I am tryiing now a blank new vm (again) with zulu 8 only.
have installed OH2.3 stable right now. lets see how it works
fritzbox is working again on stable. I will move forward to 2.4M6 now
OH 2.4M6 is installes. AVM binding still working OK
Homematic CCU is again only intializing… but without any errors in the logs…
After next 5 minutes initializing switch to:
Status: OFFLINE - COMMUNICATION_ERROR Unknown XML-RPC tag: title
Same what I had with OH 2.3. But still no error in the openhab.log
Am I missing something? CCU firewall is currently open.
HomeKit and Osram is also working fine. Just the CCU not. …
Looks like in the new firmware is one point under security: Authentication: Default is on. It needs then user/passwort to get access to the RPC API. Since the binding has no option to enter user / pw I disabled it on the CCU and voila… it works. CCU is online and found my things.
Thank you DIM to goiing through with me
Maybe the Homematic Guide should be updated with a warning or hint to deactivate the option in the CCU.
donativo: that and you’re running on 2.4M6 right? so it wouldn’t work on 2.3 even without the auth turned off? Mine is turned off by default and it doesn’t work on 2.3…
…answering my own question - yes, the same config which didn’t work on 2.3, works flawlessly on 2.4M6 after an upgrade by apt-get upgrade as described in the upgrade/installation manual
thanks for your answer.
I changed my environment to the testing channel and got version
2.4.0-S1452-1
cleared the cache but still the same issue.
I had a look here
They wrote Get 2.4.0 Milestone 6 from here: [JFrog.io](https://openhab.jfrog.io/openhab/libs-milestone-local/org/openhab/distro/openhab/2.4.0.M6/) (or the testing repo)
if it’s not too much trouble: try to upgrade your Zulu JVM to something newer
You are on the latest core (OH 2.4.0.S1452) with the latest binding 201812070742 being loaded… I don’t know why you are still getting these comms errors…
openjdk version "1.8.0_181" OpenJDK Runtime Environment (Zulu 8.31.1.122-linux_aarch32hf) (build 1.8.0_181-b122) OpenJDK Client VM (Zulu 8.31.1.122-linux_aarch32hf) (build 25.181-b122, mixed mode, Evaluation)
But still the same error
2018-12-07 16:38:42.268 [hingStatusInfoChangedEvent] - 'homematic:bridge:OEQ0302737' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Unknown XML-RPC tag: title
