Failed installing 'openhab-misc-myopenhab'
Openhabian (openHAB 2.3.0-1 Release Build) is showing this failure in the log:
2018-07-05 10:43:14.054 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab': Error restarting bundles:
Unable to acquire the state change lock for the module: osgi.identity; type="osgi.bundle"; version:Version="0.10.0.oh230"; osgi.identity="org.eclipse.smarthome.model.script.runtime"; singleton:="true" [id=139] STARTED [STARTED]```
I could use some advice on how to fix it.
  • Thomas
try to Clear the Cache
Sorry for not acknowledging your post, I didn’t see it until today; Three months late!
Thanks for the advice. Unfortunately clearing the cache did not solve the problem. System still runs, but the log file is reporting the error. Example:
2018-10-22 15:38:40.327 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab': Error restarting bundles:
Unable to acquire the state change lock for the module: osgi.identity; osgi.identity="org.openhab.binding.insteonplm"; type="osgi.bundle"; version:Version="1.12.0" [id=210] STARTED [STOPPED]
does this binding work properly?
it seems that your system can’t load it properly or when it is trying to reload this bundle something is stuck.
I’m fixing that now. After my post I found that OpenHab2 had been unexpectedly corrupted from the cache clear. The system was stuck endlessly trying to load.
I am reverting back to an earlier SD Card backup image. That is much easier/faster than trying to debug the crash problem.
mm I have the same problem after upgrading to Snapshot from 2.5
I did do a clear cache after upgrade
Everything else seems to work.
The name of the addon is openhabcloud and not myopenhab. You might be seeing this error now because the feature installation again logs missing addons on error (see PR #459).
There’s a lot of unnecessary load if it continuously tries to install an addon that doesn’t exist. See also [SOLVED] After upgrade to 2.4 stable I'm flooded with java.lang.IllegalStateException.
You also will run out of memory at some point. I confirmed that this problem still exists in recent snapshots.
Interesting. I failed reproducing it on 2.5.0-SNAPSHOT after adding some invalid binding to addons.cfg. I did open Basic UI, but maybe my desktop PC is too fast so it doesn’t continuously try to reconnect and add more SSE listeners. Did you test it on a more resource constrained device (rpi3) and did you obtain a heapdump?
untill I did the 2.5 upgrade, I had both addons in my config file and I had no warnings what so ever.
In my addons.cfg I had this line
misc = openhabcloud,restdocs,myopenhab
that never gave an error before 2.5 (Maybe in 2.4 release, I did not had that long running) before in 2.4.M5 I did not have it
Basic UI is not a factor here. Sorry if I wasn’t clear, but I was referring to the issue with invalid binding names in addons.cfg.
My test box is fairly powerful (6 core, 3.7 GHz, 8 GB). When I put an invalid binding name in addons.cfg, and monitor memory use with pidstat, I can see memory increase slightly every minute when it fails to install the bogus binding.
Below is a snip of a pidstat I’m running on the openHAB java process that logs every 15 seconds. This box is running build 1484. You can see the RSS and %MEM slowly increasing every minute. When I started this at 09:42:28, %MEM was at 11.67. It’s now at 12.57%.
I tried to debug this a while back, but I got a little lost in the code. I never did figure out what was causing the leak.
