.jar
bundle:install https://repo1.maven.org/maven2/io/netty/netty-handler/4.1.67.Final/netty-handler-4.1.67.Final.jar
bundle:install https://repo1.maven.org/maven2/io/netty/netty-resolver/4.1.67.Final/netty-resolver-4.1.67.Final.jar
bundle:install https://repo1.maven.org/maven2/io/netty/netty-transport/4.1.67.Final/netty-transport-4.1.67.Final.jar
Next ones are for mqtt binding:
bundle:install https://repo1.maven.org/maven2/io/netty/netty-codec-socks/4.1.67.Final/netty-codec-socks-4.1.67.Final.jar
bundle:install https://repo1.maven.org/maven2/io/netty/netty-handler-proxy/4.1.67.Final/netty-handler-proxy-4.1.67.Final.jar
bundle:install https://repo1.maven.org/maven2/io/netty/netty-transport-native-epoll/4.1.67.Final/netty-transport-native-epoll-4.1.67.Final.jar
bundle:install https://repo1.maven.org/maven2/io/netty/netty-transport-native-unix-common/4.1.67.Final/netty-transport-native-unix-common-4.1.67.Final.jar
I would be interested to hear your findings as to where the zwave binding is in relation to the Netty libs and the ipcamera binding when you do bundle:list
Then after upgrading Netty and messing with the order of installing bindings if you get a different result.
Netty is listed prior to any bindings with my non-funcioning system.
First I removed all non-jar bindings and bundles mentioned: zwave, netty, and mqtt. Rebooted and confirmed Netty wasn’t loaded. At this point ipcamera jar is loaded and it’s last in the list. I installed the zwave binding and added the controller. It came online. Netty and serial bundles are now last in the list. The zwave things were autodetected as expected. At this point ipcamera binding is loaded, but no things are created. I rebooted and the zwave things came back as I expected. Then I added my three hikvision camera things successfully and rebooted. Interestingly enough everything came back. At this point I was still without MQTT things, so I reinstalled that binding and rebooted. All Zwave things failed to load.
These bundles are now last:
322 │ Active │ 80 │ 2.27 │ Dagger
323 │ Active │ 80 │ 1.2.2 │ hivemq-mqtt-client
324 │ Active │ 80 │ 4.1.63.Final │ Netty/Codec/Socks
325 │ Active │ 80 │ 4.1.63.Final │ Netty/Handler/Proxy
326 │ Active │ 80 │ 4.1.63.Final │ Netty/Transport/Native/Epoll
327 │ Active │ 80 │ 4.1.63.Final │ Netty/Transport/Native/Unix/Common
328 │ Active │ 80 │ 2.2.19 │ rxjava
329 │ Active │ 80 │ 2.1.2 │ Java Concurrency Tools Core Library
330 │ Active │ 80 │ 3.2.0.202108240413 │ openHAB Add-ons :: Bundles :: MQTT Broker Binding
331 │ Active │ 81 │ 3.2.0.202108240502 │ openHAB Add-ons :: Bundles :: MQTT EspMilightHub
332 │ Active │ 81 │ 3.2.0.202108240502 │ openHAB Add-ons :: Bundles :: MQTT Things and Channels
333 │ Active │ 82 │ 3.2.0.202108240504 │ openHAB Add-ons :: Bundles :: MQTT HomeAssistant Convention
334 │ Active │ 82 │ 3.2.0.202108240504 │ openHAB Add-ons :: Bundles :: MQTT Homie Convention
335 │ Active │ 80 │ 3.2.0.202108240309 │ openHAB Core :: Bundles :: MQTT Transport
336 │ Active │ 80 │ 1.0.3 │ reactive-streams
