Hi, i moved recently from OH1 to OH2.1.
All seems finally to work out fine and i today switched all zwave items to 2.1 binding to get rid of old stuff.
What I have experienced is several switched even after 2 hours have not updated their state so still “green switch icon” and OFF…so i checked the item properties with Habmin and added a “polling period” of 300…which I hope means 300seconds…as the rest is in minutes.
hm, polling period should fix this - to have more frequent autonomous updates coming from the swithc, of course with the drawback to be more busy in the air.
I just checked again the association groups…its set to the controller id1.
I’d suggest to get a debug log so we can see what is happening. Also, you don’t say what the switches are which might also be useful - otherwise at first glance it looks like you’re doing all the right things…
hi chris, how to produce debug logs…start_debug (?) and next?
What I have observed…the classic Fibaro Switches with the LED Ring arround work perfect. Means after short time the switch state is updated in the UI. However all others, which have the same case but different brand make problems…
E.g. even after 24hours the switch state is still not set correctly…like its still OFF, even if I can see that the switch was ON for weeks.
Here an example of switch installed:
hm…just tried to check config in Habmin again and found something interesting…for this switch I can see in habmin@description the correct switch state…like ON but in ClassicUI it is still OFF.
No really - I would still suggest to look at the logs, or at least the event logs to see if the values are being updatd. If they are, then the problem might be with the sitemap setup.
I’m not sure - there’s not really enough information… Check the logs - they are your friend here .
in the meantime i checked the event logs…one example switch logged today:
2017-09-03 15:16:51.185 [temChannelLinkRemovedEvent] - Link ‘WellWater_Switch => zwave:device:f7e2c745:node10:switch_binary’ has been removed.
2017-09-03 15:17:26.684 [ItemChannelLinkAddedEvent ] - Link ‘WellWater_Switch-zwave:device:f7e2c745:node10:switch_binary’ has been added.
2017-09-03 18:00:00.019 [ItemCommandEvent ] - Item ‘WellWater_Switch’ received command ON
2017-09-03 18:00:00.025 [ItemStateChangedEvent ] - WellWater_Switch changed from NULL to ON
I restarted Openhab arroudn 3pm…is that normal that the switch link is removed and added with each start of openhab…strange. In addition you can see that at 6pm it should turn ON…what is interesting that for 3hours from the restart of OH it still was NULL…so no update at all for the switch state.
An hour or two should be enough - enough to catch the polling at least. I only really want to see the openhab.log file - this should have enough to see what’s happening…
