I recently updated my Openhab installation after abandoning it for several months. Since then my Popp 10 Year Smoke detectors are recognized as Popps Solar Powered Outdoor Siren. There are several topics which actually seem to describe the opposite issue than mine:
https://community.openhab.org/t/popp-smoke-detector-and-siren/8316
It seems that my device returns Id 0004:0002 which is identical to that of the siren in the database. I would update the database myself, but I am not quite sure of how to proceed to avoid conflicts with the current devices in the database.
According to Habmin device info the Firmware version is 1.1
Here is the XML File generated by the binding to this ticket:
<node>
<homeId>0xed228a36</homeId>
<nodeId>7</nodeId>
<version>4</version>
<manufacturer>0x154</manufacturer>
<deviceId>0x2</deviceId>
<deviceType>0x4</deviceType>
<listening>false</listening>
<frequentlyListening>true</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_SECURITY</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_MARK</commandClass>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map"/>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<COMMAND__CLASS__BATTERY>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
<batteryLevel>100</batteryLevel>
<batteryLow>false</batteryLow>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__SECURITY>
</COMMAND__CLASS__SECURITY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<versionSupported>2</versionSupported>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_LISTENING</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<version>2</version>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>4.5</protocolVersion>
<applicationVersion>1.1</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>3</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>340</deviceManufacturer>
<deviceType>4</deviceType>
<deviceId>2</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>6</int>
<int>8</int>
</nodeNeighbors>
<lastReceived>2019-01-24 19:56:58.400 UTC</lastReceived>
</node>
I would appreciate if anyone has an idea to resolve this issue.
