Fibaro Scenes
I use Fibaro FGS-213 for my lights and FGR-222 for my rollershutters.
From the manual I have read, that these actors support scenes as well.
Since I feel, that I might have misunderstood this, I would like to make sure, before wasting more time.
My idea was to fire an OH2 rule on double, triple tap or hold down. This would ideally be that a hold of the light switch opens or closes the rollershutters of that room. Do you think that is possible, or am I completey wrong?
Does any of you use these scenes and could guide me through the hardware (ZWay) configuration?
In ZWay I have tried to configure the options described in the manuals, but even in DEBUG logging I see nothing in OH.
Thanks for your help
Activate Scenes through your Config, create a Number item and bind that to the scenes channel, then create a rule:
rule "test scene"
	Item Test_Scene_Number_Item received update 16 //or whatever numbers your device is creating
	logInfo("File", "Scene number 16 triggered")
Thanks, sihui.
My Problem is at an earlier point in the hardware/zway configuration.
If I see a message arriving in OH, I know how to handle that.
Okay … I’m not of any help regarding that, I’m a zwave user :grinning:
Can you tell me what is different between Zway and ZWave ?
http://docs.openhab.org/addons/bindings/zwave1/readme.html
http://docs.openhab.org/addons/bindings/zway/readme.html
Hi, did you make any progress?
Is it possible?
I have the same devices and it would be great, if your idea works.
Thanks!
Yes, at least with the zwave binding. No idea about the zway binding, though.
Here is, what I found: Fibaro Double Switch 2 and Scenes - #3 by anfaenger
