All functionality in this beta version is now available in the snapshot version of openHAB. If you wish to use this enhanced version, please upgrade to the snapshot, or the next milestone version 3.3.0.M5 as soon as it is available. You can still manually download the beta binding jar from this post and drop it in your addons folder if you do not wish to upgrade at this point.
ELRO Connects Binding
The ELRO Connects binding provides integration with the ELRO Connects smart home system.
The system uses a Wi-Fi Hub (K1 Connector) to enable communication with various smart home devices.
The devices communicate with the hub using 868MHz RF.
The binding communicates with the ELRO Connects system and K1 Connector using UDP in the local network.
Optionally, the Elro Connects account can be used to retrieve the available K1 Connectors with their properties from the ELRO Connects cloud.
The binding exposes the devices’ status and controls to openHAB.
Console commands support adding and configuring devices on the hub.
The K1 connector allows setting up scenes through a mobile application.
The binding supports selecting a specific scene.
Many of the sensor devices are battery powered.
Supported Things
The ELRO Connects supported device types are:
- Elro Connects account:
account
- K1 connector hub:
connector
- Smoke detector:
smokealarm
- Carbon monoxide detector:
coalarm
- Heat detector:
heatalarm
- Water detector:
wateralarm
- Windows/door contact:
entrysensor
- Motion detector:
motionsensor
- Temperature and humidity monitor:
temperaturesensor
- Plug-in switch:
powersocket
account
is a bridge thing type that will allow allow automatic discovery and configuration of the available K1 connectors on the specified ELRO Connects account.
This bridge is optional.
It is used to discover the required K1 connector hub(s), using a call to the ELRO Connects cloud.
Without the account
bridge, the connector
bridge needs to be defined manually.
If no account
bridge is defined, all communication between openHAB and the ELRO Connects system will be local, not using the ELRO Connects cloud.
The connector
is the bridge thing representing a K1 connector.
All other things are connected to the connector
bridge.
Testing was only done with smoke and water detectors connected to a K1 connector.
The firmware version of the K1 connector was 2.0.3.30 at the time of testing.
Discovery
The ELRO Connects account
cannot be auto-discovered.
The account
bridge is optional, but helpful to discover the K1 connectors on an ELRO Connects account and configure them.
All online K1 connectors configured on the account will be discovered.
Notice that K1 connectors in another network than the LAN will also get discovered, but will not go online when accepted from the inbox without adjusting the connector
configuration (set the IP address).
The K1 connector connector
will be auto-discovered when an ELRO Connects account
bridge has been created and initialized.
It can also be configured manually without first setting up an account
bridge and linking it to that account
bridge.
Once the bridge thing representing the K1 connector is correctly set up and online, discovery will allow discovering all devices connected to the K1 connector (as set up in the Elro Connects app).
If devices are outside reliable RF range, devices known to the K1 hub will be discovered but may stay offline when added as a thing.
Alarm devices can still trigger alarms and pass them between each other, even if the connection with the hub is lost.
It will not be possible to receive alarms and control them from openHAB in this case.
Thing Configuration
Parameter | Advanced | Description |
username |
Username for the ELRO Connects cloud account, required | |
password |
Password for the ELRO Connects cloud account, required |
K1 connector hub
connectorId |
Required parameter, should be set to ST_xxxxxxxxxxxx with xxxxxxxxxxxx the lowercase MAC address of the connector. It will be discovered when an account bridge has been initialized. This parameter can also be found in the ELRO Connects mobile application |
ipAdress |
Y | IP address of the ELRO Connects K1 Connector, not required if connector and openHAB server in same subnet |
refreshInterval |
Y | This parameter controls the connection refresh heartbeat interval. The default is 60s |
legacyFirmware |
Y | Flag for legacy firmware, should be set to true if ELRO Connects K1 Connector firmware has version lower or equal to 2.0.14. If the connector is discovered from the account, this parameter will be set automatically. The default is false |
Devices connected to K1 connected hub
Parameter | Description |
deviceId |
Required parameter, set by discovery. For manual configuration, use the ´elroconnects devices´ console command to get a list of available devices. It should be a number |
Channels
The account
bridge thing does not have any channels.
