There are a couple of ways but here’s one (typed from memory so may be small issues/typos)
googlemaps.items
Number GoogleMaps_me_distance (gGoogleMaps)
Number GoogleMaps_me_duration (gGoogleMaps)
Number GoogleMaps_me_duration_traffic (gGoogleMaps)
String GoogleMaps_me (gGoogleMaps) { http="<[https://maps.googleapis.com/maps/api/distancematrix/json?origins=Amsterdam&destinations=Rotterdam&language=NL&departure_time=now&traffic_model=best_guess&mode=driving&key=YOUR_API_KEY:60000:default]" }
Number GoogleMaps_wife_distance (gGoogleMaps)
Number GoogleMaps_wife_duration (gGoogleMaps)
Number GoogleMaps_wife_duration_traffic (gGoogleMaps)
String GoogleMaps_wife (gGoogleMaps) { http="<[https://maps.googleapis.com/maps/api/distancematrix/json?origins=Amsterdam&destinations=Haarlem&language=NL&departure_time=now&traffic_model=best_guess&mode=driving&key=YOUR_API_KEY:60000:default]" }
I would then have two rules:
googlemaps.rules
rule "google maps - me"
Item GoogleMaps_me received update
var String json = GoogleMaps_me.state.toString
var distance = transform("JSONPATH","$.rows[0].elements[0].distance.text",json )
var duration = transform("JSONPATH","$.rows[0].elements[0].duration.text",json )
var duration_traffic = transform("JSONPATH","$.rows[0].elements[0].duration_in_traffic.text",json )
GoogleMaps_me_distance.sendUpdate(distance)
GoogleMaps_me_duration.sendUpdate(duration)
GoogleMaps_me_duration_traffic.sendUpdate(duration_traffic)
rule "google maps - wife"
Item GoogleMaps_wife received update
var String json = GoogleMaps_wife.state.toString
GoogleMaps_wife_distance.sendUpdate(distance)
GoogleMaps_wife_duration.sendUpdate(duration)
GoogleMaps_wife_duration_traffic.sendUpdate(duration_traffic)
An alternative would be to keep the HTTP binding definitions as they are and utilise the request caching function.
Great Job! This helps a lot. My wife has three branch offices she has to visit regulary, and I have to travel to my company at least once a week. All destinations are along the A2 Autobahn in Germany which is always congested. Now I set up a panel with the route and time for each location with this widget.
But “getting hungry while eating” I thought about a rule that will give a warning (sending an e.mail) when the actual time for a route exceeds a given time. I read the Google documentation of the JSON, but I am obviously not experienced enough to understand how to get the duration in a “calcuable” Format:
“status”: “OK”,
“duration”: {
“value”: 24487,
“text”: “6 heures 48 minutes”
I am looking for something like:
If GoogleMaps_me_duration_traffic > “130 minutes” then …
Any idea?
I could then combine this in a rule that uses the typical day of the week for our trips, calculate back from our typical needed time of Arrival to see if it is time to start earlier than normal.
May be me thoughts are to complicated, but looking at the json, the value did not look like a time in minutes, and the formatted string did not look usable, too.
I tried your example rule never the less, but it does not work.
rule "gifhorn>60_Minuten"
Item GoogleMaps_gifhorn_duration_traffic changed
if (GoogleMaps_gifhorn_duration_traffic.state > 60) {
sendMail("xxx@yyy.de", "Fahrzeit Gifhorn > 1h", "Fahrzeit Gifhorn > 1h")
I think I need the GoogleMaps_gifhorn_duration_traffic.state instead of the GoogleMaps_gifhorn_duration.state, as I want to use the duration with the actual traffic situation. So this is a change to your code. But although I had several situations yesterday and today that show up in the log with a duration of more than 60 minutes like these:
2018-03-07 08:05:45.716 [vent.ItemStateChangedEvent] - GoogleMaps_gifhorn_duration_traffic changed from 1 Stunde, 3 Minuten to 1 Stunde, 1 Minute
2018-03-07 08:10:47.088 [vent.ItemStateChangedEvent] - GoogleMaps_gifhorn_duration_traffic changed from 1 Stunde, 1 Minute to 1 Stunde, 2 Minuten
2018-03-07 08:20:50.032 [vent.ItemStateChangedEvent] - GoogleMaps_gifhorn_duration_traffic changed from 1 Stunde, 2 Minuten to 1 Stunde, 1 Minute
2018-03-07 08:30:52.502 [vent.ItemStateChangedEvent] - GoogleMaps_gifhorn_duration_traffic changed from 1 Stunde, 1 Minute to 1 Stunde, 0 Minuten
I also noticed that using the map.html in HABpanel dashboard exhausted my Google Maps quota. Having looking a the javascript code I noticed that it refreshes every 10 seconds.
