The Google Maps embedded by URL API requires an API key, has the potential to cost, and doesn’t show live traffic conditions. So I created this Waze Maps widget.
Waze doesn’t require an API key, but please do not refresh too fast or your IP may get temporarily banned.
Unfortunately their API only supports lat,lon, but you can use the map in Settings → Regional Settings to easily find the coordinates you want to use for the center point.
Unlike the Google Maps widget, this will not show driving directions and the time it will take. However, stay tuned for a rule template to pull the time to drive between two points and put that into an Item. It only shows the current traffic conditions and alerts around the center point.
Header and footer text are optional.
There is a companion rule template that uses Waze to calculate the travel time and distance between two points. See Driving Time and Distance using Waze [5.2.0.0;5.9.9.9].
Changelog
Version 0.1
- initial release
Resources
uid: rlk_waze
tags: []
props:
parameters:
- description: Center point in latitude,longitude format
label: Center
required: true
type: TEXT
context: location
- default: "11"
description: The initial map zoom level, between 3 (least magnification) and 17.
Defaults to 11.
label: Initial Zoom
required: false
type: INTEGER
min: 3
max: 17
- default: ""
description: Title for the widget
label: Widget Title
required: false
type: TEXT
- default: "500"
description: Height in pixels to make the card (defaults to 500)
label: Card Height
required: false
type: TEXT
- default: ""
description: Text to put into the footer of the widget
label: Footer
required: false
parameterGroups: []
timestamp: Jan 9, 2025, 11:40:54 AM
component: oh-webframe-card
height: =props.height
src: ="https://embed.waze.com/iframe?zoom="+props.zoom+"&lat="+props.center.split(',')[0].trim()+"&lon="+props.center.split(',')[1].trim()+"&ct=livemap&pin=1"
title: =props.title
footer: =props.footer
