Try now - I found that after the upgrade of the CMS earlier this week it seems to have reset a bunch of access privileges to “Not allowed” - this removed the ability to log in at all!
I’m in!
Thanks Chris!
Rob
- sorry for the hassle, and thanks for the help…
Shall I delete your second user that you just created? The first one should have access to edit the database.
Yes please… it’s the treborjm one.
Thank you!
Done - thanks.
@chris I have an xml for a Zipato rollershutter that is not in the database yet but I don’t have permissions to add it. can you help?
I’ve updated your access so you should be all set.
Cheers
Chris
@chris I added a device to the DB but got an error that thingid contains invalid characters. any idea what this is? do I need to do anything to fix this?
this is the device I added:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/519
It’s caused by the “-" in the thing id. I’ll sort this, but can you upload the manual, and an image as well please so I can check a few things.
added!
It looks like this is a duplicate and was already in the database?
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/175
hmm okay, so why are they showing up as unknown devices in habmin 2?
label reads Z-Wave Node 10 (013C:0001:0015:1.2)
I think it’s only been updated with your codes in the past few days so it’s probably not in the binding at the moment - try updating to the latest snapshot and see if that helps.
any hints on where to find the snapshot and how to install it? still getting confused by parts of OH2
It is best to use the latest snapshot of the runtime - then you can just install the latest binding through PaperUI or HABmin.
If you need to manually install bindings, then it’s more difficult unfortunately.
okay, switching to snapshot made sure that the devices showed up and work. but I’m trying to switch the “invert control” property in the channel configuration, when I click save and refresh the page, the setting hasn’t persisted
Same for me. I installed the snapshot version of the binding (How to install a SNAPSHOT version of a binding in a OH2b4 installation - #7 by reyem) and now the roller shutter is recognized again, but the setting for inverting the percentage is not persisted.
Hi, would it be possible to change my accounts so I can also add a new device to the Database?
Kind regards
Done.
I want to use the Philio Tech PAT02-B Temp./hum. sensor.
He is in the database on cd-jackson.com but openhab detects an Unknown Device.
I see that the sensor is not in the zwave binding database of OH2. Could that be the issue?
Could you please add it to OH?
