Thanks for you long detailed description!
my OpenHab don’t like me
However I get folling logs after delete and make new bridge:
2019-10-07 10:32:52.659 [INFO ] [rnal.handler.FreeAtHomeBridgeHandler] - Login Match Matching JID for login: openhab & 7abb2233-5878-47e5-81d9-052ca05afedf@busch-jaeger.de
2019-10-07 10:32:52.767 [INFO ] [rnal.handler.FreeAtHomeBridgeHandler] - Login Match Matching JID for login: openhab & 7abb2233-5878-47e5-81d9-052ca05afedf@busch-jaeger.de
2019-10-07 10:32:53.066 [WARN ] [rnal.handler.FreeAtHomeBridgeHandler] - Bridge connected. Updating thing status to ONLINE.
2019-10-07 10:32:53.076 [WARN ] [rnal.handler.FreeAtHomeBridgeHandler] - Connection authenticated
2019-10-07 10:32:53.164 [WARN ] [rnal.handler.FreeAtHomeBridgeHandler] - Bridge connected. Updating thing status to ONLINE.
2019-10-07 10:32:53.842 [hingStatusInfoChangedEvent] - 'freeathome:bridge:b91bb647' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): XMPP connection lost
2019-10-07 10:32:53.753 [WARN ] [rnal.handler.FreeAtHomeBridgeHandler] - Bridge connection lost. Updating thing status to OFFLINE.
2019-10-07 10:32:53.842 [WARN ] [rnal.handler.FreeAtHomeBridgeHandler] - Connection lost DISCONNECTED (old status: AUTHENTICATED)
Status change caused by:
javax.websocket.DecodeException: unerwartetes Element (URI:"", lokal:"iq"). Erwartete Elemente sind <{urn:xmpp:sm:3}a>,<{urn:ietf:params:xml:ns:xmpp-sasl}abort>,<{http://jabber.org/protocol/chatstates}active>,<{urn:xmpp:csi:0}active>,<{urn:xmpp:jingle:apps:rtp:info:1}active>,<{http://jabber.org/protocol/activity}activity>,<{http://jabber.org/protocol/address}addresses>,<{http://jabber.org/protocol/activity}at_the_spa>,<{urn:xmpp:attention:0}attention>,<{urn:ietf:params:xml:ns:xmpp-sasl}auth>,<{http://jabber.org/protocol/commands}bad-action>,<{urn:ietf:params:xml:ns:xmpp-streams}bad-format>,<{http://jabber.org/protocol/commands}bad-locale>,<{urn:ietf:params:xml:ns:xmpp-streams}bad-namespace-prefix>,<{http://jabber.org/protocol/commands}bad-payload>,<{http://jabber.org/protocol/si}bad-profile>,<{urn:ietf:params:xml:ns:xmpp-stanzas}bad-request>,<{http://jabber.org/protocol/commands}bad-sessionid>,<{urn:ietf:params:xml:ns:xmpp-bind}bind>,<{urn:xmpp:blocking}block>,<{urn:xmpp:blocking:errors}blocked>,<{urn:xmpp:blocking}blocklist>,<{http://jabber.org/protocol/httpbind}body>,<{http://jabber.org/protocol/activity}brushing_teeth>,<{http://jabber.org/protocol/activity}buying_groceries>,<{http://jabber.org/protocol/caps}c>,<{urn:xmpp:caps}c>,<{urn:xmpp:sec-label:catalog:2}catalog>,<{urn:ietf:params:xml:ns:xmpp-sasl}challenge>,<{urn:xmpp:jingle:apps:file-transfer:4}checksum>,<{http://jabber.org/protocol/activity}cleaning>,<{http://jabber.org/protocol/ibb}close>,<{urn:ietf:params:xml:ns:xmpp-framing}close>,<{http://jabber.org/protocol/pubsub#errors}closed-node>,<{http://jabber.org/protocol/activity}coding>,<{http://jabber.org/protocol/commands}command>,<{http://jabber.org/protocol/activity}commuting>,<{http://jabber.org/protocol/chatstates}composing>,<{http://jabber.org/protocol/compress}compress>,<{http://jabber.org/protocol/compress}compressed>,<{http://jabber.org/features/compress}compression>,<{http://jabber.org/protocol/pubsub#errors}configuration-required>,<{http://jabber.org/protocol/http-auth}confirm>,<{urn:ietf:params:xml:ns:xmpp-stanzas}conflict>,<{urn:ietf:params:xml:ns:xmpp-streams}conflict>,<{urn:ietf:params:xml:ns:xmpp-streams}connection-timeout>,<{http://jabber.org/protocol/activity}cooking>,<{urn:xmpp:jingle:apps:rtp:errors:1}crypto-required>,<{urn:xmpp:csi:0}csi>,<{http://jabber.org/protocol/activity}cycling>,<{http://jabber.org/protocol/activity}dancing>,<{http://jabber.org/protocol/ibb}data>,<{urn:xmpp:avatar:data}data>,<{urn:xmpp:bob}data>,<{http://jabber.org/protocol/activity}day_off>,<{urn:xmpp:delay}delay>,<{urn:xmpp:jingle:apps:file-transfer:4}description>,<{urn:xmpp:jingle:apps:rtp:1}description>,<{urn:xmpp:carbons:2}disable>,<{http://jabber.org/protocol/activity}doing_maintenance>,<{http://jabber.org/protocol/activity}doing_the_dishes>,<{http://jabber.org/protocol/activity}doing_the_laundry>,<{http://jabber.org/protocol/activity}driving>,<{urn:xmpp:carbons:2}enable>,<{urn:xmpp:sm:3}enable>,<{urn:xmpp:sm:3}enabled>,<{http://etherx.jabber.org/streams}error>,<{urn:xmpp:sec-label:ess:0}esssecuritylabel>,<{http://jabber.org/protocol/pubsub#event}event>,<{urn:xmpp:sm:3}failed>,<{http://jabber.org/protocol/compress}failure>,<{urn:ietf:params:xml:ns:xmpp-sasl}failure>,<{urn:ietf:params:xml:ns:xmpp-tls}failure>,<{http://jabber.org/protocol/feature-neg}feature>,<{urn:ietf:params:xml:ns:xmpp-stanzas}feature-not-implemented>,<{http://etherx.jabber.org/streams}features>,<{jabber:x:data}field>,<{http://jabber.org/protocol/si/profile/file-transfer}file>,<{urn:xmpp:jingle:apps:file-transfer:errors:0}file-not-available>,<{urn:xmpp:jingle:apps:file-transfer:errors:0}file-too-large>,<{http://jabber.org/protocol/activity}fishing>,<{urn:ietf:params:xml:ns:xmpp-stanzas}forbidden>,<{urn:xmpp:forward:0}forwarded>,<{http://jabber.org/protocol/activity}gaming>,<{http://jabber.org/protocol/activity}gardening>,<{http://jabber.org/protocol/geoloc}geoloc>,<{http://jabber.org/protocol/activity}getting_a_haircut>,<{http://jabber.org/protocol/activity}going_out>,<{http://jabber.org/protocol/chatstates}gone>,<{urn:ietf:params:xml:ns:xmpp-stanzas}gone>,<{jabber:component:accept}handshake>,<{http://jabber.org/protocol/activity}hanging_out>,<{urn:xmpp:hashes:2}hash>,<{urn:xmpp:hashes:2}hash-used>,<{http://jabber.org/protocol/activity}having_a_beer>,<{http://jabber.org/protocol/activity}having_a_snack>,<{http://jabber.org/protocol/activity}having_breakfast>,<{http://jabber.org/protocol/activity}having_coffee>,<{http://jabber.org/protocol/activity}having_dinner>,<{http://jabber.org/protocol/activity}having_lunch>,<{http://jabber.org/protocol/activity}having_tea>,<{http://jabber.org/protocol/shim}headers>,<{http://jabber.org/protocol/activity}hiding>,<{http://jabber.org/protocol/activity}hiking>,<{urn:xmpp:jingle:apps:rtp:info:1}hold>,<{urn:ietf:params:xml:ns:xmpp-streams}host-gone>,<{urn:ietf:params:xml:ns:xmpp-streams}host-unknown>,<{http://jabber.org/protocol/xhtml-im}html>,<{urn:xmpp:idle:1}idle>,<{urn:ietf:params:xml:ns:xmpp-streams}improper-addressing>,<{http://jabber.org/protocol/activity}in_a_car>,<{http://jabber.org/protocol/activity}in_a_meeting>,<{http://jabber.org/protocol/activity}in_real_life>,<{http://jabber.org/protocol/chatstates}inactive>,<{urn:xmpp:csi:0}inactive>,<{urn:ietf:params:xml:ns:xmpp-stanzas}internal-server-error>,<{urn:ietf:params:xml:ns:xmpp-streams}internal-server-error>,<{urn:xmpp:jingle:apps:rtp:errors:1}invalid-crypto>,<{urn:ietf:params:xml:ns:xmpp-streams}invalid-from>,<{http://jabber.org/protocol/pubsub#errors}invalid-jid>,<{urn:ietf:params:xml:ns:xmpp-streams}invalid-namespace>,<{http://jabber.org/protocol/pubsub#errors}invalid-options>,<{http://jabber.org/protocol/pubsub#errors}invalid-payload>,<{http://jabber.org/protocol/pubsub#errors}invalid-subid>,<{urn:ietf:params:xml:ns:xmpp-streams}invalid-xml>,<{urn:xmpp:invisible:0}invisible>,<{jabber:client}iq>,<{jabber:component:accept}iq>,<{jabber:server}iq>,<{http://jabber.org/protocol/pubsub#errors}item-forbidden>,<{urn:ietf:params:xml:ns:xmpp-stanzas}item-not-found>,<{http://jabber.org/protocol/pubsub#errors}item-required>,<{urn:ietf:params:xml:ns:xmpp-stanzas}jid-malformed>,<{http://jabber.org/protocol/pubsub#errors}jid-required>,<{urn:xmpp:jingle:1}jingle>,<{http://jabber.org/protocol/activity}jogging>,<{urn:xmpp:json:0}json>,<{http://jabber.org/protocol/commands}malformed-action>,<{http://jabber.org/protocol/pubsub#errors}max-items-exceeded>,<{http://jabber.org/protocol/pubsub#errors}max-nodes-exceeded>,<{urn:ietf:params:xml:ns:xmpp-sasl}mechanisms>,<{urn:xmpp:media-element}media>,<{jabber:client}message>,<{jabber:component:accept}message>,<{jabber:server}message>,<{urn:xmpp:avatar:metadata}metadata>,<{http://jabber.org/protocol/mood}mood>,<{urn:xmpp:jingle:apps:rtp:info:1}mute>,<{http://jabber.org/protocol/nick}nick>,<{http://jabber.org/protocol/si}no-valid-streams>,<{http://jabber.org/protocol/pubsub#errors}nodeid-required>,<{urn:ietf:params:xml:ns:xmpp-stanzas}not-acceptable>,<{urn:ietf:params:xml:ns:xmpp-stanzas}not-allowed>,<{urn:ietf:params:xml:ns:xmpp-stanzas}not-authorized>,<{urn:ietf:params:xml:ns:xmpp-streams}not-authorized>,<{http://jabber.org/protocol/pubsub#errors}not-in-roster-group>,<{http://jabber.org/protocol/pubsub#errors}not-subscribed>,<{urn:ietf:params:xml:ns:xmpp-streams}not-well-formed>,<{http://jabber.org/protocol/offline}offline>,<{http://jabber.org/protocol/activity}on_a_bus>,<{http://jabber.org/protocol/activity}on_a_plane>,<{http://jabber.org/protocol/activity}on_a_train>,<{http://jabber.org/protocol/activity}on_a_trip>,<{http://jabber.org/protocol/activity}on_the_phone>,<{http://jabber.org/protocol/activity}on_vacation>,<{http://jabber.org/protocol/activity}on_video_phone>,<{http://jabber.org/protocol/ibb}open>,<{urn:ietf:params:xml:ns:xmpp-framing}open>,<{http://jabber.org/protocol/activity}other>,<{http://jabber.org/protocol/xdata-layout}page>,<{http://jabber.org/protocol/activity}partying>,<{http://jabber.org/protocol/chatstates}paused>,<{http://jabber.org/protocol/pubsub#errors}payload-required>,<{http://jabber.org/protocol/pubsub#errors}payload-too-big>,<{http://jabber.org/protocol/pubsub#errors}pending-subscription>,<{urn:xmpp:ping}ping>,<{http://jabber.org/protocol/activity}playing_sports>,<{urn:ietf:params:xml:ns:xmpp-stanzas}policy-violation>,<{urn:ietf:params:xml:ns:xmpp-streams}policy-violation>,<{http://jabber.org/protocol/activity}praying>,<{jabber:client}presence>,<{jabber:component:accept}presence>,<{jabber:server}presence>,<{http://jabber.org/protocol/pubsub#errors}presence-subscription-required>,<{urn:xmpp:carbons:2}private>,<{urn:ietf:params:xml:ns:xmpp-tls}proceed>,<{http://jabber.org/protocol/pubsub}pubsub>,<{http://jabber.org/protocol/pubsub#owner}pubsub>,<{http://jabber.org/protocol/bytestreams}query>,<{http://jabber.org/protocol/disco#info}query>,<{http://jabber.org/protocol/disco#items}query>,<{http://