Hi Guys,
i running into some problems with amazon echo control binding.
2021-02-20 09:54:14.127 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@1921ebf’: GET url ‘https://alexa.amazon.de/api/behaviors/automations?limit=2000’ failed: Not Found
it means that you do not use the snapshot that once was available.
What you could try is to do is to go to Index of openhab-linuxpkg/pool/main select one of the snapshot directories. Download openhab-addons_3.1.0*_all.deb.
The .deb file can be unpacked with e.g. 7z.
Extract the data.tar.gz file.
Further continue to look into the file and extract the file openhab-addons-3.1.0-SNAPSHOT.kar.
Again look into the file and extract org.openhab.binding.amazonechocontrol-3.1.0-SNAPSHOT.jar
