I am sorry for confusion, I had issue with Java. Everything works fine.
I just tried to use virtual F@home Switches in free@home scenes - I see then, can set and save them into Scenes, but when the scene is triggered the virtual switches do nothing - is that bug still unsolved ? F@h 3.1.2 Openhab 3.4.3 Binding 3.3.0 (seems thatās still the latest?) .
Edit: I tried Devices set
up with virtualDeviceEmulation and set up without, outside of
the scene those switches work perfectly, but seem to not work in a scene.
Any ideas ?
Edit2: Adding virtualDeviceEmulation in the backup file, reloading the backup into the AP was not enough - restarting the F@h SystemAP then made it work!
Thanks, Olaf
Yes, I am also back to using virtualDeviceEmulation for my virtual switches.
just for your info, I just installed 4.0 M2 and the binding works
The binding is installed and it works for existing things in Openhab 4.0 M2, but Iām not able to add new things. The binding is not listed any more in the āadd thing menuā
I have also been successfully running F@H binding version 3.3 under OH 4.0M2 (Sysap FW 3.1.2), although without being required to make changes to existing setup, thus being unaware of the issue pointed out by @ML1982, so thanks for bringing it up.
Have made a new compilation of the binding, under 4.0 development environment, and the new version compiles successfully without errors, but still unable to find binding under āadd thingā.
org.openhab.binding.freeathome-4.0.0-SNAPSHOT.jar
See others have reported similar issues for manual installs of bindings, so need to investigate further.
Following:
And further:
It seems like a workaround (for now) to use Developer Sidebar from main UI to add things (not tested myself).
Hello
I am using this binding under OH 3.4.2 and it works great. Before I dare the update to OH 4, I would like to know whether the BJ binding also works under OH 4.
Thank you
It works, I made the Update last week.
Many thanks for your response. Are you using freeathome-4.0.0-SNAPSHOT.jar or the āold 3.4ā version?
Both work, but I forgot to mention that there is still the problem of adding new things.
See here:
Thank you for the answer. I have now updated and BJ is working.
I once had the problem with the missing binding with ZWave. I typed http://xxx.xxx.xxx.xxx:8080/settings/things/add/freeathome in the browser and see the binding page with scan button. Scan works then too.
Greetings
thanks a lot, it works.
Did anyone upgraded the Firmware to 3.2.1 and knows how the connection between openhab works ?
thx Stephan
just scroll up to april 2023, there are a posts about 3.2.1.
I my case it is still running without any problems.
Iām using:
Version 3.1.2 | Revision 10109
But a few days ago 3.2.1 (Edit 01.11.2023: 3.2.2 was a typo) has been released, did anybody the update?
Same question here. Anyone tried 3.2.2?
just for information, Iāve updated my Busch JƤger SysAp from 3.1.2 to version 3.2.1 and it works with the binding.
@LuiSauberhorn I think 3.2.2 was an typo, i wrote 3.2.2 in my previous post, that was wrong.
Here is my current configuration.
Busch JƤger FW 3.2.1 | Revsion 11076
Openhab 4.0.3
Has the āAdd new thingsā-problem in OH4 been solved in the meantime?
FW 3.2.2 is in fact the latest version. I am successfully running this OH addon along with FW 3.2.2 and OH 4.1.0.M2.
@Cybso with this workaround, you can add new things.
just enter the url:
and you will see this page
