And Chamberlain broke something again.
Quick Google shows they changed the auth method which makes sense since they added guest mode.
2019-08-06 15:42:20.954 [TRACE] [g.openhab.binding.chamberlainmyq.internal.HttpUtil] - Http Response <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[11038945473500641521]</body></html>.
Iām tired of them breaking things. This is the straw that broke the camelās back.
Itās time to install the Linear Z-Wave garage door opener thatās been sitting in my garage for 6+ monthsā¦
And like that itās working again
Crazy, isnāt it?
Does someone have a link to the latest JAR file for this?
What version of OH are you running?
S-
Iāve just started having some issues. Iām running 2.5.0 M3 currently. Iāve tried the binding 1.14.0.M3 and also 2.5.0.201902280358.
Thanks!
My garage door is not working either tonight.
Error from log:
2019-10-18 22:21:35.207 [ERROR] [handler.ChamberlainMyQGatewayHandler] - Requesting URL Failed
java.io.IOException: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@16b56f3(l:/192.168.20.10:36872 <-> r:myqexternal.myqdevice.com/40.112.59.58:443,closed=false)=>HttpChannelOverHTTP@a37552(exchange=HttpExchange@32270c req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@1ee9316(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1fdf73c{s=START}],recv=HttpReceiverOverHTTP@5919b4(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]<-DecryptedEndPoint@1f44374{myqexternal.myqdevice.com/40.112.59.58:443<->/192.168.20.10:36872,OPEN,fill=-,flush=-,to=92/0}->HttpConnectionOverHTTP@16b56f3(l:/192.168.20.10:36872 <-> r:myqexternal.myqdevice.com/40.112.59.58:443,closed=false)=>HttpChannelOverHTTP@a37552(exchange=HttpExchange@32270c req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@1ee9316(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1fdf73c{s=START}],recv=HttpReceiverOverHTTP@5919b4(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]->SocketChannelEndPoint@27153f{myqexternal.myqdevice.com/40.112.59.58:443<->/192.168.20.10:36872,ISHUT,fill=-,flush=-,to=93/0}{io=0/0,kio=0,kro=1}->SslConnection@9d51d0{NEED_WRAP,eio=-1/-1,di=-1}=>HttpConnectionOverHTTP@16b56f3(l:/192.168.20.10:36872 <-> r:myqexternal.myqdevice.com/40.112.59.58:443,closed=false)=>HttpChannelOverHTTP@a37552(exchange=HttpExchange@32270c req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@1ee9316(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1fdf73c{s=START}],recv=HttpReceiverOverHTTP@5919b4(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
at org.openhab.binding.chamberlainmyq.internal.HttpUtil.executeUrl(HttpUtil.java:163) ~[?:?]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQGatewayHandler.request(ChamberlainMyQGatewayHandler.java:366) ~[?:?]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQGatewayHandler.getMyqData(ChamberlainMyQGatewayHandler.java:201) ~[?:?]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQGatewayHandler.refreshDeviceState(ChamberlainMyQGatewayHandler.java:283) ~[?:?]
at org.openhab.binding.chamberlainmyq.handler.ChamberlainMyQGatewayHandler.lambda$0(ChamberlainMyQGatewayHandler.java:274) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@16b56f3(l:/192.168.20.10:36872 <-> r:myqexternal.myqdevice.com/40.112.59.58:443,closed=false)=>HttpChannelOverHTTP@a37552(exchange=HttpExchange@32270c req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@1ee9316(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1fdf73c{s=START}],recv=HttpReceiverOverHTTP@5919b4(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]<-DecryptedEndPoint@1f44374{myqexternal.myqdevice.com/40.112.59.58:443<->/192.168.20.10:36872,OPEN,fill=-,flush=-,to=92/0}->HttpConnectionOverHTTP@16b56f3(l:/192.168.20.10:36872 <-> r:myqexternal.myqdevice.com/40.112.59.58:443,closed=false)=>HttpChannelOverHTTP@a37552(exchange=HttpExchange@32270c req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@1ee9316(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1fdf73c{s=START}],recv=HttpReceiverOverHTTP@5919b4(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]->SocketChannelEndPoint@27153f{myqexternal.myqdevice.com/40.112.59.58:443<->/192.168.20.10:36872,ISHUT,fill=-,flush=-,to=93/0}{io=0/0,kio=0,kro=1}->SslConnection@9d51d0{NEED_WRAP,eio=-1/-1,di=-1}=>HttpConnectionOverHTTP@16b56f3(l:/192.168.20.10:36872 <-> r:myqexternal.myqdevice.com/40.112.59.58:443,closed=false)=>HttpChannelOverHTTP@a37552(exchange=HttpExchange@32270c req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@1ee9316(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1fdf73c{s=START}],recv=HttpReceiverOverHTTP@5919b4(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:684) ~[?:?]