I uninstalled the MQTT binding again and rebooted. Zwave items returned as expected. I installed MQTT again and rebooted. Zwave items didn’t load again as expected. I manually uninstalled all the Netty bundles from the console and reinstalled the zwave specific ones with the commands you suggested. At this point those 7 are last in the bundle list. I rebooted and the zwave things loaded properly. Next I installed the remaining netty/mqtt bundles and rebooted. The zwave things failed to load, but the mqtt things loaded properly. At this point the binding order (numerically) is ipcamera, zwave, mqtt, netty-zwave, then netty-mqtt. I removed the 4 netty-mqtt bundles and rebooted. Zwave items returned as expected. I removed the zwave-netty bundles and rebooted. I then loaded the 4 mqtt-netty bundles and rebooted. Oddly all zwave items came back, but the MQTT and ipcameras remained offline. The only bundles missing at this point are the 7 netty-zwave bundles. To confirm the ipcamera version is 3.2.0.202108281202 (I thought this version removed netty from ipcamera). Next I reinstalled the 7 netty-zwave bundles and rebooted. Shockingly the system returned fully functioning. zwave, mqtt, and cameras. The final bundle order is:
START LEVEL 100 , List Threshold: 50
ID │ State │ Lvl │ Version │ Name
31 │ Active │ 80 │ 2.12.3 │ Jackson-annotations
32 │ Active │ 80 │ 2.12.3 │ Jackson-core
33 │ Active │ 80 │ 2.12.3 │ jackson-databind
34 │ Active │ 80 │ 2.12.3 │ Jackson-dataformat-YAML
35 │ Active │ 80 │ 2.12.3 │ Jackson datatype: JSR310
36 │ Active │ 80 │ 6.2.4 │ Woodstox
37 │ Active │ 80 │ 2.8.6 │ Gson
38 │ Active │ 80 │ 27.1.0.jre │ Guava: Google Core Libraries for Java
39 │ Active │ 80 │ 30.1.0.jre │ Guava: Google Core Libraries for Java
40 │ Active │ 80 │ 1.0.1 │ Guava InternalFutureFailureAccess and InternalFutures
41 │ Active │ 80 │ 3.0.0.v201312141243 │ Google Guice (No AOP)
43 │ Active │ 80 │ 4.8.35.v20190528-1517 │ ClassGraph
44 │ Active │ 80 │ 2.1.9 │ swagger-annotations
45 │ Active │ 80 │ 2.1.9 │ swagger-core
46 │ Active │ 80 │ 2.1.9 │ swagger-integration
47 │ Active │ 80 │ 2.1.9 │ swagger-jaxrs2
48 │ Active │ 80 │ 2.1.9 │ swagger-models
49 │ Active │ 80 │ 2.0.0 │ Jakarta Annotations API
50 │ Active │ 80 │ 2.0.0 │ Jakarta Dependency Injection
51 │ Active │ 80 │ 2.0.2 │ Jakarta Bean Validation API
53 │ Active │ 80 │ 2.3.3 │ Jakarta XML Web Services API
56 │ Active │ 80 │ 3.5.7 │ JmDNS
57 │ Active │ 80 │ 2.1.2 │ Units of Measurement API
59 │ Active │ 80 │ 0.5.10 │ Jollyday
60 │ Active │ 80 │ 3.2.0.v201101311130 │ ANTLR Runtime
61 │ Active │ 80 │ 1.2.2 │ org.apache.aries.component-dsl.component-dsl
62 │ Active │ 80 │ 1.0.1 │ Apache Aries JAX-RS Specification API
63 │ Active │ 80 │ 2.0.0 │ Apache Aries JAX-RS Whiteboard
65 │ Active │ 80 │ 3.12.0 │ Apache Commons Lang
66 │ Active │ 80 │ 3.4.3 │ Apache CXF Core
67 │ Active │ 80 │ 3.4.3 │ Apache CXF Runtime JAX-RS Frontend
68 │ Active │ 80 │ 3.4.3 │ Apache CXF JAX-RS Client
69 │ Active │ 80 │ 3.4.3 │ Apache CXF JAX-RS Server-Side Events Support
70 │ Active │ 80 │ 3.4.3 │ Apache CXF Runtime Security functionality
71 │ Active │ 80 │ 3.4.3 │ Apache CXF Runtime HTTP Transport
