Can't find HTML of PaperUI
I am new here and start completely new with the topic Smart Home.
I want to customize the HTML of PaperUI or create a new UI. However, I have no idea where to start. Where is the HTML of PaperUI located?
I’ve been looking for two hours now and haven’t found a suitable solution. :frowning:
I have installed openhabian on the raspberry.
Can someone help me?
Hallo,
ich bin neu hier und starte komplett neu mit dem Thema Smart Home.
Ich möchte das HTML von PaperUI anpassen bzw. eine neue UI erstellen. Allerdings habe ich keine Ahnung, wo ich anfangen soll. Wo befindet sich denn das HTML von PaperUI?
Habe jetzt schon zwei Stunden gesucht und keine passende lösung gefunden. :frowning:
Ich habe openhabian auf dem Raspberry installiert.
Kann mir jemand weiterhelfen?
You should take a look at the high customizable HABPanel:
http://docs.openhab.org/configuration/habpanel.html
Thanks. That’ll help me a lot. I must have been blind.
But these are in principle only settings.
But where is the source code generated? Is there an HTML folder for the HabPanel?
PaperUI is used to configure openHAB and install addons, it’s no UI for daily use.
I suggest to try BasicUI. I really enjoy the simplicity of this UI. The UI definition is done by file, a sitemap. If you manage to edit html, you will be able to create a sitemap easily.
http://docs.openhab.org/tutorials/beginner/sitemap.html
Okay. Thanks.
My profession consists of PHP, HTML etc. So I should be able to create a sitemap.
I’ll check it out.
Thank you very much.
