Hi community,
from my understanding classes are not available in rules. Therefore I’m using a HashMap
of <key>,<Object>
pairs to store a collection of Objects, like:
"obj01_propertyA" -> GenericItem
"obj01_propertyB" -> GenericItem
"obj01_propertyC" -> Number
"obj02_propertyA" -> GenericItem
This simulates a collection of objects of a class containing 3 poperties of different data types. Then I use lambda functions to build the relative methods for creating a new object or disposing it.
So my code looks like this:
val HashMap<String, Object> myObjs = new HashMap
val Functions$Function4<Map<String, Object>, GenericItem, GenericItem, Number, Boolean> myObj_create = [
objMap,
myItem1,
myItem2,
theNumber |
var String itemKey = myItem1.name
objMap.put(itemKey + "_propertyA", myItem1)
objMap.put(itemKey + "_propertyB", myItem2)
var Number nTmp = new Number
nTmp = theNumber
objMap.put(itemKey + "_propertyC", nTmp)
return true
Item objects are pointers to objects, so I don’t need to create copies of them to put into the HashMap
. But when it comes to the Number
object, I think I cannot directly add the incoming parameter theNumber
to the HashMap, because once exited from the function it doesn’t exist anymore. Then I decided to create a new Number
but I get the follwoing error
Could not invoke constructor: java.lang.Number.Number()
What is it that I’m doing wrong?
thanks.
