Thanks Bob … not really sure what I’m looking for but it appears that the USB0 (and USB1) registered.
here’s the log:
openhabian@openhabian:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.15.32-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP Thu Mar 31 19:39:41 BST 2022
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] random: fast init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003e5fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0, zone HighMem: 512 pages in unavailable ranges
[ 0.000000] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
[ 0.000000] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1023808
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:46:06:EB vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=ttyS0,115200 console=tty1 root=PARTUUID=51a6517f-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000024890000-0x0000000028890000] (64MB)
[ 0.000000] Memory: 3914716K/4102144K available (10240K kernel code, 1390K rwdata, 3292K rodata, 2048K init, 590K bss, 121892K reserved, 65536K cma-reserved, 3315712K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 35355 entries in 104 pages
[ 0.000000] ftrace: allocated 104 pages with 3 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x574/0x758 with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000022] Switching to timer-based delay loop, resolution 18ns
[ 0.000309] Console: colour dummy device 80x30
[ 0.001032] printk: console [tty1] enabled
[ 0.001109] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001162] pid_max: default: 32768 minimum: 301
[ 0.001315] LSM: Security Framework initializing
[ 0.001468] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001515] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003077] cgroup: Disabling memory control group subsystem
[ 0.003330] CPU: Testing write buffer coherency: ok
[ 0.003407] CPU0: Spectre BHB: using loop workaround
[ 0.003853] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005080] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005303] rcu: Hierarchical SRCU implementation.
[ 0.006243] smp: Bringing up secondary CPUs ...
[ 0.007419] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007436] CPU1: Spectre BHB: using loop workaround
[ 0.008756] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008774] CPU2: Spectre BHB: using loop workaround
[ 0.010105] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010122] CPU3: Spectre BHB: using loop workaround
[ 0.010307] smp: Brought up 1 node, 4 CPUs
[ 0.010343] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.010377] CPU: All CPU(s) started in HYP mode.
[ 0.010403] CPU: Virtualization extensions available.
[ 0.011195] devtmpfs: initialized
[ 0.026305] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026542] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026598] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.028546] pinctrl core: initialized pinctrl subsystem
[ 0.029843] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.034241] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.035025] audit: initializing netlink subsys (disabled)
[ 0.035294] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.035891] thermal_sys: Registered thermal governor 'step_wise'
[ 0.036623] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.036681] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.037079] Serial: AMBA PL011 UART driver
[ 0.047563] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.070028] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:19:43, variant start_cd
[ 0.080039] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
[ 0.137589] Kprobes globally optimized
[ 0.143117] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.147502] vgaarb: loaded
[ 0.147965] SCSI subsystem initialized
[ 0.148206] usbcore: registered new interface driver usbfs
[ 0.148284] usbcore: registered new interface driver hub
[ 0.148372] usbcore: registered new device driver usb
[ 0.148722] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.149233] pps_core: LinuxPPS API ver. 1 registered
[ 0.149264] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.149314] PTP clock support registered
[ 0.151428] clocksource: Switched to clocksource arch_sys_counter
[ 0.232141] VFS: Disk quotas dquot_6.6.0
[ 0.232268] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.232466] FS-Cache: Loaded
[ 0.232662] CacheFiles: Loaded
[ 0.241809] NET: Registered PF_INET protocol family
[ 0.242072] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.243678] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.243736] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.243824] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.243914] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.244089] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.244146] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.244420] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.245457] RPC: Registered named UNIX socket transport module.
[ 0.245493] RPC: Registered udp transport module.
[ 0.245521] RPC: Registered tcp transport module.
[ 0.245548] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.245584] PCI: CLS 0 bytes, default 64
[ 1.103260] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.105613] Initialise system trusted keyrings
[ 1.105880] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.114868] zbud: loaded
[ 1.116828] FS-Cache: Netfs 'nfs' registered for caching
[ 1.117726] NFS: Registering the id_resolver key type
[ 1.117784] Key type id_resolver registered
[ 1.117813] Key type id_legacy registered
[ 1.117971] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.118003] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.119101] Key type asymmetric registered
[ 1.119134] Asymmetric key parser 'x509' registered
[ 1.119378] bounce: pool size: 64 pages
[ 1.119454] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.119709] io scheduler mq-deadline registered
[ 1.119742] io scheduler kyber registered
[ 1.128254] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.128317] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.128432] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.128545] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.183534] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.183937] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.183974] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.184010] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.184122] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.184384] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.188100] PCI: bus0: Fast back to back transfers disabled
[ 1.188453] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.188598] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.189049] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.192794] PCI: bus1: Fast back to back transfers disabled
[ 1.192869] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.192911] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.193016] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.193055] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.193491] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.193729] pcieport 0000:00:00.0: PME: Signaling with IRQ 57
[ 1.195174] bcm2708_fb soc:fb: Unable to determine number of FBs. Disabling driver.
