I got a new Homematic CCU3 and try now to connect it with the Homematic Binding 2.3. It tries to initialize the gateway and ends with the following error:
Status: OFFLINE - COMMUNICATION_ERROR Unknown XML-RPC tag: title
Firmware: 3.41.11
I set the firewall settings on the ccu3 already to allow anything. Any suggestions?
Ah ok, but 2.4m isn“t stable correct? So I need to change the repo and run apt get install openhab2 again. Does it just update and keep my settings or is it going to reset my whole setup?
That is good to know. Do you know something about the update process from stable to snapshot? I have OH installed on Ubuntu so I have to update it manualy by apt.
Will my setup survive the update?
I have already AVM FritzBox and Osram Lightify binding with several things running and additional HomeKit integration.
if you are using apt: follow the installation instructions on openHAB on Linux | openHAB
Change to the appropriate repo (testing=milestones or unstable=snapshots) and simply apt update and apt install (it will deploy 2.4.0 M6 on top of your existing 2.3.0 Stable and effectively upgrade it). I have added some info in the FAQ around this.
From 2.3.0 Stable to 2.4.0 M6: absolutely yes. I donāt remember any major breaking change (outside Z-Wave) that should give you lots of troubles. Backup your OH2.3.0 first of course.
Even the CCU was discoverd automatically and appears in the inbox. But while adding it it stucks on āInitializingā
Manaully adding gives the same resultā¦
2018-11-22 21:11:58.297 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing āhomematic:bridge:e4b325c7ā takes more than 5000ms.
2018-11-22 21:13:19.869 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing āosramlightify:power:84-18-26-00-00-0E-F4-D5ā to inbox.
2018-11-22 21:25:47.617 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing āhomematic:bridge:3014F711A0001F98A99A42ADā takes m$
2018-11-22 21:25:55.786 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing āhomematic:bridge:3014F711A0001F98A99A42ADā to inbox.
maybe sothing more interesting ā¦
2018-11-22 20:26:33.781 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while disposing handler of thing āhomematic:bridge:a4996c41ā$
at org.openhab.binding.homematic.internal.discovery.HomematicDeviceDiscoveryService.waitForScanFinishing(HomematicDeviceDiscoveryService.java:17$
at org.openhab.binding.homematic.internal.discovery.HomematicDeviceDiscoveryService.stopScan(HomematicDeviceDiscoveryService.java:121) [222:org.$
at org.openhab.binding.homematic.handler.HomematicBridgeHandler.dispose(HomematicBridgeHandler.java:143) [222:org.openhab.binding.homematic:2.3.$
at sun.reflect.GeneratedMethodAccessor31.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarth$
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh230]
Just noticed that my fritz box binding is now also not working⦠even fritz box and all things were online.
Have removed the fritzbox and now while adding it back, it stucked at initializing⦠:-(
I am going to setup a new vm and try with a new fresh setup once again⦠then directly with 2.4
brand new setup⦠all new binsing are not workling.
same issue like before on old system with homematic. now with avm. so testing builds are really not stable :-/
2018-11-23 21:37:17.857 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document ā/ESH-INF/binding/binding.xmlā in module āorg.openhab.binding.avmfritzā c$
java.lang.IllegalArgumentException: The XmlConfigDescriptionProvider must not be null!
at org.eclipse.smarthome.core.binding.xml.internal.BindingInfoXmlProvider.(BindingInfoXmlProvider.java:59) ~[?:?]
at org.eclipse.smarthome.core.binding.xml.internal.XmlBindingInfoProvider.createDocumentProvider(XmlBindingInfoProvider.java:141) ~[?:?]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.acquireXmlDocumentProvider(XmlDocumentBundleTracker.java:180) ~[100:org.eclipse.smarthome$
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.addingObject(XmlDocumentBundleTracker.java:205) ~[100:org.eclipse.smarthome.config.xml:0.$
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:351) [100:org.eclipse.smarthome.config.xml:0$
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:337) [100:org.eclipse.smarthome.config.xml:0.$
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$4(XmlDocumentBundleTracker.java:332) [100:org.eclipse.smarthome.config.xml:0.10.0.$
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:307) [100:org.eclipse.smarthome.config.xml:0.10.0.oh2$
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
all bindings throw the same warn? The XML document ā/ESH-INF/binding/binding.xmlā in module [...] c$ java.lang.IllegalArgumentException: The XmlConfigDescriptionProvider must not be null! ?
I just tried M6 and installed avm & homematic and it doesnāt give me any warningsā¦
I have seen this error usually associated with an old JVM (or openJDK)
