Xtend - Expressions (see Range Operators for forEach, filter, etc and see Short Circuit Boolean Operators for ?)
Then you may have to either change the Item’s Group using the OH REST API calls or model this behavior some other way, for example a separate Item. This might help with that.
Ah, OK. Too bad. I had my hopes up that you had something a little less interactive in mind.