K1 connector hub
The connector
bridge thing has only one channel:
Channel ID | Item Type | Access Mode | Advanced | Description |
scene |
String | RW | current scene |
The scene
channel has a dynamic state options list with all possible scene choices available in the hub.
The connector
also has an alarm
trigger channel that will get triggered when the alarm is triggered for any device connected to the hub.
This will also trigger if an alarm on a device goes off and the thing corresponding to the device is not configured in openHAB.
The payload for the trigger channel is the deviceId
for the device triggering the alarm.
Smoke, carbon monoxide, heat and water alarms
All these things have the same channels:
Channel ID | Item Type | Access Mode | Description |
muteAlarm |
Switch | RW | mute alarm |
testAlarm |
Switch | RW | test alarm |
signal |
Number | R | signal strength between 0 and 4, higher is stronger |
battery |
Number | R | battery level in % |
lowBattery |
Switch | R | on for low battery (below 15%) |
Each also has a trigger channel, resp. smokeAlarm
, coAlarm
, heatAlarm
and waterAlarm
The payload for these trigger channels is empty.
Door/window contact
The entrysensor
thing has the following channels:
entry |
Contact | R | open/closed door/window |
signal |
battery |
lowBattery |
The entrysensor
thing also has a trigger channel, entryAlarm
Motion sensor
The motionsensor
motion |
Switch | R | on when motion detected |
signal |
battery |
lowBattery |
The motionsensor
thing also has a trigger channel, motionAlarm
The temperaturesensor
temperature |
Number:Temperature | R | temperature |
humidity |
Number:Dimensionless | R | device status |
signal |
battery |
lowBattery |
Plug-in switch
The powersocket
powerState |
Switch | RW | power on/off |
Console Commands
A number of console commands allow management of the Elro Connects K1 hub and devices.
This makes it possible to add new devices to the hub, remove, rename or replace devices, without a need to use the Elro Connects mobile application.
The full syntax and help text is available in the console using the elroconnects
command.
Full Example
.things:
Bridge elroconnects:connector:myhub [ connectorId="ST_aabbccddaabbccdd", refreshInterval=120 ] {
smokealarm 1 "LivingRoom" [ deviceId="1" ]
coalarm 2 "Garage" [ deviceId="2" ]
heatalarm 3 "Kitchen" [ deviceId="3" ]
wateralarm 4 "Basement" [ deviceId="4" ]
entrysensor 5 "Back Door" [ deviceId="5" ]
motionsensor 6 "Hallway" [ deviceId="6" ]
temperaturesensor 7 "Family Room" [ deviceId = "7" ]
powersocket 8 "Television" [ deviceId = "8" ]
.items:
String Scene {channel="elroconnects:connector:myhub:scene"}
Number BatteryLevel {channel="elroconnects:smokealarm:myhub:1:battery"}
Switch AlarmTest {channel="elroconnects:smokealarm:myhub:1:test"}
.sitemap:
Text item=Scene
Number item=BatteryLevel
Switch item=AlarmTest
Example trigger rule:
rule "example trigger rule"
Channel 'elroconnects:smokealarm:myhub:1:smokeAlarm' triggered
logInfo("Smoke alarm living room")
Changelog
Version 0.1
- initial (beta) release
Version 1.0
- released in OH 3.3M3
Version 1.1
- Added signal strength device channel
- Added K1 hub alarm channel with originating device ID payload
- Added console commands to get devices on K1 hub and refresh device status
- Added console commands to add, remove, rename, replace devices
Version 1.2
- Added account bridge, support automatic discovery of hubs
- Support older firmwares
