aha! this is the root-cause of your problems…
We are not still there yet… OH2.x cannot run (yet) under JVM 11
You need to downgrade to JVM 8 and you will be just fine.
I feared that … I will try a new vm again. don´t like “messy” systems… should i go with oracle or use zulu for best compatibility?
Personally, I choose the “devil” (Oracle)… they own Java now
The official recommendation is Zulu of course
both work fine
openjdk version “1.8.0_192”
OpenJDK Runtime Environment (Zulu 8.33.0.1-linux64) (build 1.8.0_192-b01)
OpenJDK 64-Bit Server VM (Zulu 8.33.0.1-linux64) (build 25.192-b01, mixed mode)
zulu installed, switched java to zulu
still same. no binding is coming online
but i think the error message seems to be different?
2018-11-23 22:29:35.811 [INFO ] [.eclipse.smarthome.binding.homematic] - FrameworkEvent INFO - org.eclipse.smarthome.binding.homematic
java.io.IOException: Exception in opening zip file: /var/lib/openhab2/cache/org.eclipse.osgi/197/0/bundleFile
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:321) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.basicOpen(ZipBundleFile.java:93) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:106) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.checkedOpen(ZipBundleFile.java:65) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getEntry(ZipBundleFile.java:240) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:560) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.RpcClient.listBidcosInterfaces(RpcClient.java:118) ~[?:?]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.RpcClient.getGatewayInfo(RpcClient.java:243) ~[?:?]
2018-11-23 22:32:17.322 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘avmfritz:fritzbox:192_168_188_1’ to inbox.
2018-11-23 22:32:17.410 [ERROR] [org.eclipse.smarthome.io.rest.sse ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.sse
org.osgi.framework.BundleException: Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.r$
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309) ~[?:?]
at org.eclipse.osgi.container.Module.doStart(Module.java:581) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:449) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction$23.run(SecureAction.java:474) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction$23.run(SecureAction.java:1) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:472) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.start(ModuleContainer.java:750) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:741) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:511) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:457) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:1001) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1382) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://31.fwk1208442275/javax/ws/rs/ext/RuntimeDelegate.class to b$
at javax.ws.rs.ext.RuntimeDelegate.findDelegate(RuntimeDelegate.java:146) ~[?:?]
at javax.ws.rs.ext.RuntimeDelegate.getInstance(RuntimeDelegate.java:120) ~[?:?]
at javax.ws.rs.core.MediaType.valueOf(MediaType.java:179) ~[?:?]
at org.glassfish.jersey.media.sse.SseFeature.(SseFeature.java:62) ~[?:?]
at org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start(SseActivator.java:49) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772) ~[?:?]
… 18 more
2018-11-23 22:32:17.549 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2018-11-23 22:32:17.612 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-11-23 22:32:18.185 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-avmfritz’: Error restarting bundles:
Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
if this is the first startup of OH2.4.0.M6 on a clean system, that’s fine.
stop OH2 service, run openhab-cli clean-cache
wait 10 secs and then start it again and monitor logs.
is Zulu selected as the default JVM?
what does java -version
show on the linux console?
edit: included openhab-cli clean-cache
above.
I am tryiing now a blank new vm (again) with zulu 8 only.
have installed OH2.3 stable right now. lets see how it works
After next 5 minutes initializing switch to:
Status: OFFLINE - COMMUNICATION_ERROR Unknown XML-RPC tag: title
Same what I had with OH 2.3. But still no error in the openhab.log
Am I missing something? CCU firewall is currently open.
HomeKit and Osram is also working fine. Just the CCU not. …
I found the solution!
Looks like in the new firmware is one point under security: Authentication: Default is on. It needs then user/passwort to get access to the RPC API. Since the binding has no option to enter user / pw I disabled it on the CCU and voila… it works. CCU is online and found my things.
Thank you DIM to goiing through with me
Maybe the Homematic Guide should be updated with a warning or hint to deactivate the option in the CCU.
Same problem with CCU. How can I disable it on the CCU?
Settings --> Security --> Authentication (2nd from the bottom). Deactivate the checkbox
That did it. Thanks a lot!!!
This should be fixed in the next ESH stable release (probably build 318).
donativo: that and you’re running on 2.4M6 right? so it wouldn’t work on 2.3 even without the auth turned off? Mine is turned off by default and it doesn’t work on 2.3…
…answering my own question - yes, the same config which didn’t work on 2.3, works flawlessly on 2.4M6 after an upgrade by apt-get upgrade as described in the upgrade/installation manual
Thank you all for the advice to upgrade, guys!
I have a same problem with ccu3. I have disable the authetification Bottom on security values for XML_RPC.
My openhab version is 2.3.0.005 on Synology.
I can not update this Verion of 2.4. i d´nt have a spk file for this.
What can do?
HI, I have the same issue.
I use raspberrymatic in the current version 3.41.11.20181126
and openhabian with version 2.3.0-S1451-1
I disabled the authentication on the ccu, but in openhabian I have the rror
Unknown XML-RCP tag:title
Same message is in the /var/log/open2/events.log
I’m using Zulu Embedded 8.25.0.76
Any idea guys?
As DIM said it seems to work only with OH 2.4 M6.
Hi Don,
thanks for your answer.
I changed my environment to the testing channel and got version
2.4.0-S1452-1
cleared the cache but still the same issue.
I had a look here
They wrote Get 2.4.0 Milestone 6 from here: [JFrog.io](https://openhab.jfrog.io/openhab/libs-milestone-local/org/openhab/distro/openhab/2.4.0.M6/) (or the testing repo)
but it wasn’t a m
version for me.
How can I get the m
version?
Regards
Matthias
This is the latest Snapshot Build, so you can’t get any better/newer than this
let me see how we can debug this
first of all, let’s see which version of the binding is being loaded
Use the openhab console and:
bundle:list -s |grep -i homematic
That’s the output
192 │ Active │ 80 │ 0.10.0.201812070742 │ org.eclipse.smarthome.binding.homematic
