The network tab in your browser’s developer tools can teach you a lot while in Habmin!
No, but this is possible. I used the REST API for it here…
I feel like I have to say something from hanging in the forum and trying to lend a hand to folks having trouble with zwave stuff… about 90% of the time they have a bad node, they probably didn’t even know was bad. One messed up node (low battery or whatever) floods the network
Absolutely
Bad node (materialy or poor RF coms) or too many reports configured in too many devices.
Possible zombie nodes? They can cause routing havoc if I recall correctly.
You do not get a much worse node than a zombie one or a phantom association.
But still not sure how this helps Colin. He is running heal but his devices are still not working well.
Yeah sorry to OP @BigCol for the total thread jack but a good discussion ensued and I for one learned a lot
I’m thinking a repeater or mains powered node between shed and house best bet
@Andrew_Rowe that could be the answer
The thing is that does not explain why they work for a while then give up. That may indicate an issue with them or something else in the network. Would be sad to go and buy a repeater and then find it still dies.
@BigCol what nodes have you and how are things configured?
Has fix to heal and fact threads are no longer hanging helped any?