at org.openhab.binding.chamberlainmyq.internal.HttpUtil.executeUrl(HttpUtil.java:146) ~[?:?]
... 11 more
Caused by: java.io.EOFException: HttpConnectionOverHTTP@16b56f3(l:/192.168.20.10:36872 <-> r:myqexternal.myqdevice.com/40.112.59.58:443,closed=false)=>HttpChannelOverHTTP@a37552(exchange=HttpExchange@32270c req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@1ee9316(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1fdf73c{s=START}],recv=HttpReceiverOverHTTP@5919b4(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]<-DecryptedEndPoint@1f44374{myqexternal.myqdevice.com/40.112.59.58:443<->/192.168.20.10:36872,OPEN,fill=-,flush=-,to=92/0}->HttpConnectionOverHTTP@16b56f3(l:/192.168.20.10:36872 <-> r:myqexternal.myqdevice.com/40.112.59.58:443,closed=false)=>HttpChannelOverHTTP@a37552(exchange=HttpExchange@32270c req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@1ee9316(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1fdf73c{s=START}],recv=HttpReceiverOverHTTP@5919b4(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]->SocketChannelEndPoint@27153f{myqexternal.myqdevice.com/40.112.59.58:443<->/192.168.20.10:36872,ISHUT,fill=-,flush=-,to=93/0}{io=0/0,kio=0,kro=1}->SslConnection@9d51d0{NEED_WRAP,eio=-1/-1,di=-1}=>HttpConnectionOverHTTP@16b56f3(l:/192.168.20.10:36872 <-> r:myqexternal.myqdevice.com/40.112.59.58:443,closed=false)=>HttpChannelOverHTTP@a37552(exchange=HttpExchange@32270c req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@1ee9316(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1fdf73c{s=START}],recv=HttpReceiverOverHTTP@5919b4(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.earlyEOF(HttpReceiverOverHTTP.java:338) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1557) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.shutdown(HttpReceiverOverHTTP.java:209) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:147) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:73) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:133) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:155) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:291) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:151) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) ~[?:?]
... 1 more
2019-10-18 22:21:35.290 [ERROR] [handler.ChamberlainMyQGatewayHandler] - An exception occurred while executing a request to the Gateway: 'null'
2019-10-18 18:23:34.037 [ERROR] [handler.ChamberlainMyQGatewayHandler] - An exception occurred while executing a request to the Gateway: ānullā
Not working since early this afternoon. They must have changed something. I am seriously thinking about using a zigbee outlet and relay to connect to the garage door opener. Would be more reliable this.
The HASS guys are saying the v4 API was shut down. The MyQ binding used the v4 API, I guess I have to update the binding to use the v5 API. I will see what I can do.
I was able to create a new 1.x binding that uses the v5 MyQ API. As part of the rewrite, I changed how the items are configured. The configuration is based on the MyQ devices serial number. The āeasiestā way to get the serial numbers is to start openHAB in debug mode and look in the log files for MyQ Devices info. See the photo below for an example.
Here is an new example item file.