09:53:13 AM   UID       PID  minflt/s  majflt/s     VSZ     RSS   %MEM  Command
09:53:28 AM     0     25958      0.20      0.00 7052464 1020164  12.49  java
09:53:43 AM     0     25958     25.27      0.00 7054512 1020336  12.49  java
09:53:58 AM     0     25958      0.40      0.00 7054512 1020336  12.49  java
09:54:13 AM     0     25958      4.67      0.00 7054512 1020336  12.49  java
09:54:28 AM     0     25958      0.87      0.00 7054512 1020336  12.49  java
09:54:43 AM     0     25958     22.53      0.00 7054512 1020588  12.50  java
09:54:58 AM     0     25958      1.80      0.00 7054512 1020588  12.50  java
09:55:13 AM     0     25958      3.47      0.00 7054512 1020588  12.50  java
09:55:28 AM     0     25958      0.80      0.00 7054512 1020588  12.50  java
09:55:43 AM     0     25958     34.07      0.00 7054512 1021500  12.51  java
09:55:58 AM     0     25958      1.93      0.00 7054512 1021500  12.51  java
09:56:13 AM     0     25958      4.47      0.00 7054512 1021500  12.51  java
09:56:28 AM     0     25958      0.33      0.00 7054512 1021500  12.51  java
09:56:43 AM     0     25958     34.80      0.00 7054512 1022280  12.52  java
09:56:58 AM     0     25958      0.47      0.00 7054512 1022280  12.52  java
09:57:13 AM     0     25958      4.93      0.00 7054512 1022280  12.52  java
09:57:28 AM     0     25958      0.60      0.00 7054512 1022208  12.52  java
09:57:43 AM     0     25958     33.00      0.00 7054512 1022744  12.52  java
09:57:58 AM     0     25958      1.80      0.00 7054512 1022744  12.52  java
09:58:13 AM     0     25958      2.00      0.00 7054512 1022744  12.52  java
09:58:28 AM     0     25958      2.67      0.00 7054512 1022744  12.52  java
09:58:43 AM     0     25958     38.67      0.00 7054512 1023696  12.53  java
09:58:58 AM     0     25958      1.53      0.00 7054512 1023696  12.53  java
09:59:13 AM     0     25958     11.13      0.00 7054512 1023696  12.53  java
09:59:28 AM     0     25958      2.40      0.00 7054512 1023696  12.53  java
09:59:43 AM     0     25958     44.20      0.00 7054752 1024764  12.55  java
09:59:58 AM     0     25958      0.53      0.00 7054752 1024764  12.55  java
10:00:13 AM     0     25958     12.60      0.00 7054752 1024764  12.55  java
10:00:28 AM     0     25958      3.40      0.00 7054752 1024764  12.55  java
10:00:43 AM     0     25958     34.47      0.00 7056800 1025184  12.55  java
10:00:58 AM     0     25958     14.60      0.00 7056800 1025188  12.55  java
10:01:13 AM     0     25958      6.13      0.00 7056800 1025188  12.55  java
10:01:28 AM     0     25958      3.47      0.00 7056800 1025188  12.55  java
10:01:43 AM     0     25958     27.60      0.00 7056800 1025868  12.56  java
10:01:58 AM     0     25958      1.73      0.00 7056800 1025868  12.56  java
10:02:13 AM     0     25958      3.47      0.00 7056800 1025868  12.56  java
10:02:28 AM     0     25958      0.67      0.00 7056800 1025868  12.56  java
10:02:43 AM     0     25958     29.47      0.00 7056800 1026244  12.57  java
10:02:58 AM     0     25958      0.40      0.00 7056800 1026244  12.57  java
10:03:13 AM     0     25958      3.60      0.00 7056800 1026244  12.57  java
I should add that I first noticed this when one of my prod boxes was crashing every couple weeks. Once I removed the bogus binding name, that box has run rock solid for the last 11 months.
I had indeed the idea that things slowed down.
I did remove the myopenhab last night, to wait till things could be fixed, so you tell me I never have to add it and my system will run better?
did I understand that correctly?
Based on my testing results, any invalid binding name in addons.cfg will cause a memory leak that eventually will consume all available memory. The first indication of this may be that your system becomes more sluggish. Depending on the hardware config of your system, it could take a couple days or a few weeks. Not sure what your experience has been.
@wborn FTR, I’m running this to capture the above memory stats.
pidstat -r -p <openHAB process ID> 15
which reports memory consumption of the openHAB java process every 15 seconds.
And, if you run pidstat with a more fine-grained interval (like every 1 or 2 seconds), you’ll see a flurry of page faults every time the feature installer runs.
Personally I’m ok with an OpenHab that does not load when any invalid binding name is in addons.cfg
aka a stop the line.
I think that would make debugging a lot easier for many people.
(I’m not talking about a bad configuration of the binding, just an invalid binding name)
