I do sudo apt-get update and then sudo apt-get upgrade but it does not find anything to upgrade.
And deb http://dl.bintray.com/openhab/apt-repo stable main is addaed to the sources.list and looks as it is fetched when updating. Any hint on what is happening ?
pi@rpi-openhab ~ $ sudo apt-get update
Get:1 http://dl.bintray.com stable Release.gpg [821 B]
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Get:2 http://dl.bintray.com stable Release [3,695 B]
Hit http://repo.mosquitto.org wheezy Release.gpg
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Get:3 http://dl.bintray.com stable/main armhf Packages [20.5 kB]
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://repo.mosquitto.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://dl.bintray.com stable/main Translation-en_GB
Ign http://repo.mosquitto.org wheezy/main Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 25.0 kB in 11s (2,199 B/s)
Reading package lists... Done
pi@rpi-openhab ~ $ sudo apt-get upgrade
Building dependency tree
The following packages have been kept back:
nuscratch
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
pi@rpi-openhab ~ $
You did “sudo apt-get update”, but not “sudo apt-get upgrade”, I got the same results you did… I got mine upgraded, but I cannot get the web interface to load my sitemaps… I get the background to the web interface, but no items from my sitemap.
I am having the same problem. I also checked my sources.list file. Curiously, a few days ago, I was having the signature problem, and so I waited until others reported it working (I’m talking about this discussion).
I’m not sure I know what you’re asking. Sorry. Noob here. I was running OH 1.7.1. I may have just messed it up as I tried sudo apt-get install openhab-runtime. That may have worked as I now can’t see any pages that had multiple dimmer sliders in the UI. But at startup, it still says openHAB runtime has been started (v1.7.1).
I’ve backed up my configurations directory. Are there any other files or directories I should backup before erasing the SD card and starting over? I haven’t done much. Two z-wave lights and some hue lights.
Any file you’ve changed, but they are usually in the configurations directory. You might want to save your Z-Wave database, but it will be rebuilt if you don’t.
While I’m writing new posts came in but I send my reply anyway.
I think it’s pretty clear now. You both mixed things up. You did a manual installation and tried to upgrade it using the apt installation, which isn’t possible. @xsherlock only has the manual installation because he only used the apt-get upgrade command. @Domino has two installations because he used the apt-get install command to try the upgrade.
If you want to stay with your manual installation you have to manually upgrade it.
If you want to go with the apt installation it is described here apt installation instructions. If you want to keep your configuration move the items, rules,… files from /opt/openhab/configurations to /etc/openhab/configurations/… directories.
