jwiseman
(Mr. Wiseman (OH 4.2 Snapshot on Pi4))
165
I’m trying to have 2 different THINGS defined for 2 different states in the US.
The first THING and its channels were working fine, then I added the second THING and the first THING channels stopped working, no values anymore but the second THING channel has values.
I’m running this version → org.openhab.binding.weathercalculations-3.2.0.jar
Thanks for letting me know you’re seeing funny behavior.
I just took a look at the code and sure enough, I’ve got a TODO about being able to handle multiple things… right now, the thing handler assume’s it’s the only one and clears the list of items the binding is interested in. That seems to explain the behavior you’re seeing.
Let me take a day or two to think about how best to finish the job I started… it shouldn’t be difficult, I just want to make sure I don’t miss anything obvious. I’ll reply back when I have a new version that handles multiple things.
jwiseman
167
Thank you!
My guess it has something to do with this setting that is the same for each THING, just a thought.
OK, I’ve got a new version of the weathercalculations binding that should support defining multiple things. I’ve been testing it out here for a day or so and it seems to be doing what I expect. Please have a go and let me know if it solves the problem you were seeing.
Here’s the link to the new version:
If you installed the binding from the marketplace, you may need to uninstall the old version and install this new one. This message from about a week ago describes that process:
jwiseman
169
I’ve put it in and will report back tomorrow.
Thank you!
Jay
jwiseman
170
As a side note for others, I’ve uploaded the new version to the marketplace (I think, it seems like the only option is to simply replace the link on the listing.) If anyone needs to upgrade, I think you just uninstall the old version and re-install. Or get it from directly from the download link above.
Best,
Bill
jwiseman
172
Hey Bill,
I’m seeing the Trend factor being the same during the same binding calc cycle for 2 different states (IL & FL) when it shouldn’t be.
Here’s the config for both, if you want me to try different altitude for each location, I’d be glad to since I’m NOT 100% sure these are accurate.
Hoffman Estate, IL
Altitude = -798
Station Altitude = 231
St. Petersburg, FL
Altitude = 46
Station Altitude = 46
Both places have separate specific weather items for each location.
2022-06-12 03:57:40.051 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Chicago Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 03:57:40.369 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Florida Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 05:57:42.398 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Chicago Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 05:57:42.688 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Florida Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 06:57:43.618 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Chicago Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 06:57:43.795 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Florida Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 07:27:44.323 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Chicago Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 07:27:44.517 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Florida Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 07:57:44.850 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Chicago Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 07:57:45.124 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Florida Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 08:57:46.160 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Chicago Barometric Pressure Trend via MAP is Storm is coming
2022-06-12 08:57:46.449 [INFO ] [org.openhab.core.model.script.WEATHERCALC ] - Florida Barometric Pressure Trend via MAP is Storm is coming
Yep, seems I neglected the pressure trend calculation which uses a shared source of data. I’ll fix that tomorrow and get a new version for you to test out.
I’ve uploaded a new version (3.2.3) that I think should fix the problem. I’ve only had it running for a few hours, but it /seems/ to be working, if you’d like to try it out.
Have some updates on the subject of displaying weather forecasts:
After looking around and giving it some thought, I think that the idea of a common schema for forecast data may be a losing proposition. That’s mostly because there’s a wide variation in the data available between different sources and producing a schema that doesn’t omit data from more full-featured forecasts (like WeatherFlow’s) would result in quite a bit of complexity. It’s a shame, but the primary downside is that each widget would need to be customized; something you’d probably want to do anyhow.
I do think that weather flow’s data format would be a strong contender for the common schema, as it’s well thought out and includes all of the data you’d want.
Now for something you can actually play around with…
I’ve uploaded a new version of the smart weather binding that includes a new thing type: Better Forecast. Create one of these things and configure it with your station ID and an authorization token and you’ll get access to an automatically updated forecast based on your location. The Better Forecast thing also has features for trimming the number of forecasts in order to improve performance. By default, the forecast includes 10 daily and 220+(!) hourly forecasts, so you can cut a lot of data transfer if you don’t need that amount of data. It also “enriches” the forecast and current conditions with some extra fields that make building widgets a bit easier. This includes things like icons for the various conditions (a work in progress) as well as sunrise/sunset calculations.