80 │ Active │ 80 │ 4.3.2 │ Apache Karaf :: OSGi Services :: Event
91 │ Active │ 80 │ 1.0.0.2 │ Apache ServiceMix :: Bundles :: javax.inject
99 │ Active │ 80 │ 2.2.5 │ XmlSchema Core
100 │ Active │ 80 │ 4.19.0 │ Apache XBean :: OSGI Bundle Utilities
101 │ Active │ 80 │ 4.19.0 │ Apache XBean :: Classpath Resource Finder
102 │ Active │ 80 │ 0.7.7 │ jose4j
103 │ Active │ 80 │ 2.17.0.v20190920-0401 │ EMF Common
104 │ Active │ 80 │ 2.20.0.v20190920-0401 │ EMF Ecore
105 │ Active │ 80 │ 2.14.0.v20190528-0725 │ EMF Change Model
106 │ Active │ 80 │ 2.16.0.v20190528-0725 │ EMF XML/XMI Persistence
107 │ Active │ 80 │ 3.13.0.v20200828-1034 │ Common Eclipse Runtime
136 │ Active │ 80 │ 0.10.0.v20201105-1103 │ org.eclipse.lsp4j
137 │ Active │ 80 │ 0.10.0.v20201105-1103 │ org.eclipse.lsp4j.jsonrpc
138 │ Active │ 80 │ 2.25.0.v20210301-0821 │ Xtend Runtime Library
139 │ Active │ 80 │ 2.25.0.v20210301-0821 │ Xtend Macro Interfaces
140 │ Active │ 80 │ 2.25.0.v20210301-0843 │ Xtext
141 │ Active │ 80 │ 2.25.0.v20210301-0909 │ Xtext Common Types
142 │ Active │ 80 │ 2.25.0.v20210301-0843 │ Xtext IDE Core
143 │ Active │ 80 │ 2.25.0.v20210301-0843 │ Xtext Utility
144 │ Active │ 80 │ 2.25.0.v20210301-0909 │ Xbase Model
145 │ Active │ 80 │ 2.25.0.v20210301-0909 │ Xbase Generic IDE Services
146 │ Active │ 80 │ 2.25.0.v20210301-0821 │ Xbase Runtime Library
150 │ Active │ 80 │ 9.1.0 │ org.objectweb.asm.commons
151 │ Active │ 80 │ 9.1.0 │ org.objectweb.asm.tree
152 │ Active │ 80 │ 9.1.0 │ org.objectweb.asm.tree.analysis
153 │ Active │ 80 │ 9.1.0 │ org.objectweb.asm.util
154 │ Active │ 80 │ 3.2.0.202108240301 │ openHAB Core :: Bundles :: Core
155 │ Active │ 80 │ 3.2.0.202108240307 │ openHAB Core :: Bundles :: Audio
156 │ Active │ 80 │ 3.2.0.202108240304 │ openHAB Core :: Bundles :: JAAS Authentication
157 │ Active │ 80 │ 3.2.0.202108240306 │ openHAB Core :: Bundles :: OAuth2Client
158 │ Active │ 80 │ 3.2.0.202108240311 │ openHAB Core :: Bundles :: Automation
159 │ Active │ 80 │ 3.2.0.202108240318 │ openHAB Core :: Bundles :: Automation Media Modules
160 │ Active │ 80 │ 3.2.0.202108240314 │ openHAB Core :: Bundles :: Automation Script Modules
161 │ Active │ 80 │ 3.2.0.202108240318 │ openHAB Core :: Bundles :: Automation Script RuleSupport
162 │ Active │ 80 │ 3.2.0.202108240315 │ openHAB Core :: Bundles :: Automation REST API
163 │ Active │ 80 │ 3.2.0.202108240310 │ openHAB Core :: Bundles :: Binding XML
164 │ Active │ 80 │ 3.2.0.202108240306 │ openHAB Core :: Bundles :: Configuration Core
165 │ Active │ 80 │ 3.2.0.202108240310 │ openHAB Core :: Bundles :: Configuration Discovery
166 │ Active │ 80 │ 3.2.0.202108240316 │ openHAB Core :: Bundles :: Configuration mDNS Discovery
167 │ Active │ 80 │ 3.2.0.202108240309 │ openHAB Core :: Bundles :: Configuration Dispatcher
168 │ Active │ 75 │ 3.2.0.202108240307 │ openHAB Core :: Bundles :: Configuration XML
169 │ Active │ 80 │ 3.2.0.202108240307 │ openHAB Core :: Bundles :: Ephemeris
170 │ Active │ 80 │ 3.2.0.202108240307 │ openHAB Core :: Bundles :: ID
171 │ Active │ 80 │ 3.2.0.202108240303 │ openHAB Core :: Bundles :: Console
