shame on me - you´re right. I have the same device but different revision.
I need to use blinds_control
instead of blinds_shutter
to position the shutter.
Yeah you need to play with the available options…
Just a guess: in gate mode, if you want to open the gate but not close it automatically.
Maybe it’s used for the Fibaro command classes, no idea. At some stage during initialization the device did report this channel, so it may be useful for something.
Hi community
I control my venetian blind with the development version of z-wave with Fibaro FGR222.
I would close the venetian blind and tilt 60%. i don’t now what is the best code for this requirement in the rule.
This is my actually code … i am not happy with this, but i have no idea to improve this.
EgWz_JalousieSofa_Shutter.sendCommand(100)
Thread::sleep(10000)
EgWz_JalousieSofa_Lamella.sendCommand(60)
have anyone a better solution to control the venetian blind with tilt 60%?
Omit the sleep(), you don’t need it. You can also set tilt first but that should not make a difference.
FWIW, I’m using the blinds_control channel, not blinds_shutter (and blinds_lamella for tilt).
Using shutter & lamella here - no need for sleep()
I am using the same sequence close and then tilt.
e.g. for all venetian blinds upstairs (ShutterPosition in group UpStairsBlinds and LamellaPosition in group gUpStairsBlindsLam)
gUpStairsBlinds.members.forEach[ShutterPosition | ShutterPosition.sendCommand(BlindsClosed)]
gUpStairsBlindsLam.members.forEach[LamellaPosition | LamellaPosition.sendCommand(blindLamella20)]
I was using blinds_control (tried with both UP/DOWN and 0/100) before, but received interesting values reported by FGR-222, which varied over time: https://community.openhab.org/t/z-wave-binding-fibaro-fgr-222-spontaneous-change-of-blindscontrol-state/33860/9 and Shading automation
Which made decision criteria for rules rather hard to predict.
After switching to ShutterPosition no issues whatsoever.
Note that blinds_shutter
and blinds_lamella
are of Dimmer type while blinds_control
is of Rollershutter type.
Thanks for the answer. but the following sequence does not work at my system. the shutter goes down and the lamella remain completely closed.
EgWz_JalousieLinks_Control.sendCommand(100)
EgWz_JalousieLinks_Lamella.sendCommand(60)
also with item shutter, it doesn’t work.
but I found something. Can it be that the value 100 for position (shutter and control) is out of permitted range? if I try with 99 it works. the following sequence works fine.
EgWz_JalousieLinks_Control.sendCommand(99)
does your system works with value 100?
ZWave allows for 0-99 only, so you used to send an out of spec value, that’s why. Or send “DOWN”.
Ok, thanks, that was the readon of my problem
why do you programm the sequence with .members.forEach ? that’s interesting.
what is better compared to controlling the group via command “sendCommand” directly ?
gUpStairsBlinds.sendCommand(BlindsClosed)
gUpStairsBlindsLam.sendCommand(blindLamella20)
is there a reason for this type of programming?
laziness mainly
I found it easier to read and edit to use .members.filter[…] and .members.forEach[…]
I am using the rule (example) below to determine if certain actions are required to be executed by FGR222s.
if ((gUpStairsBlinds.members.filter[ShutterPosition| ShutterPosition.state == BlindsClosed].size == 4) && gUpStairsBlindsLam.members.filter[LamellaPosition| LamellaPosition.state == blindLamella20].size == 4)
logInfo ("StatusUpdate", "LamPos UpStairs NoAction " + blindLamella20 + " %")
else
logInfo ("StatusUpdate", "Blinds UpStairs Closed, LamPos " + blindLamella20 + " %")
Interesting…
I’m just wanted to create a rule like that with the conditional filter to execute for “each” member of the group when the item “switch_automode” is true for that blind…
I guess your rule can be modified for that
I guess you stumbled over this https://github.com/OpenZWave/open-zwave/commit/9270fd92e7b666329a72aa5214c0105b12474ac8#diff-93a42c4304f18d0325fe0bf4f09bd382 before.
Not a developer myself, but I reckon it might be useful.
In case is this of any use, adding support for status feedback on venetian blinds tilt and position (blinds_shutter, blinds_lamella) would be greatly appreciated.
As far as I’m aware, that is what was implemented a long time ago. I just double checked the code, and the reports are being handled, so either there is a bug, or the device is not sending the reports.
I don’t have these devices, so can’t test - without something to work with, it’s difficult to comment. If you provide a debug log I can take a look.
bad news - no feedback whatsoever from FGR-222 when using HW switches
Zwave binding used:
223 │ Active │ 80 │ 2.4.0.201808210909 │ ZWave Binding
node13: network_e117085e__node_13.xml (16.9 KB)
logfile when blinds are raised via openhab: openhab lower-raise.xml (38.6 KB)
logfile when blinds raised by HW switches: switch lower-raise.xml (198.5 KB)
Additionally the HABadmin view of node 13:
Open for any advise to change parameters.
Unfortunately I’m not familiar with these devices. Reports are normally configured through associations - I don’t know if there’s another association group specifically for these reports, or if they are sent through the standard features like the lifeline. Unless the device sends something though, the binding can’t update itself.
Sorry - I know that’s not so useful, but I’m not sure what else the binding can do to resolve this - I would just suggest to update all associations to point them all at the controller and see if one of them starts the reporting.
with changing the associations groups to:
I am receiving updates from FGR-222 when using the HW switches:
node13_associations_set_up-down.xml (17.3 KB)
Additionally I changed “Self-Measurement” to active, to see which impact that setting has - unfortunately none
node13_associations_set_self_measure_ON_down-up.xml (20.5 KB)
I guess the updates on shutter position and lamella tilt are hidden in the „MANUFACTURER_PROPRIETARY“ messages.
@chris
Did you manage to identify a bug as suggested earlier?
FGR-222 are sending updates to controller now, but the “MANUFACTURER_PROPRIETARY” are not handled, which they should if I did understood your post https://community.openhab.org/t/fibaro-roller-shutter-fgrm-222-with-venetian-blinds-lamellas-position/9396/239 correctly.
Sorry - I didn’t see this before.
The system should normally process the manufacturer proprietary command responses, but this log shows it’s not working. I thought you said earlier that you were able to send commands from OH to set the position, or am I wrong and in fact it is not working? If it sends, then it should also receive as the command class should be added, but please let me know if sending is working so I can have a look.
