Good morning
This is my little contribution…
My Story
I’ve been trying to control my White Westinghouse air conditioner.
One thing to know is that usual remotes controls, for TV, HI-FI, … send a signal for each key pressed (often in loops while the key is pressed). An air conditioning remote often displays information about the parameters selected. But of course parameters can be changed on the remote while the unit is out of reach, which could lead to synchronization problems between the display and the unit in some cases if it worked like the TV remotes. This implies that when such a remote sends a signal, it sends the whole parameters set.
Something that with LIRC would have been quite tedious, then searching the internet I found an alternative solution that thanks to EXEC I was able to execute with the help of a very interesting tutorial…
The tool I use is based on pigpio library:
Download link:
(On the website explains how to use the code, recording them and their use)
In my case, my air has the automatic function (depending on the internal and external temperature, know if the room need heating or cooling), this solves a lot of things because I only have to record the temperatures while the (auto) function is fixed.
For this record from the minimum temperature 17 ºC to 30 ºC, also record the function on (at 24 º C as it is the recommended temperature of use) and the shutdown function.
With the help of the following tutorial, base all my code
Let’s get started…
Things
Thing exec:command:ac [
command="/etc/openhab2/scripts/irrp.py -p -g23 -f /etc/openhab2/scripts/Auto24 %2$s",
interval=0,
autorun=true]
Thing exec:command:actemp [
interval=0,
autorun=true]
One things for on/off fuction and the other for set temperature
Items
Switch Aireacondicionado
String PlaceHolder ""
Switch Remote_Send { channel="exec:command:ac:run" }
String Remote_Send_Args { channel="exec:command:ac:input" }
String Remote_Send_Out { channel="exec:command:ac:output" }
String PlaceHolder1 ""
String Remote_Send_Argstemp { channel="exec:command:actemp:input" }
Group Thermostat "Aire acondicionado"
Number Aireacondicionado_numero "Temperatura Aire [%.1f ºC]" (Thermostat)
Number Aireacondicionado_setpoint "Target [%.1f ºC]" (Thermostat)
Sitemap
sitemap demo label="Menú"
{ Frame label="Habitación" {
Switch item=Aireacondicionado label="Aire" icon="ac"
Setpoint item=Aireacondicionado_setpoint minValue=17 maxValue=30 step=1 icon="temperature1" visibility=[Aireacondicionado==ON]
Well and the rules, this section is totally based on @josar 's tutorial, total recognition of his work.
import java.util.concurrent.locks.ReentrantLock
val ReentrantLock transmitter = new ReentrantLock
rule "Aire on/off"
Item Aireacondicionado received command
logInfo("Prueba", "Módulo " + triggeringItem.name + " to " + receivedCommand)
try {
transmitter.lock()
if(receivedCommand == ON){
Remote_Send_Args.sendCommand("on")
else {
Remote_Send_Args.sendCommand("off")
while(Remote_Send.state != OFF){
Thread::sleep(100)
Thread::sleep(400)
logInfo("Prueba", Remote_Send_Out.state.toString.replaceAll("\r|\n"," Ejecutado ") )
}catch(Throwable t) {}
finally {
// Free the resource for the next call.
transmitter.unlock()
rule "Set 24ºC - ON"
Item Aireacondicionado changed to ON
Aireacondicionado_setpoint.sendCommand(24)
rule "Set 24ºC - OFF"
Item Aireacondicionado changed to OFF
rule "Set Temperatura"
Item Aireacondicionado_setpoint received command
if (Aireacondicionado.state == ON) {
Thread::sleep(2000)
logInfo("Prueba", "Temperatura " + triggeringItem.name + " to " + receivedCommand)
try {
transmitter.lock()
var Number TT = Aireacondicionado_numero.state
Remote_Send_Argstemp.sendCommand( TT )
finally {
rule "Inicio Aire - On/Off"
System started
createTimer(now.plusSeconds(120)) [|
if (Aireacondicionado.state == NULL) Aireacondicionado.postUpdate(OFF)
rule "Inicio Aire - Setpoint"
System started
createTimer(now.plusSeconds(130)) [|
if (Aireacondicionado_setpoint.state == NULL) Aireacondicionado_setpoint.sendCommand(24)
And this is it.
Please if there is any doubt or mistake, let me know.
I’m not a programmer or anything like that, I started all this a month ago so I can fail, your comments are welcome.
I know there’s a lot of extra code that could be simplified but I still haven’t learned yet, again your comments are welcome.
Thank you!