172 │ Active │ 80 │ 3.2.0.202108240305 │ openHAB Core :: Bundles :: Console for OSGi runtime Karaf
173 │ Active │ 80 │ 3.2.0.202108240301 │ openHAB Core :: Bundles :: HTTP Interface
174 │ Active │ 80 │ 3.2.0.202108240304 │ openHAB Core :: Bundles :: HTTP Interface Authentication
176 │ Active │ 80 │ 3.2.0.202108240314 │ openHAB Core :: Bundles :: Monitor
177 │ Active │ 80 │ 3.2.0.202108240303 │ openHAB Core :: Bundles :: Network I/O
178 │ Active │ 80 │ 3.2.0.202108240303 │ openHAB Core :: Bundles :: REST Interface
179 │ Active │ 80 │ 3.2.0.202108240310 │ openHAB Core :: Bundles :: Audio REST Interface
180 │ Active │ 80 │ 3.2.0.202108240309 │ openHAB Core :: Bundles :: Authentication Support for the REST Interface
181 │ Active │ 80 │ 3.2.0.202108240314 │ openHAB Core :: Bundles :: REST Interface :: Core
182 │ Active │ 80 │ 3.2.0.202108240316 │ openHAB Core :: Bundles :: REST mDNS Announcer
183 │ Active │ 80 │ 3.2.0.202108240319 │ openHAB Core :: Bundles :: Sitemap REST Interface
184 │ Active │ 80 │ 3.2.0.202108240310 │ openHAB Core :: Bundles :: SSE Interface
185 │ Active │ 80 │ 3.2.0.202108240305 │ openHAB Core :: Bundles :: REST Interface :: Swagger 1
186 │ Active │ 80 │ 3.2.0.202108240319 │ openHAB Core :: Bundles :: UI REST Interface
187 │ Active │ 80 │ 3.2.0.202108240313 │ openHAB Core :: Bundles :: Voice REST Interface
188 │ Active │ 80 │ 3.2.0.202108240313 │ openHAB Core :: Bundles :: mDNS Service
189 │ Active │ 80 │ 3.2.0.202108240307 │ openHAB Core :: Bundles :: Karaf Integration
190 │ Active │ 80 │ 3.2.0.202108240309 │ openHAB Core :: Bundles :: Model Core
191 │ Active │ 80 │ 3.2.0.202108240312 │ openHAB Core :: Bundles :: Model Items
192 │ Active │ 80 │ 3.2.0.202108240316 │ openHAB Core :: Bundles :: Model Item IDE
193 │ Active │ 80 │ 3.2.0.202108240316 │ openHAB Core :: Bundles :: Model Items Runtime
194 │ Active │ 80 │ 3.2.0.202108240322 │ openHAB Core :: Bundles :: Language Server
195 │ Active │ 80 │ 3.2.0.202108240313 │ openHAB Core :: Bundles :: Model Persistence
196 │ Active │ 80 │ 3.2.0.202108240315 │ openHAB Core :: Bundles :: Model Persistence IDE
197 │ Active │ 80 │ 3.2.0.202108240315 │ openHAB Core :: Bundles :: Model Persistence Runtime
198 │ Active │ 80 │ 3.2.0.202108240320 │ openHAB Core :: Bundles :: Model Rules
199 │ Active │ 80 │ 3.2.0.202108240321 │ openHAB Core :: Bundles :: Model Rule IDE
200 │ Active │ 80 │ 3.2.0.202108240321 │ openHAB Core :: Bundles :: Model Rules Runtime
201 │ Active │ 80 │ 3.2.0.202108240317 │ openHAB Core :: Bundles :: Model Script
202 │ Active │ 80 │ 3.2.0.202108240320 │ openHAB Core :: Bundles :: Model Script IDE
203 │ Active │ 80 │ 3.2.0.202108240320 │ openHAB Core :: Bundles :: Model Script Runtime
204 │ Active │ 80 │ 3.2.0.202108240313 │ openHAB Core :: Bundles :: Model Sitemap
205 │ Active │ 80 │ 3.2.0.202108240317 │ openHAB Core :: Bundles :: Model Sitemap IDE
206 │ Active │ 80 │ 3.2.0.202108240318 │ openHAB Core :: Bundles :: Model Sitemap Runtime
207 │ Active │ 80 │ 3.2.0.202108240317 │ openHAB Core :: Bundles :: Model Thing
208 │ Active │ 80 │ 3.2.0.202108240318 │ openHAB Core :: Bundles :: Model Thing IDE