Switch LightModule "Light Module On" {myq="CG0670818352" autoupdate="false"}
Switch GarageDoorSwitch "Garage Door Open" {myq="CG0810243E7F"}
Contact GarageDoorContact "Garage Door [%s]" <contact> {myq="CG0810243E7F"}
String GarageDoorString "Garage Door [%s]" {myq="CG0810243E7F"}
Rollershutter GarageDoorShutter "Garage Door Open" {myq="CG0810243E7F"}
I had to remove the āattributeā support as it no longer is available. I have done very little testing with it so it may lock out your account if you use the wrong password. I will try to update the 2.x binding soon. Link to the 1.x binding is below.
Thanks,
Scott
Hi Scott,
I am getting the following error below.
Cookie rejected: ā$Version=0; TS01dfdd0d=01474093dcfa22fb2823d672cc63192e62d4eb9b9d10316b300aaed0a33648b4d2212639395b771b7f17e1f0f5b52801c82055f81d; $Path=/; $Domain=.api.myqdevice.comā. Illegal domain attribute ā.api.myqdevice.comā. Domain of origin: āapi.myqdevice.comā
That is a common error from openHABs http client, it can be ignored.
I recognized that getting the serial number is hard, so I updated the binding to support configuring the items with either the serial number or the name from the myQ app. You can now just use the name from the app, as shown in the screenshot below. It is case sensitive, and must match exactly. I was testing the binding with 2.4 and getting some unexpected errors(it was working though), so I may have to update it some more.
Switch LightModule "Light Module On" {myq="Garage Light"}
Switch LampModule "Lamp Module On" {myq="attic Light"}
Thanks,
Scott
Iāve been having issue with the binding for the past week. Iām receiving error āno MyQ device found with index: 0ā.
Iām currently on binding 1.14.0-snapshot.
Thank you
Hi Scott,
First, Thanks for the hard work! I have the 1.14.0 working with the item names from the MyQ app. I can test the 2.4 jar as well once you post it.
Chris
Hey @scooter_sehā¦ Nice work!!! I just installed the 1.14 binding and I was getting the āCould not connect to MyQ serviceā error. Turned up the logs and saw this error message
19:23:26.254 [TRACE] [nhab.binding.myq.internal.AccountData] - myq accountId: <Truncated>
19:23:26.259 [TRACE] [.openhab.binding.myq.internal.MyqData] - Requesting URL **https://api.myqdevice.com/api/v5.1/Accounts/%ACCOUNT_ID%/Devices**
19:23:26.611 [WARN ] [che.commons.httpclient.HttpMethodBase] - Cookie rejected: "$Version=0; TS01dfdd0d=015ca84662b9d0775c19839e2ae91f43dc9b82bbb60dbffd8b3142384de887496831d26dad562c5ee013e13cac0deda8e0df62c510; $Path=/; $Domain=.api.myqdevice.com". Illegal domain attribute ".api.myqdevice.com". Domain of origin: "api.myqdevice.com"
19:23:26.617 [TRACE] [.openhab.binding.myq.internal.MyqData] - Received MyQ JSON: {"code":"404.401","message":"Not Found","description":"Account not found."}
19:23:26.622 [TRACE] [.openhab.binding.myq.internal.MyqData] - myq ReturnCode: 404.401
19:23:26.629 [TRACE] [.openhab.binding.myq.internal.MyqData] - myq ReturnCode: 404.401
19:23:26.634 [ERROR] [enhab.binding.myq.internal.MyqBinding] - Could not connect to MyQ service
However, the call to https://api.myqdevice.com/api/v5/My/?expand=account had a response that was pointing to a v5 API instead of v5.1
"Devices": {
"href": "http://api.myqdevice.com/api/v5/Accounts/<AccountID>/Devices"
I tried a POSTMAN call to the v5 API from the response and I was getting a proper response without the errors.
Soā¦ Would you be able to update the binding to pick the API URL from response instead of hard coding it? Pretty please?
edit: Corrected the binding version
Hi Scott, thank you for providing the update, appreciate it. Is the binding available in OpenHab repo or do I have to download it here? If I download it here can you please tell me how to upgrade it on the existing binding? I am a little rusty with 1.4 and 2.4 as well and not sure which one to use. I am using 1.4 with latest OpenHab.
TIA
Hey Scott. Seems like Iām in the same boat as Jay. Could not connect, 404.401 error. Thanks.