[ 1.195215] bcm2708_fb: probe of soc:fb failed with error -2
[ 1.203340] iproc-rng200 fe104000.rng: hwrng registered
[ 1.203673] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[ 1.205074] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.218135] brd: module loaded
[ 1.228604] loop: module loaded
[ 1.229310] Loading iSCSI transport class v2.0-870.
[ 1.234400] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.341593] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.342825] usbcore: registered new interface driver r8152
[ 1.342912] usbcore: registered new interface driver lan78xx
[ 1.342990] usbcore: registered new interface driver smsc95xx
[ 1.344608] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.344792] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.344843] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.350577] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
[ 1.351993] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.352041] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.352080] usb usb1: Product: xHCI Host Controller
[ 1.352110] usb usb1: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
[ 1.352141] usb usb1: SerialNumber: 0000:01:00.0
[ 1.352928] hub 1-0:1.0: USB hub found
[ 1.353042] hub 1-0:1.0: 1 port detected
[ 1.353737] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.353781] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.353826] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.354331] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.354375] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.354413] usb usb2: Product: xHCI Host Controller
[ 1.354442] usb usb2: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
[ 1.354473] usb usb2: SerialNumber: 0000:01:00.0
[ 1.355221] hub 2-0:1.0: USB hub found
[ 1.355332] hub 2-0:1.0: 4 ports detected
[ 1.357052] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.357364] dwc_otg: FIQ enabled
[ 1.357378] dwc_otg: NAK holdoff enabled
[ 1.357391] dwc_otg: FIQ split-transaction FSM enabled
[ 1.357409] Module dwc_common_port init
[ 1.357855] usbcore: registered new interface driver uas
[ 1.357980] usbcore: registered new interface driver usb-storage
[ 1.358239] mousedev: PS/2 mouse device common for all mice
[ 1.362896] sdhci: Secure Digital Host Controller Interface driver
[ 1.362933] sdhci: Copyright(c) Pierre Ossman
[ 1.363541] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.367156] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.367626] hid: raw HID events driver (C) Jiri Kosina
[ 1.367813] usbcore: registered new interface driver usbhid
[ 1.367845] usbhid: USB HID core driver
[ 1.373863] Initializing XFRM netlink socket
[ 1.373943] NET: Registered PF_PACKET protocol family
[ 1.374074] Key type dns_resolver registered
[ 1.374497] Registering SWP/SWPB emulation handler
[ 1.375313] registered taskstats version 1
[ 1.375357] Loading compiled-in X.509 certificates
[ 1.376185] Key type ._fscrypt registered
[ 1.376217] Key type .fscrypt registered
[ 1.376244] Key type fscrypt-provisioning registered
[ 1.387960] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.388295] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.388437] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 32, base_baud = 0) is a PL011 rev2
[ 1.397767] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.398303] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.399620] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.399659] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.430842] of_cfs_init
[ 1.431141] of_cfs_init: OK
[ 1.466659] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.467078] Waiting for root device PARTUUID=51a6517f-02...
[ 1.518514] mmc1: new high speed SDIO card at address 0001
[ 1.566054] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 1.567032] mmcblk0: mmc0:0001 GB1QT 29.8 GiB
[ 1.570203] mmcblk0: p1 p2
[ 1.570776] mmcblk0: mmc0:0001 GB1QT 29.8 GiB
[ 1.591362] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.591552] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.596862] devtmpfs: mounted
[ 1.608173] Freeing unused kernel image (initmem) memory: 2048K
[ 1.621763] Run /sbin/init as init process
[ 1.621795] with arguments:
[ 1.621808] /sbin/init
[ 1.621821] with environment:
[ 1.621833] HOME=/
[ 1.621846] TERM=linux
[ 1.641474] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.824417] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.824477] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.824515] usb 1-1: Product: USB2.0 Hub
[ 1.827243] hub 1-1:1.0: USB hub found
[ 1.827602] hub 1-1:1.0: 4 ports detected
[ 1.971546] systemd[1]: System time before build time, advancing clock.
[ 2.080220] NET: Registered PF_INET6 protocol family
[ 2.081881] Segment Routing with IPv6
[ 2.081942] In-situ OAM (IOAM) with IPv6
[ 2.139972] systemd[1]: systemd 247.3-7+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.140926] systemd[1]: Detected architecture arm.
[ 2.149320] systemd[1]: Set hostname to <openhabian>.