209 │ Active │ 80 │ 3.2.0.202108240319 │ openHAB Core :: Bundles :: Model Thing Runtime
210 │ Active │ 80 │ 3.2.0.202108240308 │ openHAB Core :: Bundles :: Persistence
211 │ Active │ 80 │ 3.2.0.202108240304 │ openHAB Core :: Bundles :: Semantics
212 │ Active │ 80 │ 3.2.0.202108240310 │ openHAB Core :: Bundles :: JSON Storage
213 │ Active │ 80 │ 3.2.0.202108240307 │ openHAB Core :: Bundles :: Thing
214 │ Active │ 75 │ 3.2.0.202108240311 │ openHAB Core :: Bundles :: Thing XML
215 │ Active │ 80 │ 3.2.0.202108240308 │ openHAB Core :: Bundles :: Transformation Service
216 │ Active │ 80 │ 3.2.0.202108240317 │ openHAB Core :: Bundles :: UI
217 │ Active │ 80 │ 3.2.0.202108240319 │ openHAB Core :: Bundles :: UI Icon Support
218 │ Active │ 80 │ 3.2.0.202108240310 │ openHAB Core :: Bundles :: Voice
219 │ Active │ 80 │ 3.2.0.202107240911 │ openHAB UI :: Bundles :: Main UI
226 │ Active │ 80 │ 1.0.0.201802012106 │ org.osgi:org.osgi.service.jaxrs
227 │ Active │ 80 │ 1.5.0 │ ThreeTen-Extra
228 │ Active │ 80 │ 1.27.0 │ SnakeYAML
229 │ Active │ 80 │ 2.0.1 │ SI Units
230 │ Active │ 80 │ 2.0.1 │ SI Quantities
231 │ Active │ 80 │ 4.2.1 │ Stax2 API
232 │ Active │ 80 │ 2.1.2 │ Units of Measurement Reference Implementation
233 │ Active │ 80 │ 2.1.0 │ Units of Measurement Common Library for Java
234 │ Active │ 80 │ 1.4.17 │ XStream Core
238 │ Active │ 80 │ 5.5.0 │ jna
239 │ Active │ 80 │ 5.5.0 │ jna-platform
252 │ Active │ 80 │ 1.0.0 │ IO.Socket Engine Client
253 │ Active │ 80 │ 1.0.0 │ IO.Socket Socket Client
254 │ Active │ 80 │ 20180813.0.0 │ JSON in Java
256 │ Active │ 80 │ 3.7.2 │ Apache Commons Net
257 │ Active │ 80 │ 3.8.1.1 │ Apache ServiceMix :: Bundles :: okhttp
258 │ Active │ 80 │ 1.13.0.1 │ Apache ServiceMix :: Bundles :: okio
260 │ Active │ 80 │ 2.6.0 │ JUPnP Library
261 │ Active │ 80 │ 3.2.0.202108240336 │ openHAB Add-ons :: Bundles :: Amazon Echo Control Binding
262 │ Active │ 80 │ 3.2.0.202108240336 │ openHAB Add-ons :: Bundles :: Ambient Weather Binding
263 │ Active │ 80 │ 3.2.0.202108240337 │ openHAB Add-ons :: Bundles :: Astro Binding
264 │ Active │ 80 │ 3.2.0.202108240350 │ openHAB Add-ons :: Bundles :: Exec Binding
265 │ Active │ 80 │ 3.2.0.202108240357 │ openHAB Add-ons :: Bundles :: HTTP Binding
266 │ Active │ 80 │ 3.2.0.202108240359 │ openHAB Add-ons :: Bundles :: iCloud Binding
273 │ Active │ 80 │ 3.2.0.202108240419 │ openHAB Add-ons :: Bundles :: Onkyo Binding
274 │ Active │ 80 │ 3.2.0.202108240425 │ openHAB Add-ons :: Bundles :: Pushover Binding
275 │ Active │ 80 │ 3.2.0.202108240428 │ openHAB Add-ons :: Bundles :: Russound Binding
276 │ Active │ 80 │ 3.2.0.202108240436 │ openHAB Add-ons :: Bundles :: Systeminfo Binding
277 │ Active │ 80 │ 3.2.0.202108240443 │ openHAB Add-ons :: Bundles :: WeatherCompany Binding
279 │ Active │ 80 │ 3.2.0.202108240314 │ openHAB Core :: Bundles :: Configuration UPnP Discovery
287 │ Active │ 80 │ 3.2.0.202108240305 │ openHAB Core :: Bundles :: UPnP Transport
288 │ Active │ 80 │ 3.2.0.202108240447 │ openHAB Add-ons :: Bundles :: IO :: Homekit
289 │ Active │ 80 │ 3.2.0.202108240448 │ openHAB Add-ons :: Bundles :: IO :: openHAB Cloud Connector
