I got a solution, had to force rotini app to close down, it works fine now. apparently i could not self update. thank you for fast reply
However i got another issue
I use the Denon Binding for controlling my AVR there is a command “DenonCommand” when i use your mode widget it always say N/A and shows no icon. it is because that specific command do not get updates. read more on denon binding, if you like
But could it be possible to just make a default Label and icon? if it is undefined or whatever it will just roll back to that.?
In a true “mode” sense there should never be a default, since there is always known list of modes, so I don’t think it makes sense to add that mode widget.
If binding doesn’t send updates maybe a custom rule that always send state update after a command would fix that? Otherwise, wouldn’t you always loose latest/current denom command anyway, in case of openhab restart or something?
If i use density compact or moderate, the text of some switches is not displayed completly anymore. If the text is too long, i can only see “text…”. Can you adjust the font size, too? So that you can see the whole text label in small font size?
Text is already adjusted and smaller in compact/moderate density, but relatively there is less space to work with, so less text will fit on average.
Can you post a screenshot as an example though?
Also, do you have any font scaling applied in system settings? Such as large text option in accessibility or anything else that is related to system font size
Seems like Rotini does some nasty background network traffic. I switched off wireless today in the office at 10am and checked the status. Then I left Rotini backgrounded. Till 9pm it polled 800 megs of data. Luckily I do have a flat.
Any ideas?
@waitz_sebastian Can you tell me a bit more about your setup:
• do you have refreshing images/mjpeg added to your sitemaps (especially one that was selected at that time)?
• how many items do you have in the system?
• how many sitemaps?
Answer: Yeah, I’m just testing the new camera widget on my main Sitemap. Contains one image camera with 10sec refresh and 1x mjpg Camera.
Answer: I have 140 different items in my OH setup and 85 are used on the main rotini sitemaps
Answer: 4 sitemaps. 3 are used by rotini
Best guess would be the new mjpeg Camera widget having the stream still active even in background mode. Yes, I closed the app via pressing the home button.
I only went from wifi to cellular because rotini does not refreshin wifi mode when connected to any other wifi than the home one.
Hope this helps debugging the issue. Any questions, let me know.
Yeah if you have any webcams or images that refresh… beware as it will use lots of data… I have a separate sitemap that I access remotely where the images refreshes are set very low.
This what I supposed, but had a problem to put few 1x1 amd 2x2 widget in correct order
Ie. to check if any door or window is open. I know that I can put each of them, but if you have 20+ sensors it is not easy to check one by one. In openhab app I have condition that visible are only active, so just simple look on escreen before you will leave a home and you know everything
Found a bug. It doesn’t happen all the time, but in certain conditions the app will reconnect the mjpeg stream (or sitemap updates stream for that matter) when it goes into background.
Improvements:
• Swipe-to-refresh support for sitemap tabs
• Periodic auto-refresh for selected sitemap (every minute) and list of sitemaps (every 10 minutes) while the app is active
Fixes:
• Some connections are not closed after application goes into background
