In lots of cases, they could just remain deprecated forever. But shunted into a separate menu with warnings not to use these but they are kept for legacy purposes. That could split the difference, allowing use to gradually change the supported blocks for consistency sake but not break too many things in the long run.
But even with this approach we need to be judicious because there are only so many different versions of blocks we can create.
Honestly, I would vote for option 1, or maybe 3, definitely not 2.
I think the green color should be clear enough that it represents a string, and is a reference to an item as represented by its identifier, which is its name (a string). The same goes for things, referenced by their UID.
Itâs okay to call it âitemâ even if itâs not the entire item structure as most API calls would accept the identifier as representing the item.
The issue you ran into is actually a pretty common one and not specific to this âitemâ block. When you use variables you lose the type information. So when you have a loop and define a variable to be the iterator, you can basically use this variable anywhere even if itâs not the right type.
Thatâs why I designed it to be just âitemâ (and the green color to denote itâs just the name, thus a string, but you can use that to perform stuff on items by just referencing its name, so itâs basically the item).
Ok, thanks Yannick. At least with the better typed checks, it is more uncommon to make mistakes.
Variables are really a pity here, I agree, as they lose information about the type and you really need to know what you are doing.
This seems to be the most sensible solution. Usually you wouldnât use UTC unless youâre not sure where in the world you are and where your server is. For instance see this: Use home's location timezone instead of client's one in UI · Issue #1537 · openhab/openhab-webui · GitHub
When youâre away from home and in a different timezone the charts in the UI are wrong because the API offers UNIX timestamps and they depend on the timezone youâre in.
For rules, this shouldnât be a problem because the server isnât changing timezones so the local time is reliable.
Hello, Iâve been looking for one of the simplest solutions for a long time, switching on/off, according to the scheduled time with correction, but I canât find it.
I wanted to use Blockly. Habpanel. Basic Ui. (for setting any time on the fly)
It is necessary to turn on/off the lamp, according to a pre-set or adjustable time:
For example: 8:10 AM on - 8:40 AM off, while I would like to edit it manually in Habpanel or in Basic UI.
I tried to write rules in Blockly, but there is a problem of choosing the time of hours and minutes.
I created items, tried to do state item - time in the Blockly rules, nothing works.
Please tell me the solution, moreover, I believe that this is one of the most important functions to be added to Demo rules
I noticed one problem in the work of Docker (Synology) Openhab Frontal, the time is always UTC, but in Openhab, Synology, the time is correct UTC +7
First of all this is the wrong thread to ask that question as this is about adding new features to Blockly, please open a new thread and secondly I honestly have no idea what you want to achieve.
First of all, thank you for that idea and the effort so
A few hints on designing block:
When designing blocks I try to keep the number of different blocks as low as possible. So I would recommend combining the blocks by providing dropdowns get (location, equipment, pointâŠ) of â Item or Item is a (location, equipment, point)
Note that the words should be lowercase
Note that these block most likely belong to the item-category, so they should be orange.
If you want, you could provide these as blockly library and upload it to the marketplace.
If you feel we should add this to the core blocks, please create an issue in github and I can plan it in if more people feel that it would make sense to have them in 4.x.
Thanks for all the good adviceâŠi will take some time and beautify it a bit.
Personally I think that this would be nice to have in the core as from my example it helps still transforming rules etc. more from OH2 (groupsâŠ) towards OH3 and the semantic model.
So i will open an issue (after i am done with making things proper) and you can decide.
But this is Blockly for openHAB, so I assumed openHAB convention trumps Blockly convention (as long as it didnât prevent Blockly from working in the first place).
I personally donât particularly care - I know just enough about openHAB to understand whatâs going on - but for novices I would suspect itâd make more sense if all of openHAB presented the same conventions, to prevent confusion.
Can you create an issue in github please. It might make sense then to add (a) more generic blocks that allow(s) to choose via a dropdown what should be returned. I am not sure though if it makes sense to add the file parameter. There is a load of ephemeris functions and we would have to come up with a clever block design to avoid the same amout blocks here. Also it would probably require blocks that change the appearance (so called mutators) based on the choice of function you select.
Maybe someone takes the time and comes up with a clever block design that only requires very few blocks while covering most of these functionsâŠ
I made up some blocks already which I thought they would be useful.
I tried to implement a mutator already in another library but failed. I donât know if this is even possible in yamlâŠ