290 │ Active │ 80 │ 3.2.0.202108240449 │ openHAB Add-ons :: Bundles :: Persistence Service :: InfluxDB
291 │ Active │ 80 │ 3.2.0.202108240450 │ openHAB Add-ons :: Bundles :: Persistence Service :: MapDB
292 │ Active │ 80 │ 3.2.0.202108240451 │ openHAB Add-ons :: Bundles :: Persistence Service :: RRD4j
293 │ Active │ 75 │ 3.2.0.202108240451 │ openHAB Add-ons :: Bundles :: Transformation Service :: Exec
294 │ Active │ 75 │ 3.2.0.202108240452 │ openHAB Add-ons :: Bundles :: Transformation Service :: JavaScript
295 │ Active │ 75 │ 3.2.0.202108240452 │ openHAB Add-ons :: Bundles :: Transformation Service :: JSonPath
296 │ Active │ 75 │ 3.2.0.202108240353 │ openHAB Add-ons :: Bundles :: Transformation Service :: Map
297 │ Active │ 75 │ 3.2.0.202108240452 │ openHAB Add-ons :: Bundles :: Transformation Service :: RegEx
298 │ Active │ 75 │ 3.2.0.202108240453 │ openHAB Add-ons :: Bundles :: Transformation Service :: Scale
299 │ Active │ 75 │ 3.2.0.202108240453 │ openHAB Add-ons :: Bundles :: Transformation Service :: XPath
300 │ Active │ 75 │ 3.2.0.202108240453 │ openHAB Add-ons :: Bundles :: Transformation Service :: Xslt
301 │ Active │ 80 │ 3.2.0.202107240906 │ openHAB UI :: Bundles :: Basic UI
302 │ Active │ 80 │ 3.2.0.202107240906 │ openHAB UI :: Bundles :: HABPanel UI
303 │ Active │ 80 │ 3.2.0.202107240907 │ openHAB UI :: Bundles :: Icon Set :: Classic
305 │ Active │ 80 │ 3.2.0.202108281202 │ openHAB Add-ons :: Bundles :: IpCamera Binding
314 │ Active │ 80 │ 5.2.1 │ nrjavaserial
315 │ Active │ 80 │ 3.2.0.202108230349 │ openHAB Add-ons :: Bundles :: ZWave Binding
316 │ Active │ 80 │ 3.2.0.202108240314 │ openHAB Core :: Bundles :: Configuration USB-Serial Discovery
317 │ Active │ 80 │ 3.2.0.202108240318 │ openHAB Core :: Bundles :: Configuration USB-Serial Discovery for Linux using sysfs scanning
318 │ Active │ 80 │ 3.2.0.202108240309 │ openHAB Core :: Bundles :: Configuration Serial
319 │ Active │ 80 │ 3.2.0.202108240305 │ openHAB Core :: Bundles :: Serial Transport
320 │ Active │ 80 │ 3.2.0.202108240306 │ openHAB Core :: Bundles :: Serial Transport for RXTX
321 │ Active │ 80 │ 3.2.0.202108240306 │ openHAB Core :: Bundles :: Serial Transport for RFC2217
337 │ Active │ 80 │ 2.27 │ Dagger
338 │ Active │ 80 │ 1.2.2 │ hivemq-mqtt-client
343 │ Active │ 80 │ 2.2.19 │ rxjava
344 │ Active │ 80 │ 2.1.2 │ Java Concurrency Tools Core Library
345 │ Active │ 80 │ 3.2.0.202108240413 │ openHAB Add-ons :: Bundles :: MQTT Broker Binding
346 │ Active │ 81 │ 3.2.0.202108240502 │ openHAB Add-ons :: Bundles :: MQTT EspMilightHub
347 │ Active │ 81 │ 3.2.0.202108240502 │ openHAB Add-ons :: Bundles :: MQTT Things and Channels
348 │ Active │ 82 │ 3.2.0.202108240504 │ openHAB Add-ons :: Bundles :: MQTT HomeAssistant Convention
349 │ Active │ 82 │ 3.2.0.202108240504 │ openHAB Add-ons :: Bundles :: MQTT Homie Convention
350 │ Active │ 80 │ 3.2.0.202108240309 │ openHAB Core :: Bundles :: MQTT Transport
351 │ Active │ 80 │ 1.0.3 │ reactive-streams
363 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Codec/Socks
364 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Handler/Proxy
