So you are willing to pay someone else, but my time is for free? I find this strange…
Hi @chris
id be HAPPY to pay you, it’s your binding but you mentioned you have other priorities so if I can improve it further for all I’d happily pay.
Let me know!
Well, I normally prioritise based on either lots of people asking for a feature, or major bugs that are affecting people. Priorities can always be changed of course…
Unfortunately I am away from tomorrow until the end of next week, but I will look at it when I return (or maybe I can find some time when I’m on holiday).
Note that I will not have internet while travelling.
Hi Chris,
I will send you a personal email on the issue. Enjoy your no doubt much deserved holiday!
Cheers
Hi everyone, did anywone solve dimmer issue?
Yes, the updated channels were added and tested.
Hmm. I wonder what is wrong in my OH2 - I have below channels set in items file:
Switch SwitchBiuroWlacznikDoubleMote_SwitchBinary "Switch" {channel="zwave:device:2dd500f8:node19:switch_binary"}
Dimmer SwitchBiuroWlacznikDoubleMote_SwitchDimmer "Dimmer" {channel="zwave:device:2dd500f8:node19:switch_dimmer"}
Number SwitchBiuroWlacznikDoubleMote_MeterWatts "Electric meter (watts)" {channel="zwave:device:2dd500f8:node19:meter_watts"}
Number SwitchBiuroWlacznikDoubleMote_MeterKwh "Electric meter (kWh)" {channel="zwave:device:2dd500f8:node19:meter_kwh"}
Number SwitchBiuroWlacznikDoubleMote_SceneNumber "Scene Number" {channel="zwave:device:2dd500f8:node19:scene_number"}
I see scene number change in log file between 1.0/1.2/1.2/2.0/2.1/2.2, but when i slide left section or right section nothing is happenig with dimmer value. Nothing is happening in log viewer
I associate group 3 and 5 to controller and also I’ve changed parametr 3 to 1 (enabled) and parametr 4 to 3 (Central scene and config).
Firmware version is 1.8
Any ideas?
PS: Thank you very much for your reply Chris
@dastrix80 do you have some rules / items that you could share for how you’re using this device?
I do.
Ill get something up shortly.
Thanks.
Items:
/*ZWave Aeotec Wallmote Bedroom */
Number BedRoom1_AeoButton_Scene "Aeotec Bedroom 1 Button" { channel="zwave:device:a1562d1c:node20:scene_number" }
Number BedRoom1_AeoButton_Battery "Aeotec Bedroom 1 Battery" (gBatteries) { channel="zwave:device:a1562d1c:node20:battery-level" }
String BedRoom1_AeoButton_Slide1 "Aeotec Bedroom 1 #1 Button" { channel="zwave:device:a1562d1c:node20:switch_startstop1" }
String BedRoom1_AeoButton_Slide2 "Aeotec Bedroom 1 #2 Button" { channel="zwave:device:a1562d1c:node20:switch_startstop2" }
String BedRoom1_AeoButton_Slide3 "Aeotec Bedroom 1 #3 Button" { channel="zwave:device:a1562d1c:node20:switch_startstop3" }
String BedRoom1_AeoButton_Slide4 "Aeotec Bedroom 1 #4 Button" { channel="zwave:device:a1562d1c:node20:switch_startstop4" }
Rules:
rule "WallMote Dim Control BedRoom 1"
Item BedRoom1_AeoButton_Slide2 received update
val String json = (BedRoom1_AeoButton_Slide2.state as StringType).toString.split("\\W+").get(2)
val String type = transform("JSONPATH", "$.direction", json)
if (type == "INCREASE") {
percent_din = DiningRoomDim1.state as Number
percent_din = Math.min(percent_din.intValue + 10,100) // increase brightness by 10%
DiningRoomDim1.sendCommand(percent_din)
if (type == "DECREASE") {
percent_din = Math.max(percent_din.intValue - 10,0) // decrease brightness by 10%
Hi Chris,
Thank you for your time. Please find below two rules which are working so far.
//Ubikacja włączanie i wyłączanie światła z czujki ruchu Aeotec
rule "Ubikacja Swiatlo Aeotec"
Item SensorUbikacjaMotionAeotecA_AlarmMotion changed
/*Włącz światło*/
if (SensorUbikacjaMotionAeotecA_AlarmMotion.state == ON)
logInfo("Światło","ON: Włączono światło w ubikacji przez czujnik ruchu Aeotec")
SwitchUbikacjaWlacznikAeotec_SwitchBinary.sendCommand(ON)
SwitchUbikacjaWlacznikDoubleMote_SceneNumber.sendCommand(1.0)
else
/*Wyłącz światło*/
logInfo("Światło","OFF: Wyłączono światło w ubikacji przez czujnik ruchu Aeotec")
SwitchUbikacjaWlacznikAeotec_SwitchBinary.sendCommand(OFF)
SwitchUbikacjaWlacznikDoubleMote_SceneNumber.sendCommand(2.0)
//------------Biuro--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
//Ubikacja włączanie i wyłączanie światła z Aeotec WallMote Double
rule "Biuro Swiatlo Aeotec"
Item SwitchBiuroWlacznikDoubleMote_SceneNumber changed
/*Włącz światło*/
if (SwitchBiuroWlacznikDoubleMote_SceneNumber.state == 1.0)
logInfo("Światło","ON: Włączono światło w biurze z włącznika Aeotec")
RelayBiuroSwiatloMain_SwitchBinary.sendCommand(ON)
else
/*Wyłącz światło*/
logInfo("Światło","OFF: Wyłączono światło w biurze z włącznika Aeotec")
RelayBiuroSwiatloMain_SwitchBinary.sendCommand(OFF)