[ 2.171491] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[ 2.308942] usb 1-1.4: New USB device found, idVendor=10c4, idProduct=8a2a, bcdDevice= 1.00
[ 2.309014] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 2.309055] usb 1-1.4: Product: HubZ Smart Home Controller
[ 2.309089] usb 1-1.4: Manufacturer: Silicon Labs
[ 2.309119] usb 1-1.4: SerialNumber: C130049D
[ 3.074960] systemd[1]: Queued start job for default target Multi-User System.
[ 3.076705] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.080889] systemd[1]: Created slice system-modprobe.slice.
[ 3.081758] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.082861] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.083348] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.084178] systemd[1]: Created slice User and Session Slice.
[ 3.085010] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.085782] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.087255] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.087898] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.088596] systemd[1]: Reached target Network (Pre).
[ 3.089077] systemd[1]: Reached target Paths.
[ 3.089652] systemd[1]: Reached target Slices.
[ 3.090196] systemd[1]: Reached target Swap.
[ 3.091947] systemd[1]: Listening on Syslog Socket.
[ 3.093048] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.093797] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.095228] systemd[1]: Listening on Journal Audit Socket.
[ 3.096330] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.097607] systemd[1]: Listening on Journal Socket.
[ 3.099054] systemd[1]: Listening on udev Control Socket.
[ 3.100201] systemd[1]: Listening on udev Kernel Socket.
[ 3.101365] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.106885] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.113367] systemd[1]: Mounting RPC Pipe File System...
[ 3.121219] systemd[1]: Mounting Kernel Debug File System...
[ 3.129057] systemd[1]: Mounting Kernel Trace File System...
[ 3.130212] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.140317] systemd[1]: Starting Restore / save the current clock...
[ 3.149965] systemd[1]: Starting Set the console keyboard layout...
[ 3.158238] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 3.167342] systemd[1]: Starting Load Kernel Module configfs...
[ 3.176051] systemd[1]: Starting Load Kernel Module drm...
[ 3.195804] systemd[1]: Starting Load Kernel Module fuse...
[ 3.202789] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.209792] systemd[1]: Starting File System Check on Root Device...
[ 3.223442] systemd[1]: Starting Journal Service...
[ 3.249041] systemd[1]: Starting Load Kernel Modules...
[ 3.257813] systemd[1]: Starting Coldplug All udev Devices...
[ 3.259838] fuse: init (API version 7.34)
[ 3.289700] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.290714] systemd[1]: Mounted RPC Pipe File System.
[ 3.295049] systemd[1]: Mounted Kernel Debug File System.
[ 3.297580] systemd[1]: Mounted Kernel Trace File System.
[ 3.307078] systemd[1]: Finished Restore / save the current clock.
[ 3.320189] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.325062] systemd[1]: modprobe@configfs.service: Succeeded.
[ 3.326801] systemd[1]: Finished Load Kernel Module configfs.
[ 3.329216] systemd[1]: modprobe@drm.service: Succeeded.
[ 3.330687] systemd[1]: Finished Load Kernel Module drm.
[ 3.332973] systemd[1]: modprobe@fuse.service: Succeeded.
[ 3.336485] systemd[1]: Finished Load Kernel Module fuse.
[ 3.341465] systemd[1]: Finished Load Kernel Modules.
[ 3.352696] systemd[1]: Mounting FUSE Control File System...
[ 3.363637] systemd[1]: Mounting Kernel Configuration File System...
[ 3.371159] systemd[1]: Started File System Check Daemon to report status.
[ 3.387782] systemd[1]: Starting Apply Kernel Variables...
[ 3.405532] systemd[1]: Mounted FUSE Control File System.
[ 3.406586] systemd[1]: Mounted Kernel Configuration File System.
[ 3.469007] systemd[1]: Finished Apply Kernel Variables.
[ 3.498516] systemd[1]: Finished File System Check on Root Device.
[ 3.504605] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.620339] systemd[1]: Started Journal Service.
[ 3.702756] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 3.771539] systemd-journald[136]: Received client request to flush runtime journal.
