After upgrading from OH4.0.1 to OH4.0.2 using openhabian-config I get tenthousands of errors/warnings/stacktraces during openhab service start. Loading file based rules repeats endless.
But the most important problem seems to be the following:
Maybe its due to a 3rd party KAR add-on still depending on that version?
jUPnP comes preinstalled and shouldn’t be downloaded.
If you use any other version as 2.7.1.OH1 you also risk running into the CPU issues again.
I tried your solution but my problem is, that even if I’m on a Raspberry PI 4 with 8 GB RAM openhab is due to thousands of throws exceptions so slow, that I’m not able to install any binding. So I downgraded to OH 4.0.1.
Hopefully, this issue is solved in one of the next releases.
for the fun of it, I removed the eBus snapshot, clean cache, update to 4.0.2 and OH is working. Copied the snapshot back, OH still working but the eBus addon does remain in handler_error. So I think we should discuss this in the @csowada eBus thread and close this one.
any idea how the prevent this dependency? In the past the repository line was commented out. But now it will not compile without this line.Or has this something to do with the CPU fixes for 4.0.2?
You can skip declaration of repository element if you move it to Karaf Maven plugin configuration. At runtime you can rely on jupnp feature name without version. I might bring you PR for that.
