I mean 3-5 minututes is the time after which I need to wait another 8 seconds between trigger and first reaction of rule.
I have full awareness of this and always let the rule load for the first time after edit or restart and my observations starting later.
I removed all my rules file from rules directory, created new file and put inside it part with corridor rule as below. Now the lag after 3-5 min is about 1.2-1.5 second. It’s weird…
rule Pir_Corridor_On
Item Corridor_MotionSensor changed to ON
logInfo("Pir", "Corridor: Korytarz - ruch, jasnosc: " + Corridor_MotionSensor_Luminance.state)
logInfo("Pir", "Corridor: Aktywacja swiatla w trybie dzien")
sendCommand(Corridor_Ambiance_4, 100)
Thread::sleep(300)
sendCommand(Corridor_Ambiance_3, 100)
Thread::sleep(300)
sendCommand(Corridor_Ambiance_2, 100)
Thread::sleep(300)
sendCommand(Corridor_Ambiance_1, 100)
rule Pir_Corridor_Off
Item Corridor_MotionSensor changed to OFF
logInfo("Pir", "Corridor: Korytarz - koniec ruchu, jasnosc: " + Corridor_MotionSensor_Luminance.state)
Thread::sleep(300)
sendCommand(Corridor_Ambiance_1, 0)
Thread::sleep(300)
sendCommand(Corridor_Ambiance_2, 0)
Thread::sleep(300)
sendCommand(Corridor_Ambiance_3, 0)
Thread::sleep(300)
sendCommand(Corridor_Ambiance_4, 0)
And next observation, now I put into my only one rules file two simpler rules as below. In that case there is very small lag, about 250ms. If I fast turn on and off the source item there is no lag at all so the problem still exists.
var String ir_path = "/etc/openhab2/ir_sequences/ir_sequences.sh "
rule "Ir_Music_On"
Item IR_Music received command ON
logInfo("Pir", "Start of Ir music on rule")
executeCommandLine(ir_path + "JVC-Aux", 5000)
rule "Ir_Music_Off"
Item IR_Music received command OFF
logInfo("Pir", "Start of Ir music off rule")
executeCommandLine(ir_path + "JVC-Power", 5000)
Enable vast debugging such as org.openhab and org.apache.karaf to see if there’s bindings to reinstall or similar stuff going on. See also 2.5 issues after upgrade .
My rules configuration is back to my normal daily configuration as in the begining and there is still 8 seconds lag. My increased heap sizes: Maximum heap size 605,824 kbytes, Committed heap size 445,824 kbytes.
In the log I see failed uninstalling openhab ui dashboard (every minute). Do you think this could be a problem?
2020-03-01 19:35:39.582 [DEBUG] [core.karaf.internal.FeatureInstaller] - Running scheduled sync job
2020-03-01 19:35:39.675 [DEBUG] [core.karaf.internal.FeatureInstaller] - Failed uninstalling 'openhab-ui-dashboard': Feature named 'openhab-ui-dashboard/0' is not installed
2020-03-01 19:35:52.105 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 22: Command received zwave:device:77badcb7:node22:alarm_motion --> OFF [OnOffType]
2020-03-01 19:35:52.108 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 22: No event found with name 'eventOFF'
2020-03-01 19:35:52.111 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 22: No messages returned from converter
2020-03-01 19:35:59.677 [INFO ] [g.eclipse.smarthome.model.script.Pir] - Kitchen: Czujka w kuchni changed to OFF. 1=100, 2=100, Current 1 status=100, Current 2 status=100, kitchenOnByMotion=true
2020-03-01 19:35:59.684 [INFO ] [g.eclipse.smarthome.model.script.Pir] - Kitchen: Wylaczanie lamp w kuchni
Yes. Note sure it’s directly related to your problem but a problem it is.
Check the upgrade issues thread I linked to, it’s not exactly the same but should get you an idea where to look for.
addons.cfg is all commented, and other files doesn’t contain anything suspicious.
Should I try to uninstall and install again of dashboard at paper ui webpage?
yeah, sorry, that won’t work, it is complaining about it not being installed and yet shows as install in your screan shot of Paper ui (clearly it is not as per your bundle:list)
Try uninstalling it from Paper UI
Please be clear about the circumstances; a delay of first-time execution after reboot is expected. Don’t let us just make assumptions that you still mean later on, after some minutes uhh “not used timeout”
A diagnostic move; make sure your xxx.rules file has a little rule triggered on System started that need only log that it ran.
This will give two effects - you’ll be able to see if the rules file is actually reloaded (there have been reports of such)
and as a bonus, it will take the first-time-only delay out of the picture.
I always do the first load of the rule after reboot/save file and then I make the observations, I wrote about it before. And I do tests more than one time, don’t worry .
