max2
(max)
January 16, 2019, 5:37pm
1
I want to control my new WS2812 strips with a H801 controller- that’s why I connected the Data Pin (WS) to W1 (H801) and of course the power.
a few LEDs are on, but I can not control it.
I’ve attached my config and a picture of the LEDS which are on.
Can anyone help me?
scottk
(Scott Karns)
January 16, 2019, 6:49pm
2
Hi, @max2 . As far as I know the H801 will only work with “dumb” LED strips, i.e., non-WS2812/WS2811 strips. I have several H801s here that I use to control multiple warm white strips. If I’m not mistaken, the H801 is only compatible with common anode, multi-color strips with a single connection at the strip for:
VCC (12 to 24 VDC)
PWM connection per color/channel
The H801 does not provide a serial control output required by WS2812/WS2811 strips.
max2
(max)
January 16, 2019, 7:23pm
3
Oh, that’s not nice.
Than I have to search for a better solution- maybe my Sonoff Basics work.
I’m not sure if for Example Wemos D1 Mini would work directly because it has a 3,3V System.
max2
(max)
January 16, 2019, 8:04pm
4
So I’ve connected it with a Sonoff Basic (Power connected to 5V power supply, GND Sonoff > GND Led Strip, D > GPIO 14 (Sonoff).
(A few LEDs are on)!
Set GPIO 14 as WS2812, but I am not able to control it - color and brightness does NOT change.
Appreciate your help and sorry for my bad English!
MDAR
January 16, 2019, 9:37pm
5
WS281x or SK6812 SPi chips need a very specific data stream to control them.
With each chip needing 3 seperate channels.
I would “STRONGLY” advise using one of these.
Introduction NetWS-340 will drive up to two ArtNet/sACN Pixel Universes (340 WS2811/WS2812/Neopixel Pixel-LEDs) over a wired Ethernet network. DMX Protocol Selection, Device IP, ArtNet/sACN Settings and LED configuration is adjustable directly from...
With the DMX binding for openHAB2, you’ll be able to do some pretty amazing things.
HOWEVER…
It’s very possible that you’ve totally fried the first chip on your tape by putting a PWN signal into it.
If it doesn’t work, just cut off the first 1 or 2 chips and try again.
max2
(max)
January 17, 2019, 6:02am
6
The NetWS-340 are too expensive. I only want to control colours and maybe one or to effects.
I can cut it off this evening, maybe it helps.
But my Sonoff BASIC Setting is okay now?
MDAR
January 17, 2019, 6:39am
7
Always your choice for hardware, I was only offering a suggestion that I know works well and is easy to configure.
Have you done a Google search for Sonoff WS2812 ?
There’s a great topic on this forum,
Dear Community,
I saw many subjects here about controlling RGB Strip WS2811, WS2812, WS2813 using ESP8266 or Arduino.
Can I control rgb strip using GPIO, without extra hardware such as ESP8266 or Arduino?
I found these post that might be of interest to you.
They seem to refer to Tasmoto firmware and hidden commands.
opened 01:02AM - 18 Feb 17 UTC
closed 07:07PM - 08 Mar 17 UTC
I just bought a WS2812B 5Meter 300 LEDs Light Stripe and tried to make i… t run with Sonoff Basic.
I tried to uncomment #define USE_WS2812_DMA and use it on the RX (GPIO3) and even on the GPIO 14 but cann't really make it run. I connected 5V from the transformer directly to the stripes and the Data Pin with the GPIO of the Sonoff Basic.
Only the first few LEDs are reacting and even not correctly. I tried it with RGB and GRB Mode.
Did anybody get it run already?
Greetings
Thommy
max2
(max)
January 19, 2019, 9:41am
8
So I’ve ordered new stripes, this time normal (RGBWW) Stripes, with “real” warm-white.
I want to use my H801- but I found no tutorials on how to setup the Items & Sitemap in OH2.
EDIT: Solved
I succeeded in using the H801 to control WS2811 lights. For this you need to modify the printed circuit board by bypassing a mosfet. As you can see on the picture you need to cut one wire and short circuit the other two. Then you need the Adafruit_NeoPixel driver and change in the code the wire pin to 14.
Good Luck!
Kind regards,
Robert
20191115_163658|281x500
