I bought some Fibaro window sensor FGK-101 and I am trying to get them included properly. I am using an Aeotech USB Z-Stick Gen5 as z wave controller.
When I include the sensor by setting the controller in inclusion mode and hitting the TMP button on the sensor three times, the controller recognizes the sensor. The sensor even appears in HABmin, but it seems that the device is not recognized. It has no name and no manufacturer etc. set in the information.
I excluded and reincluded it twice. I even used another sensor (bought multiple). But with no successā¦
I also updated the addon to 1.8.2 with no success.
The lack of a green light means itās not completed initialisation. You should wake it up a few more times while itās close to the controller (ie with the stick plugged in so that openhab can talk to the device).
Just waking the sensor should do it (hopefully ). OpenHAB needs to receive a certain frame from the device so that it knows its awake and can communicate with itā¦
I forget if you need to use the one on the back, or the one inside - I remember this sensor being a bit of a pain to get included and working.
Is the device reasonably close to the stick (eg within a few meters should be fine). If you donāt get anywhere, check the logs to see if anything is received at all - it might be the inclusion wasnāt 100% successful.
10cm might 10 too close - yes - it is possible . If itās too close it might overload the stick and stop if from properly processing the data - I would try moving it a little further away (maybe a meter or so).
Otherwise, maybe try resetting the device (which is not easy as itās a ācomplexā process of putting the battery in and out and moving the magnet around if I remember correctly).
Iāve found these devices to be a right pain to get running - once running, they work well, but Iāve got a lot more grey hair because of them!
Got the first one up and running. And yes, I have some more grey hairs than usual. I am not sure what fixed it, but I will add 9 more, so I can figure out how to do it the optimal way.
I got them all up and running. I did it the following way. That worked quite well in the end
Prepare the sensor:
Open the sensor with a small screwdriver (be careful)
Remove the paper between the battery an the contact to activate the sensor.
Close the sensor (be sure that it is closed correctly. The sensor must not act like a button if you push the casing. This sometimes happens. It is important to close the device correctly.)
Include the sensor in the network:
Start HABmin.
Navigate to Configuration > Bindings > select the ZWAVE Binding > select the devices tab on the right
You should see at least your ZWAVE-Controller in the list of devices.
Hit āincludeā to start the 30 sec include mode
Hit the button on the back of the sensor 3 times in a short row.
The device starts to blink in blue. If it stops repeat step 5 until the 30 sec inclusion is over. Keep the sensor not to close and not too far from the controller (between 30 cm and 100 cm)
Hit āreload propertiesā in HABmin.
The new device should appear in the list (grey with no name)
If not, hit reload in your browser and navigate back to the device list.
If not, restart your openHAB server, hit reload in your browser and navigate back to the device list.
If not, repeat from step 4 until the device appears (This should happen rarely. I once needed two tries. I added 10 devices all together.)
The device starts to blink in blue. Keep the sensor not to close and not too far from the controller (between 30 cm and 100 cm)
Repeat steps 14 - 16 several times. The device in the list will first show up a name, then turn to yellow and then to green.
Congratulations, you fully added the sensor and it should work correctly now.
Hopefully this will help others
Thanks again Chris. I would not have been that insistent in repeating and would have never solved the problem without your help.
thanks to this topic I finally got my FGK-101 to show up with status green in Habmin.
But I still have the problem that sensor data does not show up in my logs. I expect some kind of busevent when I move the contact. There is only once an event when I press the button on the sensor.
I checked the sensor with the Zensys tool and it seems to be working.
Any ideas?
If nothing is showing up in the (debug) logs, then either the device is out of range (I guess itās not this) or more likely the associations arenāt set correctly. I would suggest to make sure that the appropriate group is configured to report to the controller.
Hello Chris,
I have problem with this sensor, the sensor shows always āClosedā, although I tried to change the distance between two parts the sensor.
I would suggest that the associations are not set. The associations tell the device where to send reports when something changes - if you donāt set the association, then there will be no update sent.