365 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Transport/Native/Epoll
366 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Transport/Native/Unix/Common
367 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Buffer
368 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Codec
369 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Codec/HTTP
370 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Common
371 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Handler
372 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Resolver
373 │ Resolved │ 80 │ 4.1.67.Final │ Netty/Transport
The only thing different that I can is the ipcamera jar, netty version, and binding order. I’ll let this run for a bit and reboot and restart several times. I can’t leave it this way as I’m travelling this weeked, but I can test further on Monday if needed.
That version is old as I am very busy working on it at the moment, I have uploaded a newer one at the github link. The version contains the date when it was compiled in it.
Netty is still used in the ipcamera binding. Moving forward the Netty is used only for talking back and forth to the camera, the difference is that it is no longer used for serving the files out and is why you need to use new URLS to get anything from the binding after moving to that version.
Netty is used for the ONVIF comms, so if you setup the cameras as generic and supply all the urls manually, then this would halve the amount of lines of code that use Netty. It may cause things to change or it may have no effect. I think this is something worth trying to see the effect as ONVIF is very chatty at startup.
It would be interesting to play with the console command bundle:start-level to change the start level of the netty and ipcamera to 100 to see what happens.
I wont be spending much more time on this as my system is fixed and I did narrow the root of this back to when the serial port is opened. Hopefully an updated serial library will fix this soon, but until then at least we have some potential work arounds.
I’m running the latest SNAPSHOT version plus the ipcamera binding on github without issue. I’m not sure what has change, but it’s working much better now. I’ll continue to test it to see if the issue is truly fixed on my system or not.
It would be interesting if people posted what the Open file descriptors is reported as being when they do a shell:info command in the openHAB Karaf console, and also what version of the binding they are using.
Upgraded to the nightly snapshot, this looks way better and its the first time in months i have been able to restart and have both the zwave and ipcamera bindings active at the same time (i had to disable ipcamera at reboot to let the zwave serial connection start before). Nice work!
JVM
Java Virtual Machine OpenJDK 64-Bit Server VM version 11.0.11+9-LTS
Version 11.0.11
Vendor Azul Systems, Inc.
Pid 483
Uptime 1 hour 5 minutes
Process CPU time 12 minutes
Process CPU load 0.00
System CPU load 0.67
Open file descriptors 857
Max file descriptors 1,048,576
Total compile time 4 minutes
