zWave Broken. Again
Again. zWave is broken. I’ve never had so much trouble with software.
Running the latest cut of openhab 2.4 (I’m continually installing the latest in an effort to at least try and find 1 version that’s even partially capable of working - yeah, chasing my tail on endless betas. You can put that on my tombstone but the ‘stable’ versions have proven to be anything but for me in the past).
After a power cut back in August (I was away at a funeral) it’s just never worked properly. Random devices dropped out, and although some came back after restarting openhab. Unfortunately a couple were just never able to be switched. Although they still appear in the zWave network.
Last night I took the step of shutting down openhab, removing all the xml files from /var/lib/openhab2/zwave and restarting. As
It initially looks promising. New files of the form network_id__node_nodeid.xml were created. But it was exceedingly slow. After 2 hours I had about 15 of them and went to bed with the PaperUI showing all my zWave devices as uninitialised.
This morning, not a lot has changed. All the xml’s are timestamped with around 0200 (Which is about the time my openhab restarts due to incessant memory leaks). and PaperUI says nothing has initialised.
Restarting does nothing except a few random errors telling me that openhab zWave is unable to load some files that IT HAS CEATED ITSELF due to the data being invalid. e.g.
018-10-02 07:23:53.441 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 12: Restore from config: Error. Data invalid, ignoring config.
2018-10-02 07:23:53.479 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 11: Not initialized (ie node unknown), ignoring message.
2018-10-02 07:23:53.458 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 3: Restore from config: Error. Data invalid, ignoring config.
2018-10-02 07:23:53.453 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 28: Restore from config: Error. Data invalid, ignoring config.
2018-10-02 07:23:53.482 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 8: Restore from config: Error. Data invalid, ignoring config.
Needless to say nothing works. No stats are being updated, even though if I enable debugging and watch the logs, plenty of updates are coming in from the devices.
2018-10-02 07:41:27.700 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 09 0E 32 02 21 34 00 00 06 B3 00 00 00 00 00 00 78
2018-10-02 07:41:27.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=9, callback=0, payload=00 09 0E 32 02 21 34 00 00 06 B3 00 00 00 00 00 00
2018-10-02 07:41:27.733 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=9, callback=0, payload=00 09 0E 32 02 21 34 00 00 06 B3 00 00 00 00 00 00
2018-10-02 07:41:27.735 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 237: [WAIT_REQUEST] priority=Poll, requiresResponse=true, callback: 185
2018-10-02 07:41:27.736 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 9: Application Command Request (ALIVE:DONE)
2018-10-02 07:41:27.738 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 9: resetResendCount initComplete=true isDead=false
2018-10-02 07:41:27.739 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 9: Incoming command class COMMAND_CLASS_METER, endpoint 0
2018-10-02 07:41:27.741 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 9: SECURITY NOT required on COMMAND_CLASS_METER
2018-10-02 07:41:27.742 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 9: Received COMMAND_CLASS_METER V3 METER_REPORT
2018-10-02 07:41:27.744 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 9: Meter: Type=Electric(1), Scale=W(2), Value=171.5
2018-10-02 07:41:27.745 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 9: Commands processed 1.
2018-10-02 07:41:27.746 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 9: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3859f7.
2018-10-02 07:41:27.748 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2018-10-02 07:41:27.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
The device discovery just seems to be stuck and the wave stack refuses to do anything with it.
Winter is coming, and I’d rather not rip all this out and replace it (The controls for my boiler are on this).
There was a recent merge into master with a complete overhaul of the Z-Wave binding. If you haven’t already, you’ll need to follow the steps in the first post of this thread. Basically, delete all of your Z-Wave Things and rediscover them (this does not mean exclude/include).
Thanks… But… You mean lose all the config for all this devices I’ve performed? Names, Stats, etc.
What a nightmare.
Anything that is stored in the zwave device will not need to be reconfigured (configuration parameters, associations, etc.). Anything that is saved in the Thing (name, polling intervals, etc.) would need to be reconfigured, if you use something other than the default. I don’t change anything in my 120+ Things and use this to save time…
I’ve also mentioned in another thread that this rule could be modified to save/restore the old Thing names, but could also restore other configurations too.
Cheers Scott.. I noticed that my items stayed the same. The only pain I had (Concerned with zWave) with most of the devices was where a couple of device names were swapped for some reason (Mostly devices that just sit there and don’t get switched often. They’re for monitoring,. but then monitoring is my second PITA with openhab at present)
