Just a quick, but very handy tip
When using code in your posts. Lots of people are using the default code block. Which is great.
Clicking the code button / 4 spaces before code example
<appender name="FILE" class="ch.qos.logback.core.rolling.RollingFileAppender">
<file>${openhab.logdir:-logs}/openhab.log</file>
<rollingPolicy class="ch.qos.logback.core.rolling.FixedWindowRollingPolicy">
<fileNamePattern>${openhab.logdir:-logs}/openhab.%i.log</fileNamePattern>
<minIndex>1</minIndex>
<maxIndex>3</maxIndex>
</rollingPolicy>
<triggeringPolicy class="ch.qos.logback.core.rolling.SizeBasedTriggeringPolicy">
<maxFileSize>250KB</maxFileSize>
</triggeringPolicy>
<encoder>
<pattern>%-4relative [%thread] %-5level %logger{35} - %msg%n</pattern>
</encoder>
</appender>
The four spaces before the code is handy but can break if you then edit the code in the post.
Using three backticks at the start and end of the code
You can achieve the same thing by wrapping the code with three backticks (on my GB mac that is the key to left of the Z key)
This also means you don’t have to have spaces before every line ![]()
<code>goes here</code>
Though it is all a bit gloomy.
Using three ticks and the name of the code language
If you add the code language after the first three backticks then you get colour highlighting as well.
XML
```xml
</triggeringPolicy>
<encoder>
</encoder>
becomes
</triggeringPolicy>
<encoder>
</encoder>
slighlty less gloomy
Java
```java
rule goes here
import org.joda.time.*
import org.openhab.core.types.*
import org.openhab.core.library.items.*
import org.openhab.core.items.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.eclipse.xtext.xbase.lib.*
var Timer ReloadTimer = null
var Integer timeOut = 200
var boolean reloadOnce = true
rule "Refresh rules after persistance service started"
System started
if(reloadOnce) {
ReloadTimer = createTimer( now.plusSeconds(timeOut) )
executeCommandLine("./configurations/rules_refresh.sh")
ReloadTimer=null
} else {
println("reloadOnce is false")
reloadOnce = false
The secret sauce : highlight.js
The forum software uses the popular highlight.js for this and currently the following are configured to work and highlight correctly(ish).
- apache
- bash
- cs
- cpp
- css
- coffeescript
- diff
- xml
- http
- ini
- json
- java
- javascript
- makefile
- markdown
- nginx
- objectivec
- ruby
- perl
- php
- python
- sql
- handlebars
Enjoy
