I’ve not done it with a cell widget so don’t know what options are and are note available. I’ve always been under the impression that cell widgets are intended to go inside Card or List Item widgets and not stand on their own.
But the oh-input-card example and oh-input-item example on the marketplace meet all of your requirements. If nothing else they might give some ideas what might be going wrong.
It’s always better if you don’t trim information like this. If you’re having trouble identifying a problem, maybe it isn’t where you think it is, and leaving information out just makes it harder for someone else to help. In deed, in this case, there is no such thing as a cell component that includes any input element, so I have to assume that you have this configured in an oh-input-card not in a “cell” but I can’t see that because you trimmed it off. These are very different components.
Is your date item currently NULL. There are have been other issues with input elements starting with NULL state items. Try just using a quick script to send any valid date to the item, and see if your component then works.
When discussing widget components, cell and card have two different meanings in OH. So it helps to keep them distinct in your descriptions:
It does now that I see the whole code
Hmmm…that’s strange. Your configuration works for me on 4.1.1 with a test DateTime item, and I see no reason it shouldn’t work generically. So, your item state is still likely the problem. The biggest clue is still:
If the item state were properly getting to the widget it should show before you ever click on the input.
Do you see any errors in the OH logs when you load the widget or click on the input?
Do you see any errors in the browser console?
Your item has a proper date time format, but is it a DateTime item or is it a string item with a datetime string for a state?
What do you have for the stateDescription metadata for this item?
there is no error or warn inside the logs, if I load the widget or click the send button.
There even isn’t a XHR-call while clicking and no errors in the JS-console.
The item definition is type: DateTime and
stateDescription has pattern: "%1$td.%1$tm, %1$tH:%1$tM"
I can - however replace placeholder: -- with placeholder: =items.EMS_SpMaStartpunkt.displayState and now I see at least the current state - but still no update after clicking.
Oh, thanks! That did it.
I thought “use display state” was for showing information, but I should’ve read the subline “Use the formatted state as the value for the input control”…
