Still no motion event… should it be visible in the logs?
2020-09-17 16:29:50.123 [ome.event.ItemCommandEvent] - Item ‘HttpOnlyMotionControlSensitivity’ received command 17
2020-09-17 16:29:50.143 [nt.ItemStatePredictedEvent] - HttpOnlyMotionControlSensitivity predicted to become 17
2020-09-17 16:29:50.675 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - ffmpeg version 4.1.6-1~deb10u1+rpt1 Copyright (c) 2000-2020 the FFmpeg developers
2020-09-17 16:29:50.677 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - built with gcc 8 (Raspbian 8.3.0-6+rpi1)
2020-09-17 16:29:50.678 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --libdir=/usr/lib/arm-linux-gnueabihf --cpu=arm1176jzf-s --arch=arm
2020-09-17 16:29:50.679 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - WARNING: library configuration mismatch
2020-09-17 16:29:50.680 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - avutil configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
2020-09-17 16:29:50.681 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - avcodec configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
2020-09-17 16:29:50.682 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - avformat configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
2020-09-17 16:29:50.683 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - avdevice configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
2020-09-17 16:29:50.684 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - avfilter configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
2020-09-17 16:29:50.685 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - avresample configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
2020-09-17 16:29:50.686 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - swscale configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
2020-09-17 16:29:50.687 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - swresample configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
2020-09-17 16:29:50.689 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - postproc configuration: --prefix=/usr --extra-version=‘1~deb10u1+rpt1’ --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
2020-09-17 16:29:50.690 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - libavutil 56. 22.100 / 56. 22.100
2020-09-17 16:29:50.691 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - libavcodec 58. 35.100 / 58. 35.100
2020-09-17 16:29:50.692 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - libavformat 58. 20.100 / 58. 20.100
2020-09-17 16:29:50.693 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - libavdevice 58. 5.100 / 58. 5.100
2020-09-17 16:29:50.694 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - libavfilter 7. 40.101 / 7. 40.101
2020-09-17 16:29:50.695 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - libavresample 4. 0. 0 / 4. 0. 0
2020-09-17 16:29:50.696 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - libswscale 5. 3.100 / 5. 3.100
2020-09-17 16:29:50.697 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - libswresample 3. 3.100 / 3. 3.100
2020-09-17 16:29:50.698 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - libpostproc 55. 3.100 / 55. 3.100
2020-09-17 16:29:50.783 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [rtsp @ 0x236f220] CSeq 4 expected, 0 received.
2020-09-17 16:29:54.089 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Input #0, rtsp, from ‘rtsp://192.168.0.14/ch0_1.h264’:
2020-09-17 16:29:54.090 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Metadata:
2020-09-17 16:29:54.092 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - title : Session streamed by “rtspv4”
2020-09-17 16:29:54.094 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - comment : ch0_1.h264
2020-09-17 16:29:54.094 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Duration: N/A, start: 0.050000, bitrate: N/A
2020-09-17 16:29:54.096 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Stream #0:0: Video: h264 (High), yuvj420p(pc, bt709, progressive), 640x360, 20 fps, 20 tbr, 90k tbn, 180k tbc
2020-09-17 16:29:54.097 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Stream mapping:
2020-09-17 16:29:54.098 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Stream #0:0 → #0:0 (h264 (native) → wrapped_avframe (native))
2020-09-17 16:29:54.099 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Press [q] to stop, [?] for help
2020-09-17 16:29:54.149 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [swscaler @ 0x24330f0] deprecated pixel format used, make sure you did set range correctly
2020-09-17 16:29:54.150 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [swscaler @ 0x24330f0] No accelerated colorspace conversion found from yuv420p to rgb24.
2020-09-17 16:29:54.158 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Output #0, null, to ‘pipe:’:
2020-09-17 16:29:54.159 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Metadata:
2020-09-17 16:29:54.160 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - title : Session streamed by “rtspv4”
2020-09-17 16:29:54.161 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - comment : ch0_1.h264
2020-09-17 16:29:54.161 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - encoder : Lavf58.20.100
2020-09-17 16:29:54.162 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Stream #0:0: Video: wrapped_avframe, rgb24, 640x360, q=2-31, 200 kb/s, 20 fps, 20 tbn, 20 tbc
2020-09-17 16:29:54.164 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Metadata:
2020-09-17 16:29:54.165 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - encoder : Lavc58.35.100 wrapped_avframe
2020-09-17 16:29:54.172 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] frame:0 pts:0 pts_time:0
2020-09-17 16:29:54.173 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] lavfi.scene_score=0.008587
2020-09-17 16:29:54.181 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] frame:1 pts:4500 pts_time:0.05
2020-09-17 16:29:54.184 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] lavfi.scene_score=0.003185
2020-09-17 16:29:54.587 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] frame:2 pts:175496 pts_time:1.94996
2020-09-17 16:29:54.588 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] lavfi.scene_score=0.035852
2020-09-17 16:29:54.650 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] frame:3 pts:179996 pts_time:1.99996
2020-09-17 16:29:54.652 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] lavfi.scene_score=0.006102
2020-09-17 16:29:54.660 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] frame:4 pts:184496 pts_time:2.04996
2020-09-17 16:29:54.661 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] lavfi.scene_score=0.002577
2020-09-17 16:29:54.663 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - frame= 5 fps=0.0 q=-0.0 size=N/A time=00:00:02.10 bitrate=N/A speed=3.77x
2020-09-17 16:29:55.197 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - frame= 5 fps=4.6 q=-0.0 size=N/A time=00:00:02.10 bitrate=N/A speed=1.92x
2020-09-17 16:29:56.107 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - frame= 5 fps=2.5 q=-0.0 size=N/A time=00:00:02.10 bitrate=N/A speed=1.05x
2020-09-17 16:29:56.617 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - frame= 5 fps=2.0 q=-0.0 size=N/A time=00:00:02.10 bitrate=N/A speed=0.836x
2020-09-17 16:29:56.760 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] frame:5 pts:355493 pts_time:3.94992
2020-09-17 16:29:56.761 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] lavfi.scene_score=0.035682
2020-09-17 16:29:56.770 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] frame:6 pts:359992 pts_time:3.99991
2020-09-17 16:29:56.771 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] lavfi.scene_score=0.008200
2020-09-17 16:29:56.781 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] frame:7 pts:364492 pts_time:4.04991
2020-09-17 16:29:56.782 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] lavfi.scene_score=0.003266
2020-09-17 16:29:57.074 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [Parsed_metadata_1 @ 0x2431a80] frame:8 pts:377992 pts_time:4.19991
