Like in this topic: https://community.openhab.org/t/solved-oh3-zwave-binding-z-wave-serial-controller-aeotec-z-stick-gen5-remains-offline/108182 , my Aeotec Z-stick Gen5 plus, stays off line.
System: Laptop Intel i5 gen8, 8GbRam, 256Gb SSD
OS: Debian 11
OH: OH 3.4.2 in docker
Z-stick: Aeotec Gen5 Zwave Plus (from 2016)
I backuped the zwave-network using the software from Aeotec on my Windows-laptop. This works fine, so I think I can conclude that the stick itself is fine.
Before I had OH2.4 running in Debian without a docker, and it was working just fine.
I have read lots of threads about this same problem but the solutions don’t seem to work for me.
I have installed a powered USB-hub although this is a solution to a RasPi-problem I think.
Of course I checked the userID from openHAB and passed it to the docker.
I Also connected both /dev/ttyACM0 and /dev/ttyUSB0 to the docker.
My zStick is on ttyACM0:
sudo dmesg | grep ttyACM
[ 5.386451] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
and I did:
docker exec \
-d \
openhab \
/bin/chmod o+rw /dev/ttyACM0
Should this be done every time the docker starts/restarts?
I also tried the workaround: installing SerNet:
Sudo apt install ser2net
Sudo nano /etc/ser2net.conf
deleted the whole content and added only this line:
3001:telnet:0:/dev/ttyACM0:115200 8DATABITS NONE 1STOPBIT remctl
Sudo systemctl enable ser2net
Sudo systemctl start ser2net
Port configuration in zwave-thing:
rfc2217://127.0.0.1:3001
This too does not do a thing for me.
Inside the docker I did this:
d /run/lock 0775 root dialout -
Add the following line to the legacy.conf:
And then copy the legacy.conf to tmpfiles.d
cp /usr/lib/tmpfiles.d/legacy.conf /etc/tmpfiles.d/
sudo nano /usr/lib/tmpfiles.d/legacy.conf
change:
d /run/lock 0755 root root -
to
d /run/lock 0775 root root –
#d /run/lock/subsys 0755 root dialout -
d /run/lock 0775 root root -
Now I really don’t know what to do anymore. So I asked ChatGPT as it’s quick (not necessarily correct of course). It helped me do the following:
sudo docker exec -it openhab3 /bin/bash
root@HAS:/openhab# ls /dev/tty*
/dev/tty /dev/ttyACM0 /dev/ttyUSB0
I installed minicom on the docker.
Running minicom -D /dev/ttyACM0 -b 115200 brings me to a black screen
I think this meens I’m in the zwave stick???
When I press the button a few times I see this in the terminal:
▒H ` 2!4▒ ▒
2!4▒
2!4▒
2!4▒
2!4▒ `22!4H▒ ` 2!4H▒ 2!4H▒+ 2!4H▒▒+ 2!4L▒ 2!4L▒ 2!4L▒ 2!4L▒ B
So it looks like there is some connection, but I don’t think it’s communicating well.
Now I hope you have an idea that I might have missed or that I went the wrong way somewhere?
Otherwise there are only two options: solder a wire inside like this: https://community.home-assistant.io/t/sticky-aeotec-z-stick-gen5-raspberry-pi4/218405 (I hope not, I barely understand what they say in that topic.
Or I have to buy a new stick. I hope to prevent both.