[ 3.786997] systemd-journald[136]: File /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 4.602278] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.621900] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.633656] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.677459] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.769321] mc: Linux media interface: v0.10
[ 4.803783] videodev: Linux video capture interface: v2.00
[ 4.821329] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.830296] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.830327] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.830353] [vc_sm_connected_init]: start
[ 4.846616] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.847468] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
[ 4.847489] [vc_sm_connected_init]: failed to initialize shared memory service
[ 4.855780] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.855781] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.862715] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.864335] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.875764] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 4.886807] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 4.886998] : Unregister from media controller
[ 4.887017] (efault): Unregistering node (null)[0] device node /dev/video0
[ 4.887036] (efault): Unregistering node (null)[0] device node /dev/video0
[ 4.887053] (efault): Unregistering node (null)[0] device node /dev/video0
[ 4.887070] (efault): Unregistering node (null)[0] device node /dev/video0
[ 4.925664] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.934042] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.940263] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 4.959750] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.972804] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 4.979947] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.992636] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 5.080891] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.148710] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.150112] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
[ 5.152954] usbcore: registered new interface driver brcmfmac
[ 5.442741] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.442930] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.457632] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 5.467320] usbcore: registered new interface driver usbserial_generic
[ 5.467406] usbserial: USB Serial support registered for generic
[ 5.474344] usbcore: registered new interface driver cp210x
[ 5.474645] usbserial: USB Serial support registered for cp210x
[ 5.474831] cp210x 1-1.4:1.0: cp210x converter detected
[ 5.482096] usb 1-1.4: cp210x converter now attached to ttyUSB0
[ 5.482337] cp210x 1-1.4:1.1: cp210x converter detected
[ 5.495682] usb 1-1.4: cp210x converter now attached to ttyUSB1
[ 6.770889] 8021q: 802.1Q VLAN Support v1.8
[ 6.771519] random: crng init done
[ 6.771539] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.006040] uart-pl011 fe201000.serial: no DMA platform data
[ 7.179894] Adding 2097148k swap on /var/swap. Priority:-2 extents:9 across:2777084k SSFS
[ 7.351563] zram: Added device: zram0
[ 7.359748] zram0: detected capacity change from 0 to 2097152
[ 7.467905] Adding 1048572k swap on /dev/zram0. Priority:75 extents:1 across:1048572k SSFS
[ 7.499292] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 7.850166] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 7.852292] bcmgenet fd580000.ethernet eth0: Link is Down
[ 8.464891] systemd-journald[136]: Received client request to flush runtime journal.
[ 8.710182] systemd-journald[136]: Received SIGTERM from PID 1 (systemd).
[ 8.710749] systemd[1]: Stopping Journal Service...
[ 8.809865] systemd[1]: systemd-journald.service: Succeeded.
[ 8.811502] systemd[1]: Stopped Journal Service.
[ 8.842289] systemd[1]: systemd-journald-audit.socket: Succeeded.
[ 8.843759] systemd[1]: Closed Journal Audit Socket.
[ 8.845783] systemd[1]: systemd-journald-dev-log.socket: Succeeded.
[ 8.847116] systemd[1]: Closed Journal Socket (/dev/log).
[ 8.849341] systemd[1]: systemd-journald.socket: Succeeded.
[ 8.850936] systemd[1]: Closed Journal Socket.
[ 8.875566] zram: Added device: zram1
[ 8.937374] zram1: detected capacity change from 0 to 1536000
[ 9.043094] EXT4-fs (zram1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 9.076107] systemd[615]: tailscaled.service: Failed to connect stdout to the journal socket, ignoring: Connection refused
[ 9.255627] tun: Universal TUN/TAP device driver, 1.6
[ 9.456253] systemd[1]: Started Tailscale node agent.
[ 9.894777] zram: Added device: zram2
[ 9.919361] zram2: detected capacity change from 0 to 2097152
[ 10.035586] EXT4-fs (zram2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 10.124781] systemd[1]: Listening on Journal Socket.
[ 10.131922] systemd[1]: Listening on Journal Audit Socket.
[ 10.139070] systemd[1]: Listening on Journal Socket (/dev/log).
[ 10.178772] systemd[1]: Listening on Syslog Socket.
[ 11.312329] systemd[1]: systemd-rfkill.service: Succeeded.
[ 11.991767] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.991829] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.008173] systemd[1]: Starting Journal Service...
[ 12.380909] systemd[1]: Started Journal Service.
[ 13.479292] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 13.794463] Bluetooth: Core ver 2.22
[ 13.794578] NET: Registered PF_BLUETOOTH protocol family
[ 13.794594] Bluetooth: HCI device and connection manager initialized
[ 13.794623] Bluetooth: HCI socket layer initialized
[ 13.794645] Bluetooth: L2CAP socket layer initialized
[ 13.794679] Bluetooth: SCO socket layer initialized
[ 13.804576] Bluetooth: HCI UART driver ver 2.3
[ 13.804603] Bluetooth: HCI UART protocol H4 registered
[ 13.804709] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.805017] Bluetooth: HCI UART protocol Broadcom registered
[ 14.331979] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.332005] Bluetooth: BNEP filters: protocol multicast
[ 14.332033] Bluetooth: BNEP socket layer initialized
[ 14.359524] NET: Registered PF_ALG protocol family
[ 14.404776] cryptd: max_cpu_qlen set to 1000
[ 31.834961] cam-dummy-reg: disabling