window.setInterval(function(){
console.log("Updating Google Maps traffic and travel time");
reloadTiles();
if (gm_travel == 'true') {
calculateAndDisplayRoute();
}, 10000);
A call every 10 seconds = 6 per minute = 360 per hour = 8640 per day.
Ups, I must have calulated something stupid then, when trying to identify the value. You are absolutely right, it is a value in seconds. But for the code in the rule this would mean, that I should have gotten an E-Mail with every change, as all values are above one minute (instead of one hour as intended) then. But I did not get any at all.
So there must be another problem above seconds instead of minutes.
Getting the most actual values always sounds great, but here I think it is worth to take in mind, that a delay of several minutes (something above statistical noise) needs exactly this time to happen. There cannot be a relevant new delay of several minutes between a reading now and a reading in ten seconds.
Therefor I use a five minutes interval instead of a ten second intervall. As I now monitor three routes I have not seen any bigger difference between two readings than two minutes. And that is still statistical noise. So I do not see that there would be any use in a ten second intervall, and that there really could be a problem with an Intervall that does not exceed the daily quota.
This looks like your item is a String, not a number. I would need to see the rest of your log to confirm but I would imagine that checking your String is greater than 60 would either error, or give you an unexpected result.
The above issue aside, the rule would send an email every time the the duration changed but was above 60minutes. You may end up with several consecutive emails alerting you to the traffic so you may want to factor in some proxy item or some kind repetition restriction.
Thas was my initial question/concern when asking for a calculatable value The log does not show anything else than the already cited messages of the changing time with the full formatted text hours/minutes. So no errors on type mismatches.
The item is generated by the frist defintion that given here this way:
But I think I now found the solution by myself: As this definition generates a String from JSONPATH($.rows[0].elements[0].duration_in_traffic.text) I tried to define a number and went back to the JSON defintion that has a string and a value line. So I tried to define an item like this
Number GoogleMaps_gifhorn_duration_traffic_time "Duration [%d]" (gGoogleMaps) { http="<[https://maps.googleapis.com/maps/api/distancematrix/json?origins=Langenhagen&destinations=Gifhorn&language=DE&departure_time=now&traffic_model=best_guess&mode=driving&key=mykey:300000:JSONPATH($.rows[0].elements[0].duration_in_traffic.value)]" }
And this item has the duration in seconds so that I can make calculations with it.
The rule up to now is just sort of a PoC and as it works now, it really generates a lot of mails.
So the next challenge would be something like:
var mail=false
if day_of_week=Wednesday and actual_time > 07:30 and actual_time < 10:30 and actual_time + duration_in_seconds > planned_arrival_time and mail=false
send E-Mail
mail=true
This would mean, that I would get just one mail on wednesday mornings when it is time to leave to arrive in time.
everytime I start it up.
I googled this Error msg and found that it is caused bye the maps API not knowing the Start and End Location. However, this also happens if I try any locations (like generic “Berlin” to “Hamburg”)
Any Idea?
edit: I figured it out!
I should not set a zoom level if i want distances
Seems like you dont support german letters: ä;ö;ü (Köln) for example does not work!
MOST IMPORTANT: You dont support “ß” - common in “Straße” which… you guessed right, translates to “Street”
Example locations that do not work:
“Von-Werth-Straße+240,+50259+Pulheim”
“Anystreet, Köln”
