Not sure in what topic i should place this.
I’m having troubles configuring the E.31 (sACN) to DMX interface/Bridge.
I’m able to connect to this thing:
And i created a DMX item:
When i change the DMX then i see changes in the logs:
But there is no reaction on the LED strip that is connected by a DMX decoder. The DMX controller is working fine if i use another system.
I have no clue why this isn’t working.
Anybody has this working and can advice me on what to check?
Did you configure the correct universe? Some interfaces start with 0, others with 1. Did you select unicast it multicast? If multicast: is the system running OH in the same network as the system that is working with other software?
Thanks for your reply, @J-N-K
I configured the correct universe (1) and i tried 0 as you suggested.
I’ve tried with unicast and multicast, no succes. I guaranteed in the correct network, i configured a fixed ip address.
I have no other software that i can trywith. Can you suggest one?
Thanks angain for your advice!
Yes, I hav a DMX interface of Qbus and i can controll the DMX interface, colors are working. Then i disconnect Qbus and place The sACN interface in its place.
I even try switching the wires of the DMX signal to be sure ( i dont know if there is a polarity on DMX).
I even have a scope on the output. DMX signal is showing up, but doesn’t change when i send a color from OH.
I’m also trying to figuring out wireshark to see if the data from OH is transmitted to the interface.
Don‘t know. Multicast is printed on the interface, that should be used then. Are the OH system and the Interface in the same subnet? Do you have a Managed Switch? Some Block multicast.
I know nowt about KNX, but analyzing your events.log from post one;
OH Command arrives 245,56,60.
Prediction from autoupdate, in response to command.
autoupdate’s prediction applied as an update 245,56,60. (All ordinary enough so far, none of this involves interaction outside OH)
450mS later, another update to 189,52,60. That has come from the binding, it’s not unusual for the initial response to a command to be the “old” status in various technologies. Did it come from the actual device, or some cache along the way?
A few mS after that, yet another update to 244,56,60. That’s a close match to the issued command, and it’s not unusual to see a small difference that can accounted for by rounding errors in various conversions along the way. This again has come via the binding, almost certainly from some external source i.e. a DMX device.
All the clues here say that command got to some end device and was accepted. The rounding error makes it look even more like a “real” event, and not just a reflection from DMX bus.
Easy test to repeat the exercise with decoder unplugged.
Is there some multi-channel thing going on here, not looking at same target?
MDAR
15
Hi
So to recap.
You have seen the LED lights responding from Qbus ? (Unless QBus is a DMX output, not sACN output, I’ve not worked with Qbus)
And yes, DMX does have a polarity.
(It’s just that some manufacturers label the terminals incorrectly)
So in theory, as long as nothing else is trying to send data to your sACN adapter, it should just be a matter of matching OH’s configuration to what works for you in Qbus ?
Personally, I struggle with getting the sACN / Art-NET bridges working in text files, but I did manage it once and I have put up an example here -
#J-N-K’s binding is rock solid, so once you get it configured correctly, you should be okay.
One thought…
I don’t think that the sACN adapters report back their online status, so I’m going to assume that when an Art-NET or sACN bridge is shown as Online, it simply means that OH has not “failed to initialise” it.
And one small technical detail.
DMX is strictly a One Direction protocol.
Master unit (transmitter based loosely on RS485) issue a strictly timed data stream, which all slave devices listen to.
RDM protocol was developed as a bi-directional version, so that fixtures could be polled for their status.
If…
You’re only setting up s small network, I would advise a Uni-cast bridge.
MDAR
16
Hi
I found this little app on Google Play.
It’s a little fiddly to set up, but I’m finding it really useful for testing single universe Art-NET or sACN
I am using the same bridge. Had problems to get it running with openHAB.
Solution for me was to configure a local address for the bridge in openHAB setup.
Config File (but it’s also possible to do this in GUI):
Bridge dmx:sacn-bridge:myDMXbridge [ mode=“multicast”, localaddress=“YOUR_OPENHAB_IP”, universe=1 ] {
YOUR_THINGS
That forces the selection of a specific network interface. Maybe in some setups multicast is send to the loopback or some other interface that cannot reach the bridge.
thanks for the advice! I’m busy with another project for the moment, but next week i will look in to it.
So i had to try today.
I’ve found a freeware software for windows, wich can log sACN devices
The logger shows this:
When i change my colors on openHAB, so openHAB side is ok.
The software also shows a list of found devices on the network. My raspberry pi with openHAB was found by the software. But it didn’t found my Brige!?!?
I’m on fixed ip now and i can reach te web page for settings.
Also added the parameter localaddress to my configuration.
Try to get the bridge running first with a DMX Software like https://www.qlcplus.org/
Connect the bridge directly to your Laptop.
The webinterface of the bridge is just for the settings. DMX protocol is UDP, maybe you have Firewall, Router or something that blocks UDP broadcasts. If connect the bridge directly to a network port of your computer, you can eliminate one possible source for an error
