I’ve just installed the RGBW controller from Fibaro and I am not able to control the colour using the colorpicker.
There is the following error in the logs:
[WARN ] [ternal.converter.ZWaveColorConverter] - NODE 18: Unknown color mode null.
Looks like a similar topic to:
If I understand correctly the colorMode=RGB config is missing from the db file. Is it possible to check locally if that fixes the problem?
