Description
This widget controls Denon/Marantz AVR devices and works in light mode as well as in dark mode.
Prerequisites:
- OH3.4 or higher
- Denon/Marantz binding installed
- Denon/Marantz device (Thing, Channels, Items) fully set up according to binding instructions
- The widget is designed for Telnet mode to be configured in the Denon/Marantz Thing
If you are on an earlier release than OH3.4, please make sure you update the widget code as follows:
Replace
text: =@props.xxxxx
by
text: =items[props.xxxxx].displayState || items[props.xxxxx].state
You’d need to update the widget code on these 3 spots to work for you.
Recommendation for best use of widget:
Link items to the “Send a Custom Command” channel:
Add respective options to item’s metadata (e.g. Input source, surround program):
That’s it.
Have fun with the widget.
maxmaximax
Changelog
Version 0.1
- initial release
Resources
uid: Denon AVR v01
tags: []
props:
parameters:
- description: Device name
label: Title
required: false
type: TEXT
- context: item
description: Item for Power Channel
label: Power
required: false
type: TEXT
- context: item
description: Item for Input Source
label: Input Source
required: false
type: TEXT
- context: item
description: Item for Mute
label: Mute
required: false
type: TEXT
- context: item
description: Item for selected Surround Mode
label: Get Surround Mode
required: false
type: TEXT
- context: item
description: Item for Volume (dB)
label: Volume (dB)
required: false
type: TEXT
- description: Set minimum Volume
label: Minimum Volume
required: false
type: INTEGER
- description: Set maximum Volume
label: Maximum Volume
required: false
type: INTEGER
- description: Set Volume Stepsize
label: Volume Stepsize
required: false
type: DECIMAL
- context: item
description: Item for sending a command for Quick Select options 1,2,3
label: Send Quick Select Command
required: false
type: TEXT
- context: item
description: Item for sending a command for Surround Program
label: Send Surround Program Command
required: false
type: TEXT
- context: item
description: Item for sending a command for Tuner Preset Number
label: Send Tuner Preset Number Command
required: false
type: TEXT
- context: item
description: Item for sending a command for Tuner Preset Up/Down
label: Send Tuner Preset Up/Down Command
required: false
type: TEXT
parameterGroups: []
timestamp: Jan 15, 2023, 11:08:14 AM
component: f7-card
title: =props.title
outline: true
class:
- no-padding
style:
noShadow: false
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.3)
slots:
default:
- component: f7-row
class:
- margin-top-half
- margin-left-half
- margin-right-half
- margin-bottom-half
slots:
default:
- component: f7-col
width: "25"
slots:
default:
- component: f7-segmented
class:
- segmented-strong
style:
--f7-segmented-strong-padding: 0px
--f7-segmented-strong-between-buttons: 5px
--f7-segmented-strong-button-font-weight: 300
--f7-segmented-strong-bg-color: transparent
--f7-segmented-strong-button-hover-bg-color: rgba(var(--f7-theme-color-rgb), 0.07)
--f7-button-fill-hover-bg-color: var(--f7-theme-color)
--f7-button-border-radius: 4px
--f7-button-padding-vertical: 0px
--f7-button-padding-horizontal: 0px
slots:
default:
- component: oh-button
outline: true
class:
- padding-top-half
- display-flex
- flex-direction-column
text: ON/OFF
action: toggle
actionItem: =props.itemPower
actionCommand: ON
actionCommandAlt: OFF
icon-f7: power
iconSize: 15
fill: "=(items[props.itemPower].state === 'ON') ? true : false"
style:
--f7-button-border-width: 1px
--f7-button-border-color: var(--f7-card-outline-border-color)
height: auto
font-size: 8px
- component: f7-col
width: "50"
large: "45"
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
width: "25"
slots:
default:
- component: f7-icon
class:
- float-left
material: input
style:
color: "=(items[props.itemPower].state === 'ON') ? 'var(--f7-theme-color)' : 'var(--f7-card-outline-border-color)'"
- component: f7-col
width: "75"
slots:
default:
- component: Label
class:
- float-right
text: =@props.itemInputSource
style:
white-space: nowrap
overflow: hidden
text-overflow: elipsis
font-size: 12px
color: "=(items[props.itemPower].state === 'ON') ? '' : 'var(--f7-card-outline-border-color)'"
- component: f7-row
config: {}
slots:
default:
- component: f7-col
width: "25"
slots:
default:
class:
- float-left
material: graphic_eq
style:
- component: f7-col
width: "75"
slots:
default:
- component: Label
class:
- float-right
text: =@props.itemSurroundMode
style:
white-space: nowrap
overflow: hidden
font-size: 12px
- component: f7-row
config: {}
slots:
default:
- component: f7-col
width: "25"
slots:
default:
class:
- float-left
f7: speaker_2
style:
- component: f7-col
width: "75"
