Hi everyone, I have a bunch of Xiaomi door/window sensors on external doors and have just made a bunch of rules to turn on lights when doors are opened after dark. Although untested yet, think they will work.
I would like to combine them into 1 rule. Here are the rules.
var Timer sdtimer = null
rule "Open Front Glass Door"
Item Front_Glass_Door_Status changed to OPEN
if(NightTime.state == (ON)) {
SW2_02_1.sendCommand(ON)
SW2_02_2.sendCommand(ON)
if(Rule_Disable != (ON)) {
sdtimer?.cancel
sdtimer = createTimer(now.plusSeconds(300)) [|
SW2_02_1.sendCommand(OFF)
SW2_02_2.sendCommand(OFF)
And this one
var Timer bdtimer = null
rule "Open Back Glass Door"
Item Back_Door_Status changed to OPEN
T2_02_2.sendCommand(ON)
T2_01_1.sendCommand(ON)
bdtimer?.cancel
bdtimer = createTimer(now.plusSeconds(300)) [|
T2_02_2.sendCommand(OFF)
T2_01_1.sendCommand(OFF)
And this one for example
var Timer fdtimer = null
rule "Open Front Door"
Item Front_Door_Status changed to OPEN
SW2_01_1.sendCommand(ON)
SW2_01_2.sendCommand(ON)
fdtimer?.cancel
fdtimer = createTimer(now.plusSeconds(300)) [|
SW2_01_1.sendCommand(OFF)
SW2_01_2.sendCommand(OFF)
The sensors are all members of a group so I think I could use
when member of group Door_Sensors changed to OPEN
as the trigger, but really have little idea what to do after that. From what others have shown me over the last few days, I need if triggering.item == something do xyz. but rather than use multiple if statements I would like to use the switch case but have no idea how.
as always, any help appreciated.
James
I have created a rule for this. The idea bhind my rule is, that if i open a door a light is switched on and if the door is closed the light is switched off after a certain amount of time.
Contacts , corresponding lights and switchoff time is stored in an array.
// Imports
import org.eclipse.smarthome.model.script.ScriptServiceUtil
import java.util.Map
import java.util.List
// Global constants and variables
val IDX_TIMEOUT = 0 // Timeout value in seconds. After this time the target should change from ON-State to OFF-State
val IDX_TARGET = 1 // Name of the target item
val EDGE_NOTHING = 0
val EDGE_RISING = 1
val EDGE_FALLING = 2
val Map<String, List<String>> actionMap = newHashMap (
"GF_GT_Multisensor" -> newArrayList("300", "GF_GT_CeilingLight_State"),
"GF_HW_CellarDoorContact" -> newArrayList("300", "CE_EC_DoubleSwitch_State01"),
"CE_EC_MotionSensor" -> newArrayList("300", "CE_EC_DoubleSwitch_State01"),
"CE_LD_Multisensor" -> newArrayList("300", "GF_HW_Stairlight_State"),
"GF_BA_Multisensor" -> newArrayList("300", "GF_BA_CeilingRGB_State"),
"PR_ME_MotionSensor" -> newArrayList("300", "PR_ME_WallLight_State")
val Map<String, Timer> actionTimer = newHashMap
// Rule: Triggered Lighting
rule "Triggered Lighting"
Member of gPIRTrigger changed or
Member of gContactTrigger changed
val String ruleIdentifier = "userule.TriggeredLighting"
var Integer edgeKey = EDGE_NOTHING
var String triggerKey = triggeringItem.name.substring(0, triggeringItem.name.lastIndexOf('_'))
var String targetKey = actionMap.get(triggerKey).get(IDX_TARGET)
var GenericItem targetItem = ScriptServiceUtil.getItemRegistry.getItem(targetKey) as GenericItem
var Integer timeoutValue = Integer::parseInt(actionMap.get(triggerKey).get(IDX_TIMEOUT))
// Determine if we have the rising edge or the falling edge
if (((triggeringItem instanceof ContactItem) && (triggeringItem.state == OPEN)) || ((triggeringItem instanceof SwitchItem) && (triggeringItem.state == ON))) {
edgeKey = EDGE_RISING
} else if (((triggeringItem instanceof ContactItem) && (triggeringItem.state == CLOSED)) || ((triggeringItem instanceof SwitchItem) && (triggeringItem.state == OFF))) {
edgeKey = EDGE_FALLING
// Now we know what to do
switch edgeKey {
case EDGE_RISING : {
actionTimer.get(targetKey)?.cancel()
targetItem.sendCommand(ON)
logInfo(ruleIdentifier, "Rising edge detected: Running timer canceled and target {} set to ON!", targetKey)
case EDGE_FALLING : {
actionTimer.put(targetKey, createTimer(now.plusSeconds(timeoutValue)) [ |
actionTimer.put(targetKey, null)
targetItem.sendCommand(OFF)
logInfo(ruleIdentifier, "Target {} has been set to OFF after {} seconds!", targetKey, timeoutValue.toString)
logInfo(ruleIdentifier, "Falling edge detected: Target {} will be set to OFF after {} seconds!", targetKey, timeoutValue.toString)
default : {
logError(ruleIdentifier, "Argh, this line should never be executed - Something must have gone wrong!")
may this is a little inspiration. Do not hestitate and ask questions.