jabber.org/protocol/muc#admin}query>,<{http://jabber.org/protocol/muc#owner}query>,<{jabber:iq:last}query>,<{jabber:iq:oob}query>,<{jabber:iq:privacy}query>,<{jabber:iq:private}query>,<{jabber:iq:register}query>,<{jabber:iq:roster}query>,<{jabber:iq:rpc}query>,<{jabber:iq:search}query>,<{jabber:iq:version}query>,<{urn:xmpp:langtrans:items}query>,<{urn:xmpp:sm:3}r>,<{urn:xmpp:reach:0}reach>,<{http://jabber.org/protocol/activity}reading>,<{urn:xmpp:jingle:apps:file-transfer:4}received>,<{urn:xmpp:receipts}received>,<{urn:ietf:params:xml:ns:xmpp-stanzas}recipient-unavailable>,<{urn:ietf:params:xml:ns:xmpp-stanzas}redirect>,<{http://jabber.org/features/iq-register}register>,<{urn:ietf:params:xml:ns:xmpp-stanzas}registration-required>,<{http://jabber.org/protocol/activity}rehearsing>,<{urn:ietf:params:xml:ns:xmpp-streams}remote-connection-failed>,<{urn:ietf:params:xml:ns:xmpp-stanzas}remote-server-not-found>,<{urn:ietf:params:xml:ns:xmpp-stanzas}remote-server-timeout>,<{urn:xmpp:message-correct:0}replace>,<{urn:xmpp:receipts}request>,<{urn:ietf:params:xml:ns:xmpp-streams}reset>,<{urn:ietf:params:xml:ns:xmpp-stanzas}resource-constraint>,<{urn:ietf:params:xml:ns:xmpp-streams}resource-constraint>,<{urn:xmpp:errors}resource-limit-exceeded>,<{urn:ietf:params:xml:ns:xmpp-sasl}response>,<{urn:ietf:params:xml:ns:xmpp-streams}restricted-xml>,<{urn:xmpp:sm:3}resume>,<{urn:xmpp:sm:3}resumed>,<{urn:xmpp:jingle:apps:rtp:info:1}ringing>,<{roster:delimiter}roster>,<{urn:xmpp:rtt:0}rtt>,<{http://jabber.org/protocol/activity}running>,<{http://jabber.org/protocol/activity}running_an_errand>,<{http://jabber.org/protocol/activity}scheduled_holiday>,<{urn:xmpp:sec-label:0}securitylabel>,<{urn:ietf:params:xml:ns:xmpp-streams}see-other-host>,<{urn:xmpp:carbons:2}sent>,<{urn:ietf:params:xml:ns:xmpp-stanzas}service-unavailable>,<{urn:ietf:params:xml:ns:xmpp-session}session>,<{http://jabber.org/protocol/commands}session-expired>,<{http://jabber.org/protocol/rsm}set>,<{http://jabber.org/protocol/activity}shaving>,<{http://jabber.org/protocol/activity}shopping>,<{http://jabber.org/protocol/si}si>,<{http://jabber.org/protocol/activity}skiing>,<{http://jabber.org/protocol/activity}sleeping>,<{urn:xmpp:sm:3}sm>,<{http://jabber.org/protocol/activity}smoking>,<{http://jabber.org/protocol/activity}socializing>,<{urn:xmpp:errors}stanza-too-big>,<{urn:ietf:params:xml:ns:xmpp-tls}starttls>,<{storage:bookmarks}storage>,<{storage:rosternotes}storage>,<{http://jabber.org/protocol/activity}studying>,<{urn:xmpp:features:pre-approval}sub>,<{http://jabber.org/protocol/pubsub#errors}subid-required>,<{urn:ietf:params:xml:ns:xmpp-stanzas}subscription-required>,<{urn:ietf:params:xml:ns:xmpp-sasl}success>,<{http://jabber.org/protocol/activity}sunbathing>,<{http://jabber.org/protocol/activity}swimming>,<{urn:ietf:params:xml:ns:xmpp-streams}system-shutdown>,<{http://jabber.org/protocol/activity}taking_a_bath>,<{http://jabber.org/protocol/activity}taking_a_shower>,<{http://jabber.org/protocol/activity}thinking>,<{urn:xmpp:thumbs:1}thumbnail>,<{urn:xmpp:time}time>,<{urn:xmpp:errors}too-many-stanzas>,<{http://jabber.org/protocol/pubsub#errors}too-many-subscriptions>,<{urn:xmpp:jingle:transports:ibb:1}transport>,<{urn:xmpp:jingle:transports:ice-udp:1}transport>,<{urn:xmpp:jingle:transports:s5b:1}transport>,<{http://jabber.org/protocol/tune}tune>,<{urn:xmpp:blocking}unblock>,<{urn:ietf:params:xml:ns:xmpp-stanzas}undefined-condition>,<{urn:ietf:params:xml:ns:xmpp-streams}undefined-condition>,<{urn:ietf:params:xml:ns:xmpp-stanzas}unexpected-request>,<{urn:xmpp:jingle:apps:rtp:info:1}unhold>,<{urn:xmpp:jingle:apps:rtp:info:1}unmute>,<{http://jabber.org/protocol/pubsub#errors}unsupported>,<{urn:ietf:params:xml:ns:xmpp-streams}unsupported-encoding>,<{urn:ietf:params:xml:ns:xmpp-streams}unsupported-feature>,<{urn:ietf:params:xml:ns:xmpp-streams}unsupported-stanza-type>,<{urn:ietf:params:xml:ns:xmpp-streams}unsupported-version>,<{http://abb.com/protocol/update}update>,<{vcard-temp}vCard>,<{http://jabber.org/protocol/xdata-validate}validate>,<{urn:xmpp:features:rosterver}ver>,<{urn:xmpp:invisible:0}visible>,<{http://jabber.org/protocol/activity}walking>,<{http://jabber.org/protocol/activity}walking_the_dog>,<{http://jabber.org/protocol/activity}watching_a_movie>,<{http://jabber.org/protocol/activity}watching_tv>,<{http://jabber.org/protocol/activity}working_out>,<{http://jabber.org/protocol/activity}writing>,<{http://jabber.org/protocol/muc}x>,<{http://jabber.org/protocol/muc#user}x>,<{http://jabber.org/protocol/rosterx}x>,<{jabber:x:conference}x>,<{jabber:x:data}x>,<{jabber:x:oob}x>,<{urn:xmpp:langtrans}x>,<{vcard-temp:x:update}x>
2019-10-07 10:32:58.174 [WARN ] [sions.caps.EntityCapabilitiesManager] - Failed to discover information for entity 'mrha@busch-jaeger.de/rpc' for node 'https://github.com/qxmpp-project/qxmpp#dOmtXIyaqfcEcu52BgM7enFuDnw='
java.util.concurrent.CompletionException: rocks.xmpp.core.session.NoResponseException: Timeout reached, while waiting on a response for request: IQ-get (680d3d6f-9c8a-488f-8efd-ab20256216cf) to 'mrha@busch-jaeger.de/rpc'
Extension(s):
Identity: []; Features: []
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:292) ~[?:?]
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:308) ~[?:?]
at java.util.concurrent.CompletableFuture.orApply(CompletableFuture.java:1371) ~[?:?]
at java.util.concurrent.CompletableFuture$OrApply.tryFire(CompletableFuture.java:1350) ~[?:?]
at java.util.concurrent.CompletableFuture$CoCompletion.tryFire(CompletableFuture.java:1020) ~[?:?]
at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:474) ~[?:?]
at java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:1977) ~[?:?]
at rocks.xmpp.util.concurrent.CompletionStages.lambda$timeoutAfter$5(CompletionStages.java:113) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: rocks.xmpp.core.session.NoResponseException: Timeout reached, while waiting on a response for request: IQ-get (680d3d6f-9c8a-488f-8efd-ab20256216cf) to 'mrha@busch-jaeger.de/rpc'
Extension(s):
at rocks.xmpp.core.session.XmppSession.lambda$sendAndAwait$7(XmppSession.java:829) ~[?:?]
... 7 more
2019-10-07 10:32:59.204 [hingStatusInfoChangedEvent] - 'freeathome:bridge:b91bb647' changed from OFFLINE (BRIDGE_OFFLINE): XMPP connection lost to ONLINE
2019-10-07 10:32:59.194 [WARN ] [rnal.handler.FreeAtHomeBridgeHandler] - Bridge connected. Updating thing status to ONLINE.
2019-10-07 10:32:59.200 [WARN ] [rnal.handler.FreeAtHomeBridgeHandler] - Connection authenticated
2019-10-07 10:32:59.857 [WARN ] [rnal.handler.FreeAtHomeBridgeHandler] - Bridge connection lost. Updating thing status to OFFLINE.
2019-10-07 10:32:59.865 [WARN ] [rnal.handler.FreeAtHomeBridgeHandler] - Connection lost DISCONNECTED (old status: AUTHENTICATED)