slots:
default:
- component: Label
class:
- float-right
text: =@props.itemVolumedb
style:
white-space: nowrap
overflow: hidden
font-size: 12px
- component: f7-col
width: "25"
slots:
default:
visible: "=(items[props.itemPower].state === 'ON') ? true : false"
class:
- segmented-strong
style:
slots:
default:
text: MUTE
action: toggle
actionItem: =props.itemMute
actionCommand: ON
icon-f7: speaker_slash
iconSize: 15px
fill: "=(items[props.itemMute].state === 'ON') ? true : false"
outline: true
class:
- display-flex
- padding-top-half
style:
font-size: 8px
height: auto
- component: f7-card
visible: "=items[props.itemInputSource].state === 'TUNER' && items[props.itemPower].state === 'ON' ? true : false"
outline: true
- component: f7-row
slots:
default:
- component: f7-col
width: "10"
slots:
default:
visible: true
noShadow: true
class:
- margin-left-half
- margin-right-half
style:
display: grid
grid-template-columns: repeat(1, 1fr)
gap: 5px
--f7-button-font-size: 8px
--f7-button-text-color: "=themeOptions.dark === 'light' ? 'black' : 'white'"
--f7-button-outline-border-width: 1px
--f7-button-font-weight: 300
slots:
default:
- component: oh-repeater
sourceType: itemStateOptions
itemOptions: =props.itemSendTunerPresetUpDownCommand
for: option
fragment: true
slots:
default:
icon-f7: "=loop.option.label === 'UP' ? 'chevron_up' : 'chevron_down'"
iconSize: 15px
action: command
actionItem: =props.itemSendTunerPresetUpDownCommand
actionCommand: =loop.option.value
outline: true
style:
height: auto
- component: f7-col
width: "80"
slots:
default:
visible: true
noShadow: true
class:
- margin-left-half
- margin-right-half
style:
display: grid
grid-template-columns: repeat(4, 1fr)
gap: 5px
slots:
default:
itemOptions: =props.itemSendTunerPresetNumberCommand
for: option
fragment: true
slots:
default:
text: =loop.option.label
action: command
actionItem: =props.itemSendTunerPresetNumberCommand
outline: true
style:
height: auto
outline: true
- component: f7-row
slots:
default:
- component: f7-col
width: "50"
large: "50"
slots:
default:
- component: Label
class:
- margin-left-half
- text-align-center
text: Source & Surround
style:
font-size: 12px
- component: f7-col
width: "50"
large: "50"
slots:
default:
- component: Label
class:
- margin-right-half
- text-align-center
text: Quick Select
style:
font-size: 12px
- component: f7-row
class:
slots:
default:
- component: f7-col
width: "50"
large: "50"
slots:
default:
visible: true
class:
- margin-left-half
style:
--f7-button-text-color: var(--f7-theme-color)
--f7-button-padding-vertical: 5px
slots:
default:
sourceType: array
for: SourceSurroundSetting
in:
- icon: input
option: source
- icon: graphic_eq
option: surround
fragment: true
slots:
default:
icon-material: =loop.SourceSurroundSetting.icon
iconSize: 15px
fill: "=vars[loop.SourceSurroundSetting.option] || vars[loop.SourceSurroundSetting.option] === undefined ? false : true"
outline: true
class:
- display-flex
style:
height: 27px
action: variable
actionVariable: =loop.SourceSurroundSetting.option
actionVariableValue: "=vars[loop.SourceSurroundSetting.option] || vars[loop.SourceSurroundSetting.option] === undefined ? false : true"
- component: f7-col
width: "50"
large: "50"
slots:
default:
class:
- margin-right-half
style:
--f7-button-font-size: 12px
slots:
default:
itemOptions: =props.itemSendQuickSelectCommand
for: option
fragment: true
slots:
default:
action: command
actionItem: =props.itemSendQuickSelectCommand
outline: true
style:
height: 27px
visible: "=vars.source === false && items[props.itemPower].state === 'ON' ? true : false"
outline: true
noShadow: true
class:
- margin-left-half
- margin-right-half
style:
display: grid
gap: 5px
--f7-button-text-transform: uppercase
slots:
default:
itemOptions: =props.itemInputSource
for: option
fragment: true
slots:
default:
action: command
actionItem: =props.itemInputSource
fill: "=(loop.option.value == items[props.itemInputSource].state) ? true : false"
outline: true
style:
height: auto
visible: "=vars.surround === false && items[props.itemPower].state === 'ON' ? true : false"
outline: true
noShadow: true
class:
- margin-left-half
- margin-right-half
style:
display: grid
gap: 5px
slots:
default:
itemOptions: =props.itemSendSurroundProgramCommand
for: option
fragment: true
slots:
default:
action: command
actionItem: =props.itemSendSurroundProgramCommand
outline: true
style:
height: auto
- component: f7-row
class:
- margin-left-half
- margin-right-half
- margin-top-half
slots:
default:
- component: f7-col
slots:
default:
- component: oh-slider-card
outline: true
item: =props.itemVolumedb
min: =props.MinimumVolume
max: =props.MaximumVolume
step: =props.VolumeStepsize
scaleSteps: 4
scale: true
unit: dB
label: true