In addition to the weather card widget file that you’ll use to create a new widget in the OpenHAB UI, you will need to add an empty file called “dummy.js” in your config/html directory, but that’s a one-time thing.
The widget does some “magic” that gets around forcing you to create a million items by parsing the JSON data before the widget fills things in. That, plus some of the extra fields the enrichment process contributes made the resulting widget code a lot simpler. Just be careful not to mess with the “onload” line in the widget. I’ve got some additional things I’d like to do (I want to add an option to use WeatherFlow’s weather icons, for example), so I will try to follow up when I have more to report.
In my opinion “a common schema for forecast data” would need to be, in the first place, rather a sort of the agreement made between weather bindings developers. Forecast sources from different weather providers deliver similar data i. e. weather data (temp, precip, humid, pressure etc.) and also description of the weather together with corresponding icons. The issue is that the same data are often delivered in different ways. If you are non-standard user, it’s fine, because you will rather choose to customize both, data and widget. However, for typical person who just want see forecast for the next 5-7 days with a “complete” widget it is important to have data in a common and consistent format. I would take Kodi as an example, where you have default widget for weather forecast and different providers that you can choose to install depending on the accuracy of data as appropriate to desired location. I could imagine something similar in OH, where you could have a weather widget with forecast available in OH3 from the start and user would just need to install any weather data binding, set the location in OH3 settings and choose weather provider in widget configuration to have it all set and working.
Once you’ve set a forecast thing up, you can link an item to the enriched forecast data and use this widget to display it in your OpenHAB UI:
Ok, sorry if this is a silly question, but how exactly should I configure forecast thing to have it working with the widget?
I made the thing and created items for each channel.
Now, what do you mean by “linking item to enriched forecast data and use this with the widget”?
As far as I understand the widget itself doesn’t need to be fully configured, but how should I link “enriched forecast” to the widget? Is this something I should put into “Item prefix” or change other setting, or maybe I should change something in the YAML code? Right now I get error as follows:
In it’s configuration, there’s a setting for “Forecast Item”. Set that to the item you created above for the “enriched forecast”… I think you’ve called it WeatherFlowForecast_ForecastEnriched.
That should be all you need to do. There is a lot of data available that isn’t displayed. You can customize that if you want, the code is a lot simpler than the original version because all of the data is in the one item and it gets parsed into a javascript object so you can do something like:
=items[props.item].objState.current_conditions
I’ve included an example of the kind of data you can get from the enriched forecast here:
One side note: I found a bug in the Main UI that was causing the forecast icons to be missing. My fix was accepted a week or two ago and it should be present in the latest snapshot.
Yes, I think that in order to be useful, you’d need to account for data that most people wouldn’t care about (but that some might)… yahoo weather probably doesn’t include a lot of the types of data that the weather flow data does. Right now everyone has been tailoring their widgets and such to the specific data source they’re using. Maybe if we got to the point where we had some really good widgets that used the weather flow format, we might convince people to convert their data to the weather flow format.
There are some other weather formats that seem well thought out (the Norwegian meteorology department looks nice), but even the best of those don’t have places for the detail available in the WF format.
Thanks Bill! Amazing work. It didn’t work for me in the first place because I have hade already installed WeatherCard widget with the same UID, so this time I’ve copied YAML to new widget and changed UID and it works.
It seems that enriched forecast provides a lot information. If i find some spare time I would like to build a full screen weather widget with these data. Thanks again for your work!
i had it installed manually (updated version 3.2.1), after OH upgrade i was trying to install one from the store 3.2.2 and got the error above, nothing more.
I suspect that the marketplace feature doesn’t know how to deal with upgrading a bundle that’s been manually installed. The marketplace is still a fairly new feature, so they probably haven’t figured out all of the use cases. Glad you were able to get it installed eventually!
